Question about HP DeskJet 970cxi InkJet Printer
Deskjet 970cxi will not print
I have tried all the suggestions in trouble shooter with no effect. I have also connected the printer via a USB cable, which was installed via the windows wizard with no problems, but it still would not print. Normally the printer is connected via a standard cable. A test print looks perfect. Windows device manager says all devices working properly. What I can I do now?
  • Anonymous Dec 03, 2007
  • Anonymous Mar 22, 2008
    Printer aangesloten via com-poort of Usb hij print gewoonweg niet.
    Opnieuw installeren via cd-rom geeft hij aan printerkabel is niet aangesloten,
    maar is wel aangesloten.
    Wat nu,kan iemand mij een oplossing bieden!!!
I need to get the driver software Dekjet 970cxi
Can I get driver software.
Posted on Feb 29, 2008
My Deskjet 970cxi printer is now using too much ink (which does not dry) when printing photos on premium photo paper. the results on ordinary paper are much better. How can I rectify this Ian
When you give a photo print, the print quality will be high.
To adjust this go to Printer properties.
1) Go to control panel
2) Open Printers and Faxes.
3) Right Click on Printers.
4) Select Printer Properties.
5) Select Printing Preferences, and choose quality of photo print to medium
Dec 03, 2010 | HP DeskJet 970cxi InkJet Printer
My printer will not print. It says it is queued and it just will not do anything. What can I do to make it print? It does not even say error or anything.
Remove the printer from your PC, delete the printer, restart the machine. Attach the printer, preferably with a USB cable and not the parallel cable. If you already had it using USB, attach it to a different USB port. Reinstall using the Windows driver instead of the driver that came with the printer. Your printer should work after that.
Apr 07, 2010 | HP DeskJet 970cxi InkJet Printer
Were can I get a ethereal cable for my deskjet 970 cxi printer
you can get a cable from any local store example : bestbuy, staples, office depot or a local tech shop.
Jan 26, 2010 | HP DeskJet 970cxi InkJet Printer
How do I connect printer HP 970 to a Laptop HP 8430 ? Which cable ? Thanks for your help.
You can connect this printer to your HP laptop using a USB printer cable, It will plug into one of your laptop's USB ports.
Oct 30, 2009 | HP DeskJet 970cxi InkJet Printer
Need instructions of how to print double sided on my hp deskjet 970cxi
Please open the Contorl Panel, go to Printer, Go to Preference of selcted printer.
Or the Properties of printer. There you will find on the General Tab, Print on both Side of page option, also known as DUPLEX.
Select it and then go for print.
Apr 28, 2009 | Apple HP DeskJet 970cxi InkJet Printer
The power light and the paper feed light are both on and the printer does nothing. It's a HP Deskjet 970 Cxi
you going to have to go inside the printer and check for loose cables on the main board. if all cables are ok , i suggest changing the main boar.
Apr 06, 2009 | HP DeskJet 970cxi InkJet Printer
HP Deskjet 970cxi
go to control panel, and look at the ports to make certain they are enabled..if not, remove them, then do a scan for hardware changes, and then try it again. I recommend you remove anything plugged into those ports while doing this.
check your computers warranty here 4 FREE
Mar 24, 2008 | HP DeskJet 970cxi InkJet Printer
Deskjet 970 unable to get test
ok...first...low color will do that blue effect..
and, you may need new drivers
remove old ones first
go here for fresh set
then reinstall
Feb 26, 2008 | HP DeskJet 970cxi InkJet Printer
HP DeskJet 970cxi InkJet Printer Logo
218 people viewed this question
Ben Johnson
