Question about Acer Aspire 5720-6661 Notebook PC
RE: Acer 5610z and Netgear wireless router. The wireless switch is on. But I still do not find any wireless connections. Not even the Netgear Rangemax. Says there are no connections within range. No matter how close to the router it is.
    Problem Solver:
  • 5 Answers
Your laptop may not be compatible with the n+ or you might have the security settings wrong try plugging your laptop directly in and try tweaking the setting there.
Posted on Jul 28, 2009
My laptop won't connect via wireless, and can't even find the network. It used to work fine until a few days ago. I have a netgear DG834G router
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
May 08, 2010 | NetGear DG834G 54 Mbps 802.11g Wireless...
I need the security key to my existing wireless netgear router.
The Security Key is normally used for Wireless routers to protect your connection from any unauthorized use. As you have said that you do not have the Security key for your router with you, the best way to connect your ACER laptop to the Netgear router is by asking your Wireless service provider to reset the security key & freshly reentering the same on both of your HP & ACER laptops.
Feb 06, 2010 | NetGear RP614 Router
I have an acer aspire 5610z laptop and cannot stay connected to wireless network...please help
try to restart the router and wait about 15 seconds and then make sure you have the correct we[ code to connect to it
Jul 04, 2009 | Computers & Internet
Can't get wireless connection
try locating the wireless switch of your new Acer. It might be accidentally turned off thats why no available wireless network found in range
Jun 11, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Can't connect to netgear wnr 2000
conect to netgear then shut down and turn it back on.
May 27, 2009 | Acer TravelMate 5520 Notebook
Problem connecting wireless to a Netgear MR314
Login to router and change the wireless channel on which the router is transmitting wireles signals.
Pretty old router that you have. Ugrade your router and stay tension free with the newer routers as they work fine and have low downtime.
May 16, 2009 | NetGear MR314 (MR314NA) Wireless Router
Do i need the cables for the router?
To go Wireless on your desktop Acer Aspire L3600, you should consider buying an USB Wireless Adapter. It could be any brand as long have same frequency with your Netgear (i.e 2.4 Ghz/5.8 Ghz)
P.S.: If this information was helpful, please rate this solution.
aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Apr 01, 2009 | NetGear DG834G Router
Home Network Problem with Netgear MR814 and Netgear FS105
Is your ReplayTV and Xbox configured to use DHCP? If not, you may need to configure static IP addresses for each of them.
Feb 17, 2009 | NetGear ProSafe FS105 5-Port Ethernet...
Problems connecting my laptop to wireless router
Make sure that you do the setup via cable, not through wireless!
If you change form WPA to WEP, the length of the key changes and you will have to provide this new key if you want to connect wireless to your router.
You can leave your laptop connected via cable and check if your wireless card can connect.
No, you don't have to reinstall everything again. Just plug in the cable, connect to your router (192.168.x.x) and check your wireless setup.
Dec 28, 2008 | NetGear WGR614 Wireless Router
Wireless connection of netgear wireless router for compaq laptop
Sometimes firewalls on your computers can cause connection issues. I had the same problem with my home network. I had norton internet security 2008 on both systems, but the firewall settings on both computers had to be adjusted to allow the computers to talk. If you have different brand firewalls on each computer, you should consider to switching one of the computers so that it matches the other.
Another thing you want to do is log into the router's web utility and check to see if the wireless settings are blocking wireless connections in some way. You also want to make sure the ssid broadcast is enabled.
Finally, you really should consider using security on your router, so wireless connections would be password protected. I suggest wpa personal.
May 03, 2008 | NetGear WGR614 Wireless Router
Acer Aspire 5720-6661 Notebook PC Logo
111 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
