Question about Motorola Mobility TracFone C139-4 Cellular Phone
How can i find my dead phone - Motorola Mobility TracFone C139-4 Cellular Phone
Phone startup failed problem
I have nokia7610 my problem is when i stat phone then phone start up faild contact reaitalier so please i want solution
Nov 17, 2010 | Nokia 7610
ON\OFF buton is not responding. The phone is
The power (On/Off) button is not responding probably because it is broken, the phone is dead, or the battery is dead or drained. Connect the phone to a charger and check whether the phone charges the battery or not. The power button is indeed not responding and broken when the phone charges the battery. The only way to turn on the phone is by replacing the power switch.
When the phone doesn't charge the battery, the phone may be dead or the battery is dead/drained. To revive the battery and verify whether the phone is dead or not, check it here.
Apr 06, 2010 | Nokia 6233 Cellular Phone
Cordless phone went dead
leave batt out for a long period of time,then replace
Nov 30, 2009 | Panasonic KX-TG2431 Cordless Phone
My phone is not coming back on
Re4asons for phone not coming on are: Dead battery or dead battery because of dead charger. Use the charger elsewhere to check if it is charging. If yes then use battery elsewhere to see if it has the required charge. If both are working fine then
A dead phone. Or does it show some signs of life like some LED flashing or blinking???? If yes then the phone is not dead yet. It requires reinstall of firmware. Please do that and the phone has a fair amount of chance of springing back to life.
While if there are no signs of life what so ever, then friend the phone may really be dead and can be used as a paper weight on your desk.
Nov 09, 2009 | Motorola Mobility V360 Cellular Phone
My phone will not turn on
Your phone could be suffering from: A dead battery. Replace it. A dead Charger not charging the battery, try a different charger to confirm. If dead replace. A faulty power on switch. You need to confirm and replace it. A dead phone (I hope not). If nothing works then the phone may be dead. Sometimes the connections snap with the slightest of jerks and the phone goes dead. You need to carry out the fault finding and rectify the fault. If it still does not come on then replace the phone. But in this order.
Nov 07, 2009 | Motorola Mobility Clutch i465 Cell Phone
Nokia 3120 dead
Ensure a fuly charged battery. If it does not work then take it to Nokia Care and let them check the poweron switch. If it is still dead, then let them check it thoroughly and then declare it dead. May be its firmware is corrupted and needs re-install. Incidently, there is a donation box at Nokia Care where you can donate your dead phone. Nokia will use whatever working parts the dead phones have.
Aug 26, 2009 | Nokia 3120 Cellular Phone
Nokia 6630
sorry but and?
your phone is dead,
we cant bring it back,
sorry
okay
check the battery
check the battery connectors
does the phone charge
try and put another battery of the same type in the phone
if that fails
yes your phone is dead
Jul 05, 2009 | Nokia N70 Cellular Phone
Motorola v635 dead
you have a software problem. take your phone for flashing. but if there was water damage, then the phone might be dead.
flashing the phone replaces the phone's firmware with new firmware, making the phone brand new
Jun 13, 2008 | Motorola Mobility V635 Cellular Phone
Cell phone dead
check the batteries..charge them and use it..may the battery must be worn out so replace the batteries...or only keypad lights are on and display is off then replace the display..an new display would b around 300 INR.
Apr 10, 2008 | Nokia 3310 Cellular Phone
Motorola Mobility TracFone C139-4 Cellular Phone Logo
1,297 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
