Question about HP CP3525N Color LaserJet Printer
Why black color smears when printing envelope but color prints fine?
  • dbucyk May 11, 2010
    What type of printer is it? Is it a laser, inkjet, or bubblejet printer?
    Brigadier General:
  • 4,090 Answers
Firstly are you using the cirrect cartridge ( genuine)? some compatible ones have less drying agent to help prevent clogging but take longer to dry.
Some papers are not suitable to laser printers, so ensure the paper you are using is recommended for use in a laser. This includes Photopaper
Posted on Jul 28, 2009
There are black ink blotches when I try to feed envelopes through the rear feeder
use the maintance function on your printer to adjust the ink output level.
Dec 21, 2012 | Brother New-MFCJ6710DW - MFC-J6710DW...
Ink is smudged on envelope. How do I stop that from happening?
i bet you're printing in Black,
what happens is when black is selected, the 3 colored drums lift up 2 mm annd only the K drum is engaged, amd there is no static in the transfer belt under the CMY drums.
envelopes have air in them and can bounce along the bely after the black has printed, and seeing the toner is powder and not yet fused on, the toner touches the cyan drum as the envelope hits the fuser entry point as well as dragging on the Left transfer belt Blue lift handle(take out the belt and spring the handle off).
If you open the lid in this print mode, and lift out the cyan drum, turn it over and pull back the cover for the OPC drum, you will see the black toner on the green drum.
FIX 1. In the art work place a tiny dot of yellow. this will run the print mode in color and enagage all the drums. gaurantee your print will be fine, and know one ever sees that yellow dot.Problem is, this then runs down your CMY drums for black only printing.
FIX2.
If you have a later machine, downlaod iQueue from Xante.com (free) fantastic software. and get the machine updated with the latest X1.11 firmware from your dealer.
This allows with iQueue, to set the machine to print Black only, and you run the machine without the CMY drums installed....it works, it's great...
Aug 10, 2010 | Xante Ilumina Digital Color Press Printer
Envelopes print in color and I want black only
First you need to change the settings in the software you are trying to print the envelope. Open the program (for example MS Word), go to the option from which you print envelopes and labels. Set the font color to black, not "automatic", and in Word, click "default", which sets the color as black rather than allowing the printer or its software to select the wrong color. Then try to print on the envelope and let us know if you are able to print the envelope in black only.
Apr 20, 2009 | Office Equipment & Supplies
Won't print envelopes in black
Apr 13, 2009 | Lexmark X4270 All-In-One InkJet Printer
Addresses on envelopes have begun smearing
clean all the feed rollers with a window cleaner, shoukld be fine then
canon tech
Mar 31, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Printing
Check on your color (not mono) ink levels. If they are low, this could cause this.
Technical info: On this printer, envelope text is printed in "composite black" which means we mix the colored inks to make black. This is done for envelopes and not letters because of the ink properties which resist water and smear. If one of the colors is low, you'll get something other than black.
Mar 24, 2009 | Lexmark Z53 Color InkJet Printer
Streaked & smeared printing on envelopes
Check area where the envelope is pulled into the unit. There may be some debris causing the ink to smear.
Sep 24, 2008 | HP OfficeJet 7310 All-In-One InkJet...
PIXMA 830 Smudges when printing envelopes
On my MP780, be careful to select the appropriate paper type; I was getting black smudges on the left side of my envelopes until I explicitly set that my paper type was "envelope" from "plain paper".
Another idea is to adjust the "ink drying wait time" to a higher level.
Dec 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
HP CP3525N Color LaserJet Printer Logo
188 people viewed this question
Seeker5211
Seeker5211
