Upgrade my Harddisk
I have four years old intel board D915GVWB. I want to upgrade my Hard disk 80Gb to 250 gb . can i do with out upgrade my drivers & BIOS?
    Sergeant:
    Novelist:
  • 192 Answers
No, unfortunately the BIOS will need to be flashed. If your system is about 4 years old, then you probably are using INT13 BIOS which will recognize about 137 GB.
The flash will allow the BIOS routine to read the larger hard drives, possibly up to a terabyte. Also, you will probably be able to use faster RAM, fix any bugs in the system BIOS, and possibly other features.
Do you know how to flash your system BIOS? If you don't contact me by posting a response. I'll tell you how to do it step by step.
Posted on Jul 28, 2009
Testimonial: "thank it is very useful"
    President:
  • 2,187 Answers
Yes you can. You only have to consider the type of drive that you have to purchase. If it is IDE, the wide flat wire or the SATA which has a narrow flat wire. Make sure you get the same type.
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
I am using a toshiba portege m400 and try to upgrade harddisk to 250 gb while installiing windows 7 hard disk is not detected.
maybe its not compatible to the laptop the hard disk that you purchase try replacing it with lower capacity hard drive then reinstall the windows 7 again
Aug 07, 2011 | SIB 250GB 2.5" SATA HDD Hard Disk Drive...
Iam having p3 proceessor,133mhz, 810e chipset, motherboard,512mb sd ram,80gb seagate harddisk. iwant to upgrade my harddisk like 160 gb or 250 gb. is it compatible with this configuration. ...
You can put a 160gb on it as is with no trouble, but should add ram to at least 1 gig to make better use of your system. Hope this helps:)
Aug 24, 2010 | Computers & Internet
How much Hard disk my motherboard D845GVSR will support.
There's not really a limit to how big a harddisk you can support. The only thing that can restrict you is the connection, because, for obvious reasons, you can't connect a SATA disk to an old IDE board, but it seems like you're aware of that.
You can just buy any SATA HDD you want!
May 13, 2009 | Intel D845GVSR Motherboard
Regarding hard disk updation
you need to buy a new harddisk with much more capacity.but for the drivers, it can be downloaded
May 08, 2009 | Intel D845GVSR Motherboard
Maximum hard disk support
this hard drive size will work with your motherboard but the problem is the size will be detected only up to 130 GB or less, so if you will be using that size of hard drive you will just waste it.. so better use a 120 GB of hard drive or upgrade your motherboard so you can use a 250 GB.....
Hope that helps.............
Sep 01, 2008 | Computers & Internet
250gb sata hard disk to 845 glad mother board
Hello all. I have the same issue. My MB is 845G [P4 2.4 Ghz] and SATA harddisk I need to install is Seagate 250 GB Baracuda with 3.0Gb/s interface, I belive which makes this HD as SATA II. So for this motherboard should I prefer PCI cards which support SATA II over the supports SATA I [these are cheaper].
Thanks so mcuh!!!
May 12, 2008 | Computers & Internet
How much big HDD can i connect to my ASUS-CUBX-L motherboard?
The size of the drive that will be detected can vary on a number of things: bios version, and OS.
They will both "physically" work, but the full capacity may not be "seen".
The 160 should work fine, but the 320 may only "show" as a 250 or 300.
My best advice is to flash the bios to the latest, and start with the 160. Install your OS, and connect the 320 as a slave after the OS install, and check its properties.
Jan 08, 2008 | ASUS Intel 440BX Chipset CUBX-L...
Cpu upgrade
You can upgrade your pc to intel chipset original motherboard...and do it to intel core 2 duo processor. if u want to upgrade ur ram then go for 1GB ram... and 250 GB hard disk and finally go for pentium-IV and dvd writter... and use microsoft mouse and keyboard bcoz it does not require driver to be installed
Oct 01, 2007 | IBM I System Board (61H2600) Motherboard
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
