SOURCE: John Deere LT155 Lawn Tractor has trouble going uphill
u can change belt yourself need belt size and have to remove cutting deck but check belt tension first if loose with brake off belt stretched out and slipping needs replacement
SOURCE: my ariens 824 wont go forward or reverse
I would check your traction drive disc for wear or shredding.With low or little fuel in tank you can safely grab handle bars and lift machine up on it's auger housing.Then remove shield from under machine and inspect metal disc with rubber around it.If rubber looks worn you can get a replacement traction drive disc easily from most small engine repair shop's or go online and look for your nearest Ariens dealer.
SOURCE: Loss of drive in a Craftsman Lawn tractor
I also have a Craftsman tractor with the same problem. Sears repairman said it needed a new transmission and it would cost $1,400 to install. A new one is about $1,000. Anyway, if you remove the battery and the battery tray under the seat it will expose the transmission fill hole (hex). I opened the top and it looked empty. I had a bottle of 90 weight gear oil in my shop and filled the transmission to the top. I have not had any problems with it since. $4.00 bottle of oil verses a new tractor is worth a try.
SOURCE: ariens ezr 1742 will not move
There is one common problen that causes this. Infront of the rear wheels there are two housings for the indepentent hydrostatic transmissions. There is one gold colored shaft with a ninety degree angle on it sticking out from EACH of the housings on the top front. Again these are on both sides and they each need to be pushed downward so that the rods can then be pushed backward into the transmissions to inguage them so both of the wheels are powered. Give this a try.
