Question about Canon Office Equipment & Supplies
Error 002,turn off n open again - Canon Office Equipment & Supplies
    Problem Solver:
  • 19 Answers
Do the rested in machine
Posted on Jul 28, 2009
OKI c6150 with error msg 002-fatal error. please, I need a quick answer. do not have time to scroll through pages of older posts
If you printer has an additional memory card fitted then remove it (powered off of course) and turn on and see what happens. If the fatal error is still there then with the age of the machine (getting on in years) it is better to replace it as the error refers to the cpu in the control board and that's expensive on older machines to replace.
Jun 20, 2016 | OKI C Office Equipment & Supplies
Canon imageclass mf4412 turn on power supply E-202-0002 error solusation
for canon mfp4412 e202-002 error
turn off printer
open scanner
check scanner is working or making noise
if it making noise check scanner flat cable on formator boad side or replace cable
Dec 03, 2012 | Office Equipment & Supplies
Canon ir 3300 error code E000805-002
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Canon&model=iR3300&code=E003-0000
Oct 22, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Could you tell me what error code 003 is for a zanussi zbd 903 built in double oven
This code is displayed when the user attempts to restart the appliance after an
error code 001 or 002
- Safety circuit malfunction
001 if the meat probe is open circuit or the temp of the food is over 100deg c
002 is if the meat probe is short(closed) circuit hope this helps
Jul 11, 2010 | Zanussi Ovens
E002 and e004 are the errors
E 002 & E 004 is malfuntion the fuser unit.
E 002 : check TH1 termistor,H1 & H2 heater lamp and the thermofuse termostat.
E004 : SSR malfunction.
Aug 01, 2009 | Canon Office Equipment & Supplies
E000001 002 ERROR CODE, HOW DO I CLEAR IT ?
Problem should be checked out by a technician as clearing the error is not going to make a problem go away if it's there (although to you it may appear as if it is), but if you must. You can go into Service Mode (Additional Functions > 2,8 > Additional Functions), Copier > Function > Clear > ERR. Select the ERR to highlight then turn copier on and off using main power switch (on right hand side of copier. Wait 10 secs or so before turning back on).
May 11, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Error code E00012-002
If I recall correctly, e12 is a jam code. Power the unit off and look in user serviceable areas for paper bits. inspect sensors for paper bits. reseat external finisher unit. power back on. you may have a bad paper sensor in the unit.
Feb 19, 2009 | Canon imageRUNNER 2200
Error 002 with Canon image class MF 8180 C
I usually open the back cover, top cover, cartridge cover and pull out the paper tray. Sometimes this clears the alarm, if this does not clear the alarm, I unplug the printer for a couple minutes. Between opening and closing the covers and unpluging the printer, the alarm goes away. Ray
Dec 30, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Fatal error 002
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
Take the printer off the network. (Remove the network cable) Then enter the menu and select network menu. You want to change the settings as described below:
Change the Hublink Setting to "100 base tx full"
Change the FTP Setting to "Disable"
Once done and machine says online, shut it off, reattach the network cable and restart the printer.
You may also want to change the printer's IP address.
If this does not help, or you cannot get past the 002 fatal error then the machine will require service.
Aug 08, 2008 | OKI C5200n Laser Printer
old marine
old marine
