V Communications 7500 Answering Machine Logo
Ted Nitu Posted on Jul 28, 2009
To turn on an answering machine
From a remote phone I press 0 and turned the answring machine off.
Is tehre any way to have the machine answr again ( turned it it on ) ?
Thanks.
Anonymous
Level 1:
  • Contributor 57 Answers
  • Posted on Jul 28, 2009
Anonymous
Contributor
Level 1:
Answers
57
Questions
Helped
38875
Points
97
Of course there is you just need to unplug all of the cords [ power off]. and then plug them all back in and it should reset its self
Phone 29893ge1
You may view/download the manual at http://www.fixya.com/support/p474402-ge_29385ge1_call_waiting_caller_id/usermanual-70D20F8-pdf
"Rings to Answer" is on page 12. "Time and Date" begins on page 9.
Setting the number of rings before answering machine kicks in
Here is the link to the user manual; http://service.us.panasonic.com/OPERMANPDF/KXTC1501B.PDF Check page 19 - you can set the answer rings from 2 to 7 Hope this helps :)
My I phon 4 touch screen will not allow me to unlock to answr. I have to use my headset to answer the phone//// but it allows me to end the call by touching the screen
If it's a bluetooth headset you talking about. That's how it's designed. So you don't have to "find" the phone to answer it. That's the whole idea behind "Hands free".
1helpful
Code to retrieve messages
Here are the instructions you need to follow:
If you want to be able to play your messages from a remote location, you need to enter a two-digit Personal Identification Number (PIN) code (01-99).
To select a PIN, perform the following steps:
1) With the phone in standby, press [menu/clock] twice.
The system announces "Security code," and the current PIN code is announced as it is displayed on the base.
Then the system announces the instructions for setting the PIN code.
2) Press [volume/select/ ] or [volume/select/ ] until the desired number appears.
3) Press [set] to select the PIN code. You hear a confirmation tone, then the announcement "Security code" followed by the new PIN code is announced. After a few seconds, the system announces "To set ring time, press menu again."
Note: The PIN code is set to "80" at the factory.
Remote Operation
When you are away from home, you can operate your answering machine with any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even record a new greeting message.
1) Call your telephone number.
2) During the greeting message, press [0] and enter your PIN code
3) The answering machine announces the current time and the number of messages stored in memory. Then you hear "To play incoming message, press zero two. For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command from the following chart:
Command Function Command Function
[0] then [1] Repeat a Message [0] then [6] Answering Machine On
[0] then [2] Play Incoming Messages [0] then [7] Memo Record/Stop*
[0] then [3] Skip a Message [0] then [8] Greeting Message Record/Stop*
[0] then [4] Delete a Message [0] then [9] Answering Machine Off
[0] then [5] Stop Operation [1] then [0] Voice Prompts
* For Memo Record and Greeting Message Record functions, the first time you enter the corresponding command, it
starts the Recording function. If you want to stop the recording, enter the command again.
Note: Once you enter the remote access menu, you must enter a command within 15 seconds, or the
answering machine automatically hangs up and returns to standby.
5) After all of the voice prompts have been played, you hear intermittent beeps indicating that the system is in the
command waiting mode. You may enter another command at this time from the chart.
6) When you are finished, hang up to exit the system. The answering machine automatically returns to standby.
Turn on the Answering Machine Remotely
If you have forgotten to turn on your answering machine, you can turn it on remotely from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press [0] and then enter your PIN code. The answering machine announces the number of messages stored in memory. You hear "To play incoming message, press zero two. For help, press one zero."
4) Press [0] then [6] to turn the answering machine On. You hear the outgoing message and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
ANSWER MACHINE ON MD760 NOT WORKING-DISPLAY SHOWS ''DASHES''
I feel soooo stupid...I guess somehow when I was retrieving my msgs remotely, the answer machine got turned off. I just pressed the on button & the "0" appeared again. But I never touch that button so don't know how the machine got turned off. Thanks anyway. But why is there no phone # to get a live person like there used to be???
2helpful
Auto answer mode and lights
i 2 use d same mdl dude i dnt thnk so is thr any option 2 turn off d lights is default assignd. bt auto answr mode its v smpl. go to user profile select ur headset profile thr u can find auto answr option unmark it. thats it
Phone keeps turning on the answering machine all by itself.
figure out how many times it takes for your phones answering machine to automatically turn on, then call your phone company and have them limit the number of times your phone rings. like say at 14 rings if it auto answers at 15 rings.
Picking up messages remotely
Try this...
See if this works for you.
Remote Operation
When you are away from home, you can operate your answering system with any
touch-tone telephone.Use this function to check for recorded messages, to play or
2) During the greeting message, press 0 and enter your PIN code.
3) The answering system announces the current time and the number of messages
Command Function
0 then 1 Repeat a Message
0 then 2 Play Incoming Messages
0 then 3 Skip a Message
0 then 4 Delete a Message
0 then 5 Stop Operation
0 then 6 Answering System On
0 then 7 Memo Record/Stop*
0 then 8 Greeting Message Record/Stop*
0 then 9 Answering System Off
1 then 0 Voice Prompts
If you forgot to turn on answering system the directions for that are here:
Turn on the Answering System Remotely
If you have forgotten to turn on your answering system, you can turn it on remotely
3) Press 0 and then enter your PIN code. The answering system announces the
4) Press 0 then 6 to turn the answering system On. You hear the outgoing message
Top V Communications Lands Phones Experts
k24674
Are you a V Communications Lands Phone Expert? Answer questions, earn points and help others
