Question about Canon PowerShot A40 Digital Camera
On record picture smeared like massively over exposed
On record picture smeared like massively overexposed. It happend suddenly after I took a pic. thro the window at night could the flash have reflected and damaged the pic.receptor device.I have re-formatted the mem.card 4 times,removed and recharged the battery, let it sit for about 10 days incase it may have picked up moisture I did take a pic. also from the front door of a hail storm ,it never got wet at any time? IXUS 500
Regards
Maxwell
mecla@adam.com.au
    Brigadier General:
  • 4,090 Answers
Make sure the ISO is set on the correct exposure for daylight.. try say 100 or 200 if its set for flash at say 60 nor 30 and you try to use it in brighter or daylight it will overexpose.
Posted on Jul 28, 2009
Camera makes overexposed pictures wiht lines can this be a software problem ?
Nope, this is a hardware problem and the camera needs to be worked on. Notice how your display works fine but the finished product exhibits the anomaly. The recording end is messed up.
Aug 12, 2015 | Panasonic Lumix DMC-TZ7 Digital Camera
Suddenly my Canon PowerShot450 makes white pics
Either aperture ring is jammed or CCD is bad.
Needs service.
May 26, 2010 | Canon PowerShot A450 Digital Camera
Finepix E550 -suddenly very grainy photos and over exposed?
Have you checked what ISO you have selected here?
Graininess and over exposure can be caused by selecting the wrong ISO ( which in film days was ASA ( film speed) The average ISO should be 100 some early models allowed ISO 64 or similar. Having it set at 400 -800 ISO can also have the pics come out grainy. But not nescessarily overexposed unless you point directly at the light source as these ratings are for low light/movement situations. The video mode usually sets itself up differently to picture mode. The fact that you say your video is OK says there is nothing wrong with the lens or sensor, just the settings you have initially chosen to have autoed.
Please rate our help to keep thye service online++++Thanks for using FIXYA
Sep 19, 2009 | Fuji FinePix E550 Digital Camera
Some of my pics come out every white how do i fix that .when i take pics they come out very white but all of them do that.
If they are white that means they are getting over exposed. You may have your camera in a manual mode that is set to overexpose the pictures. You can set it in an automatic mode to take care of this. The other possibility is that you have a exposure adustment that can be set at either + for brighter or - for darker. It should be set at 0. Sometimes this is a EF option on the camera. Hopefully this helps.
Jul 16, 2009 | Sakar 90379 Digital Camera
Overexposed Results
sorry to say my friend if all settings are correct and normal as u took pics in past with the same settings
the CCD Imaging chip is gettin faulty it starts like these symptoms first over exposed then pink purple shades and blurry pics , scrathces on pics and then completely off u have to get it replaced thru service centre in ur area but there is a strong chance u can get free repairs from Sony bcoz it is a known problem in various models
see this link for ur problem and help
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
http://eservice.sony.com/webrma/web/index.do
Mar 12, 2009 | Sony Cybershot DSC-T200 Digital Camera
Fuji s5000 overexposing pictures
try setting it to auto mode and see if it is ok
otherwise
they are not over exposed actually they have CCD HR problem ur CCD is having fault as 1000's have the same fault u will get pink shades in white and then later it will stop working u have to arrange for ccd change go to fuji service centre
Feb 19, 2009 | Fuji FinePix S5000 Digital Camera
Nikkor 50 1.8 overexposes
You probably have oils on the aperture blades and they do not close to the F stop you set as quickly as required, thus causing the over exposure. Easy to pinpoint: sent the aperture to full open (F1.8) and use appropriate shutter speeds as determined by the camera (in manual mode), if the picture does not over expose, then the problem is with the oiled contaminated aperture blades. Have it cleaned.
Feb 12, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Background is overexposed
So, the problem doesn't seem to be the flash if the actual subject in the foreground is exposed properly. My guess is that the background is being lit by another light source. Typically, your camera uses a flash for dark areas or what it gauges as a dark area. This doesn't adjust the background for additional light sources. For example, if you're standing outside and there's a tree covering someone that you're taking a picture of your flash will adjust to "properly" light that individual. However, because the flash was used for the main subject, the background is actually now overexposed. The overexposed background will show up as a brightly lit area because the camera had to adjust for the foreground. This will actually reverse itself when it's dark out - meaning if the background and foreground are dark, the flash will expose the foreground, but the background will be black. Hopefully, that helps you understand lighting and exposure. Now, to fix this problem when shooting, you would need to consider several options - 1. SLR camera with aperture and f-stop settings as well as compensation controls. This will allow you to control every element of the exposure, but you still need to be aware of the lighting behind the "subject" to properly expose your shots. 2. backlighting compensation - common settings on both SLR and point and shoot cameras that makes auto lighting conversions for backlighting and other common lighting issues. Test whatever options are on your camera to see what works best for your specific problem. 3. Photoshop retouching - you may take one shot with your subject exposed properly and a second shot with the background then merge the images together. 4. using a tripod to shoot without using the flash - this may give you the closest exposure to exactly what you see when looking at your subject.
Dec 19, 2008 | Polaroid i733LP Digital Camera
All white pic is shown on LCD when used in Manual Mode with delayed shutter timer
You are massively overexposing the picture. Manual mode means you have to set the exposure manually. You need to adjust the settings so that the light meter reads somewhere around the zero mark.
M mode is most useful for flash photography where you want a certain level of ambient illumination in the picture as well.
If you want some control over the camera but don't want to worry about exposure too much, use A and S modes. The manual will explain all of these modes.
Aug 31, 2008 | Nikon D40x Digital Camera
Overexposed
try it in auto mode if it is the same condition do u feel change in color like white turning pink or purple or sort of over exposed pics as u said then i worry that ur CCD HR is going to faulty in coming days later on pics will get pink and purple and then ccd stops working completely , i hope this is not the case do let me know if i can help u
Jan 07, 2008 | Fuji FinePix S1 Pro Digital Camera
Canon PowerShot A40 Digital Camera Logo
110 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
