Question about Juki TL-98Q
I have the Jukie 98Q. Problem with needle
I have the Jukie 98Q and problem with needle breakage. After inserting needle I check to be sure needle clears the plate and is in tight. After stiching for awhile needle starts hitting the plate. Machine is dedicated to quilting frame. Can the vibration from stitching cause the needle to shift.
Ok Ladies I think I have another solution. I just spent 7 hours unpicking the loopy thread on 4 rows of my quilt. I tried again and it did it again. so I got that scrap piece of quilt sandwich and started testing. (I was a machinest for 10 years and was gonna figure this **** out) I did all the typical things that have been suggested.
1-Check to see if it's threaded Right
2-Check the upper thread tension
3-Change the needle
4-Check the bobbin tension
5-Use silicon on a sponge and have the thread drag thru it.
6-??? #5 helped me figure out my problem. as your threading your machine... when you get to the last stationary loop before you go down to the loop on the needle shaft...... Mine was jumping out of that thing enuff that even tho it looked like it was threaded thru there is WASN"T!!!! so as you r going along it shreading itself on the out side and that where those dang loops on the under side come from.. then it just breaks.
SOLUTION--- 1st I opened the door that covers the light and you can see a tiny screw that holds that particular loop in place. If you losen it just enuff you will notice it will swivel some. Mine was laying back against the body of the machine so I tipped it up as far as it would go and tightened it. Then I began to sew some more. Seamed to work and then WALLA out again.
2nd you know thos type of paper clips that are like jaws but if you flip their little handles over they will lay against your paper??? I got a tiny one of those and clipped it in such a way that the thread is untouched but it can't get out of that loop any more. Time to chage the thread? Remove the paper clip change the thread and put the clip back. Hows that!!! Need a picture email me at jamesie7@msn.com Carol
Posted on Jan 14, 2010
  • 4 Answers
I am having the same problem. I think either the thread gets caught around the bobbin or the cloth is pulling the needle over to the plate, like the hole is too small for these shifts. I bought a "hand made" quilt from the store a few years ago and thought I'd add more quilting to it for fun. I have gone through over 30 needles on it. I'm going to try oiling it and I'll post it if that works, if not I'll post something when I find the solution. Oh, the heavier duty needles (jeans/leather) last the longest.
Posted on Jul 29, 2009
  • bflysmile Aug 21, 2009
    I oiled the machine around the bobbin (where it tells you to in the instructions) and have not had another needle break and have finished 1.5 quilts. (Since the oil was out I also oiled the other areas as well.)
I have a consequent rb5 , bobbin thread is not feeding top thread, also needle keeps breaking off
First make sure you are putting in needle correctly, it has a flat side.
Insert a new needle into your sewing machine with the flat side away from you. Push the needle into the clamp until it touches the pin (a) and stops. Firmly tighten needle clamp screw with the screw driver.
if you find all the thread bunched up then look at your thread not being routed through all the the locations. Go slow and retread from beginning.
Oct 26, 2016 | Sewing Machines
I have a Juki TL-98Q The thread cutter and the needle up down button don't work. How can I fix them?
Has a piece of broken needle or chunk of thread jammed into the blades and are not letting them move? If there was a big time thread jam it can actually break one of your blades and you will have to go to a repair man and have the blade replaced.
Jan 09, 2016 | Juki TL-98Q
Service manual is there one to download? juki tl
Yes, I think you just go to the website. Although I have one but it does not help much with thread and needle breakage except that the hook and loop probably need to be adjusted by a pro.
Aug 05, 2013 | Sewing Machines
Jukie serger skipping stitches
have you tried changing the needles?
if you have changed the needles & it's still skipping stitches the serger needs to be serviced
Apr 16, 2012 | Sewing Machines
MY BROTHER MACHINE NO. LS-2125i THREAD BREAKING WHEN SEWING?
Thread brekage can be caused by several things but start simple by taking off the needle plate then thoroughly clean the sewing mechanism and add a few drops of oil, then check the threading is correct. replace the needle. Always use quality threads and make sure that the thread is not to heavy for the size of the needle (it should pass easily through the needles eye). check that the needle hole in the plate is not bent or damaged and peppered with needle marks, a damaged plate will cause many problems. Finally, make sure that the tensions are not too tight this can be a major cause of thread breakage especially if poor quality thread is used. ( check thread by breaking it by hand, it should offer good resistance to breakage, if it breaks easily then discard it. hope this is useful, best of luck.
Apr 14, 2010 | Sewing Machines
Juki TL98Q needle thread breakage
your bobbin it is not in his right position, quit tightin your tension.
Sep 29, 2009 | Juki TL-98Q
The top thread keep breaking. should the tension
Thread breakage is usually due to the needle in backwards, upper tension too tight or old/weak thread.
When replacing the needle, make sure that the flat side is to the right (3 o'clock position) and is pushed all of the way up before tightening.
What brand and weight of thread are you using and are you sewing with the foot or free motion sewing?
Jun 17, 2009 | Juki TL-98Q
Needle thread breaks while quilting on machine frame
My friend and I both have the Juki 98Q but on different frames - we were both having problems (needles breaking, thread getting tangled) we removed the thin metal thing inside the bobbin case and have had no problems since (over a year now!).
Nov 01, 2008 | Juki TL-98Q
Juki TL-98Q Logo
170 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
Derek Massey
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
