Question about Panasonic PT-43LC14 43" Rear Projection HDTV
Air Filter Waring for Panasonic PT-43LC14
How do you reset the air filter warning. I heard there is a code using you remote control to do this. A warining for air filter cleaning comes up and then turns off my TV. I have called Panasonic and they say there is no filter. Please help
  • 1 more comment
  • kishor soni Nov 22, 2007
    veb cem prblm
  • markz Dec 19, 2007
    I have the same problem with mine. It will run for about 1 minute then shut off.
  • Anonymous Mar 01, 2008
    My pt-43lc14 air filter light came on, so i went to pans web site for auth service center. Had 1 in my area. Talked to them, they said they never heard of this and was aware of no filter. They said a good cleaning at about $180 might help. I purchased some compressed air in a can, took the back panel off, cleaned everthing I could get to. then did near the bulb. I then left the tv unplugged overnight for hard reset. So far no problems (2 months later). Never found a filter!
I received the Air filter warning twice. I removed the back panel and used a HEPA (Shopvac) vacuum to clean the exbosed back and removed the sanp panel and cleaned the front. I did not remove the front bulb panel underneath the snap cover. Never found a filter and I have this model number. The warning has not come back so far.
Posted on Apr 26, 2008
    Genius:
  • 1,030 Answers
This may be a temperature issue there is a thermal sensor that tell the tv its to hot and need air so it think its filte is cloged. make sure there is plenty of clearance for air flow.. however there may be more involved problem with the set ... the sensor could be failing
Posted on Feb 22, 2008
2 Suggested Answers
  • 489 Answers
SOURCE: Air Filter Waring for Panasonic PT-43LC14
you have manuel ?
Posted on May 31, 2009
Clean filter message reset
the filter will need to be cleaned and if the set still shuts down then I would suspect the fan may need to be cleaned and possibly replaced.
Aug 07, 2012 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic PT-43LC14; I changed the lamp. I still get the lamp meter warning on the screen when I turn on the TV. How do I reset the lamp meter?
terayamam001,
Here is the procedure,
1. Turn on the television
2. Press the volume down button on the TV display (not the remote)
3. While pressing the volume button, press the "split" or " PIP" button on the remote.
This should solve your problem.
Thanks for using FixYa and for the great rating!!
hardrocko
Sep 12, 2010 | Panasonic PT-43LC14 43" Rear Projection...
Resetting the lamp timer for my Panasonic
You need the original remote to reset the lamp. Try to find a neighbor with a similar tv or buy one off ebay.
Mar 05, 2010 | Panasonic PT-43LC14 43" Rear Projection...
Lamp reset on a panasonic model pt-50lc14-k
This works for mos Panasonics
Turn on Power
Pres and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
Nov 12, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Temp light flashing and air filter message
there are 2 cooling fans one or both of them may need replaced,
Jan 20, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Air filter dirty
It means the Fan is dirty clean off dirt so fan can run,or fan might be bad. More then likely fan has alot of Dust Bunnys.
Dec 01, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Reset lamp meter on Panasonic PT-43LC14 television
While TV is on, simultaneously press and hold both the TV's Volume Down button and the remote's PP/Play button for 7 seconds.
Jun 03, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Air filter
Is your set under warranty? If not, bite the bullet now and get the service manual - you will need it sooner or later.
Whether there is a way to reset the warning or not, a solution is needed for the problem of restricted airflow and you will need to take off teh back panel and blow out the dust using compressed air and while your in there, look for any filters in front of the fans.
Nov 23, 2007 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic PT-43LC14 43" Rear Projection HDTV Logo
1,573 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
