Question about Canon MP140 PHOTO AIO All-In-One InkJet Printer
Got PIV with XP, only LPT not USB
I got an Canon MP140 series Printer I´m trying to install with my old P4 with Windows XP. Cannot install as it only recognizes LPT port and not USB. What can I do? Thanks!
    President:
  • 1,335 Answers
There are a couple of options.
The easiest is to add a USB board to your P4 assuming you have a spare slot.
The second option is to use a USB-to-Parallel cable, USB-F/USB-Fadapter, and USB-to-Printer cable. It would probably be cheaper to put in a USB card.
Posted on Jul 28, 2009
How to install mp140 printer to windows xp loptap
Here is how to install your canon MP-140 printer.
Click here to download the driver for windows XP. Click here for step by step instruction to set up your printer. And here is the quick guide on how to use your printer, click on the link.
I hope this will be able to help you out on your printer.
Thank you for choosing Fixya
Mar 16, 2011 | Computers & Internet
How can I make my canon mp140 wireless? I have a BT home hub on a secure network and it has a USB port, Is is possible to make this printer have some sort of wirless capabilities so i canb print from...
Its not an offical part of the homehub, but connect the MP140 and the HomeHub by USB, then on the computer you need to tell the PC that the printer is attached to the homehub rather than the PC. So on windows, start the add new printer wizard, and follow the steps on http://www.wallaceit.co.uk/Hardware/BT-Home-Hub---Use-it-as-a-print-server---Windows-XP-guide/80/article.aspx
Dec 11, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
How to install canon printer MP140 without a disk
You can download the drivers and software for your printer from CANON:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=15294
Click on the "Drivers and Downloads" tab and then select you OS.
Aug 18, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Hi, I have brand new Canon MP140 3 in 1. I am getting the error message &cannot communicate with scanner. Cable may be disconnected or scanner may be turned off. Check status. scanner driver will be...
1. If you are connected correctly (via a USB cable), first be certain that the cable is snug on both sides (PC and Canon MP140).
2. If still a problem, remove the Canon MP140 icon from Printers and Faxes.
3. Then, disconnect the USB cable.
4. Restart your PC and log into Windows.
5. Connect the USB cable.
6. The PC should recognize the Canon MP130 and ask for a driver.
7. Install the driver.
If #6 does not happen, your USB cable could be faulty or may be a problem with USB port or your Canon. Move USB cable to a different USB port on the PC. Replace the USB cable. Try to install the Canon on a different PC to test.
Hope this helps.
Aug 11, 2009 | Panda ANTIVIRUS ED PLT 7.0 1YR 26-50...
I did reformat my laptop and unfortunately i lost my canon mp140 cd.. can you please help me and find one so i can download to my laptop and can use again my canon pixma mp140
If you do not have the software, you need to download the software from one of the following locations:
Official Canon Drivers and Software
Canon USA:DRIVER & DOWNLOADS
After downloading is finished, unplug the printer USB and run the software that you downloaded.
The software installer will tell you when to connect USB.
Apr 25, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
I HAVE CANON MP140 AND WINDOW VISTA. NO QUALITY FOR COLOUR PRINTS
IT MAY BCOZ , THE CATREDGE GET DRY.....
SOLN
1. TAKE THE PRINTERS AND FAXES FROM CONTROL PANEL, TAKE THE PROPERTIES OF
THE PRINTER, SELECT THE HIGH QUALITY PRINTING FROM PRINTING PREFERENCES
2. POUR SOME SPIRIT ON THE HEAD OF THE CATREDGE ...
Oct 06, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
What does disabling bidirectional support mean
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} USB to Parallel conversion requires translation by XP and Vista's 'hardware interleave' software as well as the USB device manufacturers driver. The software package just doesn't work well with older peripherals that use legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many complaints about USB to Parallel or Legacy Serial adapters. Printing is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista, and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5 Mbps.
The BJC-80 and the BJC-85 have the same print speed. The BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps. Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR port, the XP print spooler has problems with it, and can hang if printing more than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6 than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers, and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port number.
Install the printer manually from the list of printers, and select the proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the adapter card driver may reinstall, and assign the next available LPT port, LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridge within XP or Vista.
Within Vista, set the Canon ISScan software to run in Windows 98 compatibility mode, to allow use of the TWAIN driver.
Jun 12, 2008 | Canon BJC 80 InkJet Printer
Canon BJC 2000 question-1284 to usb
TIPS:
Jun 05, 2008 | Canon BJC 80 InkJet Printer
BJC 80 Won't Print
Try disable bidirectional support
Jun 02, 2008 | Canon BJC 80 InkJet Printer
Time consuming
Try installing the latest driver: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=230&modelid=7998
Aug 23, 2007 | Canon BJC 80 InkJet Printer
Canon MP140 PHOTO AIO All-In-One InkJet Printer Logo
65 people viewed this question
old marine
old marine
