Question about Kenmore 88752 Top Load Stacked Washer / Dryer
Washer fills up only when dryer is running but doesn't begin cycl
Model 11520, gotten off of the top of the timer unit.
This just began. I was drying a pair of sneakers - with a bunch of towels - in the dryer. I know now this is a no no. The sneakers caught the wing of the dryer and the dryer stopped. I removed the sneakers. The dryer would not start right away but did start several minutes later.
The dryer still gets warm.
However, the next time I tried to do a wash, nothing. It was only by accident that I learned the barrel would fill only if the dryer was running. I tried a cycle with low water while the dryer was running. The barrel filled but the wash cycle would not begin. It wouldn't move in "spin" either.
  • 7 more comments
  • bobby3d Jul 29, 2009
    First off, I got that Model number wrong. It's not the model number for the machine. Secondly, if it was the agitator, seems like I would hear the motor turning or trying to and there's nothing. Why does the barrel only fill when the dryer is on? Could the short stop of the dryer have done anything to make that happen?
    I took off the timer mechanism (2 screws and a harness). I wish there was a way to test it. It works on load (pulling the know out) but the timer doesn't move or click in any other mode, like on spin, with the lid closed.
    Would a broken timer allow water in the barrel once the knob is pulled back?
  • bobby3d Jul 30, 2009
    Washer fills up only when dryer is running but doesn't begin. This just began. I was drying a pair of sneakers - with a bunch of towels - in the dryer. I know now this is a no no. The sneakers caught the wing of the dryer and the dryer stopped. I removed the sneakers. The dryer would not start right away but did start several minutes later. The dryer still gets warm. However, the next time I tried to do a wash, nothing. The separate washer control would not water load or make the barrel move in any position. It was only by accident that I learned the barrel would fill only if the dryer was running. I tried a cycle with low water while the dryer was running. The barrel filled but the wash cycle would not begin. The timer would not move. It wouldn't move in "spin" either.
    Comments:
    Jul 29, 2009 - First off, if it was the agitator, seems like I would hear the motor turning or trying to and there's nothing. Why does the barrel only fill when the dryer is on? Could the short stop of the dryer have done anything to make that happen?
    Jul 29, 2009 - Would a broken timer allow water in the barrel once the knob is pulled back?
    Solution #1 posted on Jul 28, 2009
    greg_margo
    Rank: Guru
    Rating: 89.48% , 372 votes
    It sounds like the agitator got loose or stripped. Try to tighten the agitator (it may be held down by a wingnut that can be tightened by hand, if not a pair of pliers). It's important not to overtighten the agitator or it will become bound up and not turn at all. Most washers have some "give" built into them for just the type of mishap you experienced.
    Comments:
    Jul 29, 2009 - If the timer isn't moving at all, or stopping short of the rinse cycle or spin cycle, it's broken and needs replacement. It just seemed less likely given the description of your problem but yes, a timer that stops prior to finishing the wash would most definitely be the cause for your washer to stop midway through the cycle.Jul 29, 2009 - Not sure what model you have so I can't tell if the timer controls both the washer and dryer or if you have independant timers. It's a first for me to hear a washer only working when the dryer is on. If they have independant timers, you may well have a short somewhere.
    Jul 29, 2009 - If the timer has a broken tooth in it, preventing it from running the whole cycle, it's very possible for it to start the wash, let the tub fill with water, and then quit. It's very common with the push/pull knobs that take a beating over time for the spindle to get stripped or a tooth get broken on the inside.
    Why will the water fill only if the dryer is on. If the pull knob loads water by electrically (and not mechanically) talking to the water valve, doesn't that mean that the wholo timer is receiving electricity? Is there a way to test the timer. A parts place said it would probably cost betw $75 and $100 for the part.
    Following is the history. Let me add that I've bought a used timer off of ebay yesterday and will try it out. The last expert who answered me suggested that a wire was out or that I hooked it back wrong. That ignores my history so I'm asking for another expert. Following is the history with my first expert:
    This just began. I was drying a pair of sneakers - with a bunch of towels - in the dryer. I know now this is a no no. The sneakers caught the wing of the dryer and the dryer stopped. I removed the sneakers. The dryer would not start right away but did start several minutes later. The dryer still gets warm. However, the next time I tried to do a wash, nothing. It was only by accident that I learned the barrel would fill only if the dryer was running. I tried a cycle with low water while the dryer was running. The barrel filled but the wash cycle would not begin. It wouldn't move in "spin" either.
    greg_margo
    Rank: Guru
    Comments:
    Jul 29, 2009
    If it was the agitator, seems like I would hear the motor turning or trying to and there's nothing. Why does the barrel only fill when the dryer is on? Could the short stop of the dryer have done anything to make that happen?
    Comments:
    Jul 29, 2009
    It wasn't you, Greg. Another expert.
    I hate like hell to move that ****** out of the closet that it's in but I'll try.
    Thanks
    I took off the top of the dryer unit and all the wires seem to be in order. I did disconnect the timer unit and ordered another off of ebay ($25). At that price, I figured it was worth taking the chance. One person suggested taking off the back of the washer. I replaced a belt years ago by removing the front, not the back. In looking down the back of the dryer from above, I don't see wires altho that's where the wiresd to the wall outlet come out of. It seems that the bulk of the wires to the controls are top-front. I do see what looks like a resistor in the connections. Could that be bad?
    Is there a proper test for the timer or the harness that connects to it. I do have a Fluke multimeter. Here's a pix of the timer:
    http://cgi.ebay.com/Whirlpool-Kenmore-Wa...
  • 3,037 Answers
If you have the schematic, generally when the timer is on a certain cycle, that cycle should be showing a closed circuit. You can always order a new timer from Repair Clinic and return it within 30 days if it ends up not fixing the problem (a awesome return policy for expensive parts like this). Just go to www.repairclinic.com and enter your model number and the part should be pretty close to the top of the list. Let me know how this turns out.
Benjamin
Posted on Jul 31, 2009
    President:
  • 1,723 Answers
This sounds like a connection got banged loose from the shoes in the dryer pounding around. I think the first place to start here is to take the back off and do a thorough inspection of the connections coming in and going on into the components. I really think you have just knocked a wire loose.
Posted on Jul 30, 2009
  • 1 more comment
  • Craig Butler
    Craig Butler Jul 30, 2009
    I see a lot of comments on this and I don't see anything about going over the connections and a good visual inspection at all. That is the first thing any good technician will do on every single call. It's where you start! Every time!
    It is more often than not that you will see something a miss during the initial inspection.
  • Craig Butler
    The resistor is probably fine if it's not discolored.
  • Craig Butler
    You sound determined to fix this yourself. That's commendable. You may want to get a cheap meter at Home Depot, it will really help you with all the suggestions you are getting. You may be able to test components (with our help) and actually determine what's working and what's not??
    President:
  • 2,559 Answers
It sounds like either a wire is still off or if you replaced them,they are in the wrong location.
  • 1,959 Answers
Posted on Jul 28, 2009
  • 3 more comments
  • Greg Margossian
    Greg Margossian Jul 29, 2009
    Ifthe timer isn't moving at all, or stopping short of the rinse cycle or spin cycle, it's broken and needs replacement. It just seemed less likely given the description of your problem but yes, a timer that stops prior to finishing the wash would most definitely be the cause for your washer to stop midway through the cycle.
  • Greg Margossian
  • Greg Margossian
  • Greg Margossian
    Greg Margossian Jul 30, 2009
    Don't know which expert you were referring to; I never accused you of hooking anything up wrong or had a loose wire. I mentioned that it was possible you had a short since the washer was only operational when the dryer was on.
  • Greg Margossian
Ran dryer towels and sneakers didn't dry compleatly took out sneakers ran gave code AR drum turn and heats?
Make sure that the exhaust vent is not clogged! If it is, the unit will not dry anything properly since the humidity has no way of leaving the inside of the machine.
Apr 10, 2015 | Maytag Whirlpool Cabrio High Efficiency...
Maytag Dryer
HI,
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Aug 28, 2008 | Dryers
How to assemble belt
Hello Denise, I have seen this problem many times. The sneakers by themselves in the dryer cause a shock effect , when the weight of the sneakers tumbling onto the drum overloads the skinny belt and the belt breaks every time. Usually. if you dry the sneakers along with other clothes or towels this will not happen.
Feb 27, 2014 | Estate TEDS840JQ Electric Dryer
I have a Kenmore 110.63032102 dryer and I put a pair of sneakers in it. It shut off and now it wont even turn on. What's wrong?
Drying a pair of sneakers causes the dryer to overheat and this causes the thermal fuse to blow. The thermal fuse is wired in series with the motor circuit and if it blows, power to the motor is terminated causing the dryer not to turn on. Disconnect power then Pry the lower access panel off with a flat-head screwdriver as shown.
Remove the hex-head screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the duct to expose the thermal fuse on the blower housing.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards. Let us know if you need further advice.
Jan 26, 2011 | Kenmore Dryers
Whirlpool duet dryer GEW9200L will turn on but will only "click" when push button in. Timer light starts flashing. Wife was drying a load of towels with her pair of tennis shoes in it on the last load that...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 17, 2010 | Dryers
Frigidaire GLGT1031CS1 washer timer
Yes. Replace the timer and you are good to go.
Jul 05, 2010 | Frigidaire GLGT1031C Dryer
I was drying a pair of sneakers and the drum stopped turning and won't turn after several attempts to re-start the dryer.
What happened is the belt came off. Don\'t panic! I can help. Unplug the dryer and pt it on a tailgate. You gotta oil the rollers and clean out the lint so get it somewhere you can **** dat puppy. You gotta yank out the filter and remove those 2 screws on top the filter housing. Then use a putty knife to pop the top. Yank up on the front (after removing screws) and get it out yer way. I have here an old school manual and some repair pics babe. with any luck you should have this bad baby up and running!!
MANUAL
PICTURES
Dec 18, 2009 | Kenmore 64742 Electric Dryer
Washer filled with water but never began cycle
It sounds like the controller/timer unit has failed and needs to be replaced. I hope that this help you resolve the issue. Please rate this response. Thanks!
Aug 24, 2009 | Washing Machines
Kenmore 88752 Top Load Stacked Washer / Dryer Logo
100 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
