Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Where are the temperature controls on the kenmore elite bottom freezer refigerator
  • 631 Answers
Here is a shortcut to drawings that might help you. They may have your refrigerator on this site.
http://www.appliancepartspros.com/partsearch/
Posted on Jul 28, 2009
Kenmore elite refrigerator is not cooling, but the freezer seems to be working fine.
Kenmore Elite refrigerators come in several styles, including units with a freezer at the top and units with freezers at the bottom. The top and bottom of the fridge work on different systems. Sometimes the freezer may function perfectly, while the fridge performs poorly. Most issues with the fridge cooling are due to incorrect settings or poor cleaning practices. Checking common problems with the refrigerator will help you diagnose the situation and keep expensive repairs to a minimum
1. Check that the Kenmore Elite refrigerator is plugged in. Inspect the circuit breaker of the home if the refrigerator is plugged in but not running.
2. Pull the unit out from the wall and vacuum the condenser coils at the back of the unit.
3. Turn the temperature control in the Kenmore Elite refrigerator to the "On" position.
4. Turn up the temperature on the temperature control, located inside the unit on the wall.
5. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the Kenmore Elite fridge door.
6. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the fridge door.
7. Move food away from the vents inside the Kenmore Elite refrigerator.
I hope i solve you problem.
Have a nice day : )
Sep 04, 2011 | Refrigerators
The temperature settings for the refrigerator and
I have the same problem with this refrigerator. It looks like Sears Parts Direct sells all the parts for this unit except for the printed circuit board and temperature control switches. I called my local repairman and set up an appointment. He called back to cancel his appointment because he was also unable to get the electronics. Were you able to fix your unit? What did you replace?
Jul 28, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore elite fridge, french doors, bottom freezer: water does not come out cold. What should the temperature settings be at (for fridge and freezer)?
Fridge 34-38 degres
Freezer below 29
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 17, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Cant find the ice maker filter on my kenmore elite bottom-mount refigerator
It is on the back - behind a removeable panel. Top left side.
Oct 14, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
What temperature should we set the refrigerator and the freezer?
Totally up to you. Most people set them for the temp they like their milk and the firmness of their icecream
Sep 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite bottom freezer refrigerator...water won't work
I turned up the temperature in the freezer and the refrigerator. The next day the water was flowing.
Thanks for your time.
Sherry Piper
Jan 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator not cooling
This could be that it is out of balance. Set the temperature settings to midway. This control can easily get the fridge temp out out of balance if over adjusted. If you already have the tmp control at midway then you need to make sure there are no obstructions to the duct that carries the cold air from the freezer to the fresh food section to cool it. Check for ice buildup or any kind of blockage. Let me know what you find.
Nov 16, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice Maker; Kenmore Elite
you have an bad fan motor or wire connection to the fan that is used for the ice maker..hope it helps
Aug 30, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
265 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
