Question about Frigidaire FEF336BC Electric Kitchen Range
I have a frigidaire model # CFEF372CB2 and everything works except broil and bake functions. Any ideas?
4 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: ge spectra xl44 stove
Most likely the oven ignitor is bad or weak.  You can look at it and see how it compares to the broil ignitor.  If you see a whitish color on the ignitor and if it doesn't fully glow then it needs to be replaced.
Posted on Oct 22, 2007
  • 184 Answers
SOURCE: Broiling works but baking does not work
CHECK FOR 240VOLTS AT THE TERMINALS OF THE BAKE ELEMENT. GAIN ACCESS BY REMOVING THE BACK PANEL OF THE RANGE. SOMETIMES THE TERMINAL WILL BURN OFF OF THE WIRE GOING TO THE ELEMENT. THE WIRE WILL JUST BE HANGING THERE. BE SURE TO UNPLUG THE OVEN BEFORE REMOVING BACK PANEL. IF THE WIRE IS BURNT, REPLACE THE TERMINAL AND REATTACH TO THE ELEMENTS TERMINAL. IF THE TERMINAL IS DAMAGED, REPLACE BAKE ELEMENT.
IF THERE IS NO VOLTAGE TO THE ELEMENT, REPLACE CONTROL.
Posted on Apr 04, 2008
duby1990
  • 367 Answers
SOURCE: I have a frigidaire gallery stove. The bake not working
Your oven ignitor has gone out. This is located under the pan in the bottom of the oven. This is held in with 2 screws in the back portion of the pan. This will expose the ignitor and then 2 screws take it out. Replace this and this will fix it. very common problem
Posted on Feb 11, 2009
Kenmore range model c970-535121. Heard loud pop stove breaker and main breaker both tripped. Now everything functions except bake and broil do not work. Also noticed when push buttons on control panel
Sounds to me like you have a short in the bake and broil section. Check the wiring and see if a wire has come out of an area and grounded its self. Shut the power off when checking this out and you should find out where the short is so you don't shock yourself . Also check for wires that appear like they are burnt as this indicates where a short could be. Be very careful as this could be dangerous. If you don't know what you are doing call a repair man .
Dec 02, 2014 | Kenmore Kitchen Ranges
Frigidaire oven -- won't bake, everything else works
Hi, you mentioned the voltage supply appears good, but have you checked the bake element itself for voltage or continuity ? I don't recommend checking ranges while they have power, so you should unplug the unit from the wall. The lower element's (bake) tend to burn out more frequently because they are used more so I'd start by checking it for continuity. Hope that help's. Let me know if you require tips or guidance to check the element and I certainly will try and assist you. **FYI...It should read very little to no resistance with an ohm meter. If it reads infinte, it's time for a new one. Part # 316075104 and retails for about $30.** Thank's for visiting "fixya" amd good luck. Macmarkus :)
Jan 07, 2010 | Frigidaire FEF364DQ Electric Kitchen Range
Bake function not working
Yes, you need to replace the igniter.
If you're comfortable splicing wires, you can order any ignitor of the same shape, otherwise go to searspartsdirect.com to find the exact replacement part.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Jul 19, 2009 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Bake not working
Well, to ensure the element isn't bad, you can take an ohm meter to the contacts of it and measure the resistance. It should be around 20 ohms. If it is much greater or infinite, the element is bad. To get to the contacts you will need to unplug the oven, pull it away from the wall and remove the rear panel. Then disconnect the element wiring and touch the probes from the meter to the contacts on the element. Otherwise, usually, the temp sensor is bad if the broiler still works, this is a small pencil shaped rod on the inside top of the oven. You can test it the same way and it again should be around 20 ohms. You can order a new parts locally or from repairclinic.com. Let me know what you find.
Benjamin
Nov 13, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire conventional oven won't heat up
My frigidaire model is CPLEF398CCB conventional electric flat top oven. Everything is working fine except my oven. When I select pre-heat, broil or bake nothing lid up. No heat on the coil, only fan.Any suggestions?
Jul 03, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Hi, I have a Whirlpool oven model rf386pxgb 2 , everything is working fine except the broil. I checked the cables, thermal fuse, etc. looks ok. Any ideas or sugesstions? Thanks in...
with the unit set for bake check the voltage ac across the broil element
240 to element across it replace the element
no voltage across the element replace the control board
May 16, 2008 | Whirlpool Kitchen Ranges
970-686133 Bake and Broil Element not working
Typically what happens on on these models, when the bake element breaks, it sends a surge back to the oven control (or clock) and causes it to fail also. Sounds like this is what has happened here. If the overlay (touchpad) is a separate piece, you will need to buy it also. Let me know if you have any questions.
Feb 25, 2008 | Kenmore 95680 / 95681 / 95682 / 95684...
Frigidaire FEF336BC Electric Kitchen Range Logo
301 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
