Question about Samsung DLP HL-P5663W 56" TV
My samsung lcd tv is clicking and wont turn on
Only 1.5 years old 40 inch LCD 1080i. Clicks for about 5 to 10 minutes, then turns on. Once on works fine. Tonight its not turning on at all.
  • scarlettpurp May 11, 2010
    i have the same exact problem i have on had mine for 15 months.
Its a common problem with many Samsung LCD TVs. We had the same problem on our Samsung TV. Based on some info on the net we called Samsung Support department ( 1-800-SAMSUNG). After describing the problem and mentioning that I have read on the net that its a common problem, representative asked for the model number and serial number of the TV ( I read them to her from a sticker on the side of TV). The Samsung Rep acknowledged that it was a common problem for my model and few other LCD models and they were fixing the problem without any charge to customer eve though TVwas out of warranty. She took the required info and gave me the ticket/transaction number and forwarded it to a local technician. Technician called next day and setup the appointment with us. Technician came within the 4 hr window that he had promised and changed the faulty capacitor on the power board and was done within 10 mins. Samsung rep had indicated that the technician will determine if the issue was with capacitor or not. If the issue was something else then tecnician will charge the regular service charge to fix the issue.
Posted on Jun 30, 2010
  • Mark Nov 07, 2012
    I have the same problem. They agreed that there is a problem and wanted to set me up with service. They were not as nice to me. There will be a charge. Too much to pay for this repair. Guess it will go to the junk pile.
  • 7 Answers
Its the electrolytic capacitors on the power supply board.
you will find them swollen or exploded. easily fixed. go to www.earthinfo.org/samsung-tv-makes-a-strange-clicking-sound.
Posted on Aug 05, 2009
Had the same problem and the TV was taking longer & longer to start up when first switched on Lots of clicking. Found that the capacitors on the main power card were shot. Look for a group on capacitors that are fat or bulging could also be leaking black stuff. they cost about 50cents each from an electronic spares shop.Had to replace 4 on mine. You'll need to remove the back cover & the power card. Also need a soldering iron & some solder.Total cost of repair $3. Hope this helps
Posted on Aug 03, 2009
Hi i have changed the capacitors because my tv was just clicking and clicking doesnt come on
and now it doesnt even click and also doesnt have any power
help please
Posted on Dec 21, 2009
As said by others it is the cheap capacitors that samsung have put in.
When getting them replaced or replacing them yourself make sure you use the ones that have a higher temp threshold.
Just done mine myself, quite easy if you are ok with a soldering iron. the ones samsung used only had a 105 degrees max temp, i put in new ones with a max temp of 130 degrees so these will last longer. Remember the only way these tv`s turn off is at the power socket not by the button on the front.
Rubberman
Posted on Oct 06, 2009
LN-S4041D 40 in. HDTV LCD Television: OUR SAMSUNG T.V IS A 40 INCH AND IT CLICKS, CLICKS...
Is there a clicking sound? Unplug the power cord for 20 seconds and see if this helps reset the circuitry. If the clicking continues, go to http://www.fixya.com/support/t722954-samsung_lns4051_dx_makes_clicking. If you can see defective caps on the power board and don't feel comfortable replacing, parts can be ordered at PartStore.com.
May 16, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
3 year old Samsung 40 inch LCD TV will not turn on
The problem is 4 capacitors on the power supply board. Just had mine done under warranty. They (Sears) replaced the whole power board but you can get larger capacitors and just replace those for alot cheaper if not under warranty.
Dec 10, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Tv clicks but wont turn on
power supply board has probably failed, common problem. call1-800-samsung for nearest service center.
Nov 25, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
46 inch Samsung TV that just clicks but wont turn on
I just fixed this very same problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Sep 18, 2009 | Samsung LN-S4051D 40 in. LCD Television
My Samsung LCD TV will not turn on, it just clicks
A Replacement Power Supply.
Parts: £80 - £110 depending on the model.
Labour: £40 (ish) little bit more with a 90 day warranty etc.
Type your model number into www.chsinteractive.co.uk for the price on a PSU.
Good Luck.
Sep 07, 2009 | Samsung LN-S4051D 40 in. LCD Television
50 inch samsung tv clicks on and off when turn on
the Fuse needs to be Replaces, contact nearest samsung service center. would cost just $1 trust me
email me if you need any assistance ... rajanetworking@gmail.com
Sep 02, 2009 | Samsung LN-S4051D 40 in. LCD Television
I have a 46 inch Samsung LCD model number LN-T4665F and I have been having issues w/ the power/ clicking sound! It used to turn on and clicked a few times now just clicks all the time and doesn't turn on...
1. It is not a two years old TV, but a 9 years old one.
2. The common problem of the symptoms is a defective main power supply, you may check to see that are there anny "Pup-Up" electrolytic capacitor on the power supply, if there is any, replace them, you may fix up the TV
Jul 02, 2017 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung DLP HL-P5663W 56" TV Logo
9,319 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
