Compressor clutch won't engage unless you tap on it to get AC to come on. 1996 gmc sonoma
    Champion:
  • 363 Answers
Sound like you have a loose wire connection, i would make your the ground is secure and the hot lead is secure
Posted on Jul 28, 2009
07 sportage. Ac clutch goes off after 5mins
Woody have refrigerant level checked may be low. have a good shop recharge A/C system if checked and found low. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
FIXED Car Compressor Clutch Won Engage
The Trainer 40 When the compressor won compress
Diagnosing AC Compressor Clutch Problems
Jun 30, 2016 | AC Cars & Trucks
1999 GMC air cond. AC clutch wont engage. system is charged. relay, fuze,and low pressure switch are replaced.
ac compressor clutch coil open or short. wire cut or open to ac clutch.2 wires one is ground the other power, remove connector ac compressor then probe with test light between the two wire
Aug 05, 2013 | 2003 GMC Sierra 1500
Ac blows hot air
the ac clutch itself is bad there is a little washer in behind clutch sticking easier and almost as cheap to replace compressor
Aug 02, 2012 | Air Conditioning and Heat for GMC G2500
I have a 99 gmc sonoma that won't go into gear and there is no presure on the clutch pedal it goes straight to the floor but the fluid level is still on full and the fluid has some black looking gunk...
It is confirmed that the clutch hydraulics has faulted. Since there is no clutch the gear links are not engaged. Possible that the master cylinder has failed, possible a leak in the system.
You will need to overhaul this section and the pedal will respond.
Also check on the transmission fluid and the gear settings.
Sep 30, 2011 | 1999 GMC Sonoma
Ac won't get cold anymore power to compressor but won't click on clutch won't engage possible problems are compressor or evaporator what do you think?
Has the Freon been checked with a gauge to see if there is enough Freon to allow the system to work. Low or no Freon will not allow the compressor to engage. The low pressure switch is most likely activated due to low freon, and will cause this condition.
Aug 19, 2011 | 2001 Jeep Grand Cherokee
I'm tryin to find out if my a/c compressor is out. So I know that the dealer said that I need it charged and I didn't get it done. So lately it has been makin a loud noise and rattlin on the...
You may be having AC problems but that is not what happened when the Steering locked unless the AC is on the same belt as the Power steering unit. That whining you are hearing when you turn is actually the power steering unit being low on fluid or the power steering pump going out. Based on what you have described my guess is that the unit has gone out and needs to be replaced. As far as the AC compressor is concerned, if the unit is low on Freon it will not engage once it gets too low unless the clutch goes out. When you look at the center of the AC compressor when the engine is running and the AC is off you should see the pulley free spinning and the very center of the pulley won't be spinning, that is the clutch Dis-engaged. When you turn the AC on the Clutch should engage and allow the compressor to work. You will hear it kick in and kick out repeatedly if it is low on Freon. If it is too low it will never kick in because the low pressure switch won't allow it.
Jun 16, 2011 | 1995 Oldsmobile Aurora
The clutch is not engaging on the compressor for the ac system it is a 1998 gmc sonoma 4.3 v6
hi.
the most likely cause is low gas in the air con system .
most cars have a pressure switch that detects low gas level and will prevent the clutch enganing to prevent damage.
the first thing to do is to top up the gas in the air con system.
i would recommend getting this done properly as they will ensure that the correct amount of freon is in the system, but you can top it up yourself using cans of freon from a motor shop.
Apr 21, 2011 | 1998 GMC Sonoma
Ac clutch not engaging
you will have to see with test light if you have power going to the ac compressor you either have bad compressor or low pressure switch
Aug 18, 2009 | 1996 Dodge Neon
1998 gmc sonoma air conditioner - not cold
Check the magnetic clutch is engaged on front of a/c pump, have the motor running, a/c on and fan on high, if the centre hub is static the pump in not switched on, this can happen when the gas pressure gets low.
Aug 05, 2009 | 1998 GMC Sonoma
The AC is not cooling and when I check the clutch on the compressor it isn't engaging and turning the compressor.
You must of lost freon and when there is no freon your clutch will not activate.Must check it for pressure in the lines.If there is pressure check pressure switch.Good luck let me know
May 24, 2009 | 1999 GMC Suburban
Heating & Cooling Logo
268 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
