Honeywell th8000 I can not set the cool setting any lower than 70, I thought it was supposed to go down to 40
    Scholar:
  • 117 Answers
There should be a way to set the parameters on the thermostat to go down below 70. Check your manual for instructions
Posted on Jul 28, 2009
HAVE A HONEYWELL THREMOSTAT TH8000 NEED WIRING HELP HEAT IS COOL COOL IS HEAT
Most of the time the white wire hooks to W and the yellow wire hooks to Y....... W= Heat Y= Cooling In any case if you are getting Heat when you set the thermostat to Cooling....... Turn the furnace off at the ssu or main breaker and then ... Pop the thermostat off of the subase and switch the wires that you have on Y with W and put the wire from Y to W.... Here is some more information on how a typical thermostat is wire in the pdf..... Hope this helps...
Here is a pdf for the installlation manual for a Pro 8000
http://www.hydro-temp.com/help/drawings/honeywell%2069-1894ES.pdf
May 05, 2011 | Honeywell Heating & Cooling
Th8000 is blowing hot instead of cold
if you have a heat pump you must go to installer set up and change the reversing vave to energize in cooling
Aug 30, 2010 | Honeywell Electronic Programmable...
Mystery message "wait" appears above "following schedule" display line on our Th8000. Ac does not come on even when temperature is in range. Fan operates ok. Is "wait" setting one I can reset? Maybe a...
Mystery message "wait" appears above "following schedule" display line on our Th8000. Ac does not come on even when temperature is in range. Fan operates ok. Is "wait" setting one I can reset? Maybe a compressor issue rather than thermostat? Thanks
Jun 21, 2010 | Honeywell Electronic Programmable...
Thermostat set at 74, but air conditioner won't turnoff
Need to reset the lever sensitivitie( behind the cover) to a lower setting.
Jul 22, 2009 | Honeywell Heat/Cool Thermostat
Message: "in recovery"
the "in recovery mode" is refering to a thing called energy recovery management its one of the features on your tstat what it does- when you are using the program on your tstat the "in recovery" starts your unit early so if the tstat is set to be 70 degrees at 8 in the morning when 8 o clock hits it will already be 70 degrees in your house you can turn this feature off if you want in the installation setup codes
Jun 24, 2009 | Honeywell Programmable Thermostat Heater
My heating/cooling blower (not the outside unit but the fan in the garage) does not turn off, even when my Honeywell TH8000 is set on automatic. What can I do to have the fan motor shut off?
try hard wiring your 24 volt that goes to the outside unit to the yellow wire coming back from your thermostat make sure the yellow wire is on the yellow terminal on the thermostat (honeywell) i have run into situations when this seemed to be the only thing that worked
Jan 13, 2009 | Honeywell Programmable Thermostat Heater
Th8000 does not match another thermometer inside home
Is the thermostat mounted near a lamp or other heat source?
Is the wall warm from ducts in the wall or a refrigerator on the other side?
The thermostats are usually pretty accurate. Most times I find some other influence on the thermostat causes the problem.
The Honeywell 8000 series also has a feature accessed through the installer setup menu, that will allow the temp display to be changed + or - 8 or 9 degrees.
Check the manual or Honeywell's website for a .pdf if you need it.
Hope this helps.
Matt
Jan 11, 2009 | Honeywell Electronic Programmable...
Non-deletable schedule in VisionPRO TH8000
The thermostat has a function called "Adaptive Intelligent Recovery".
This feature allows the thermostat to learn how long the furnace and air conditioner take to reach programmed temperature settings, so the temperature is reached at the time you set. For example: Set the Wake time to 6 am, and the temperature to 70°. The heat will come on before 6 am, so the temperature is 70° by the time you wake at 6.
You can turn off this function. Download the installation guide at the next link:
http://customer.honeywell.com/honeywell/ProductInfo.aspx/TH8321U1006
and look for funcion number 0530 Adaptive Intelligent Recovery. In this manual you also find the way to do a reset with the function number 0710.
I hope this solves your problem.
Nov 19, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
253 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
