Question about Dayton 1hp 1725RPM 56C Frame 90 Volt Dc Electric Motor with 115 Volt Input Control # 1F798
2 hp daton 3 phase motor runs hot - Dayton 1hp 1725RPM 56C Frame 90 Volt Dc Electric Motor with 115 Volt Input Control # 1F798
    Champion:
  • 363 Answers
Depending on the load and resistance. If the motor is under an entreme load it will run hot. and maybe its time for a new set of brushes
Posted on Jul 28, 2009
We are trying to replace our 3 wire well pump with a 2 wire pump. It starts up and then stops. Any ideas?
A 3 phase motor replaced by a single phase motor has to be connected to phase one and neutral. You're going to use more power that way. How long does it run before shutting off? Is the new pump getting hot? Have an electrician determine which wires are the phase hot and neutral. Hooking up 2 phases without a neutral will trip the thermal overload in the motor.
Oct 24, 2016 | Cars & Trucks
Single phase or 3 phase
Hmmm. Good question. Like anything, it varies depending on how the equipment is going to be used and in what environment. We could really get into the weeds, but let's just ask the couple of key questions.
1. Is this a commercial or residential environment?
2. What's the horsepower of the motor(s) in use?
3. What's the availability of 3 phase power?
1. If your saw is in daily, commercial use, then 3 phase may offer some distinct advantages: While it's expensive to convert (assuming you don't already have 3 phase available) it allows for smaller, less expensive wiring, and lower voltages making it safer and less expensive to run.
Single phase, otoh, is much more available, and runs motors up to 5hp with little difficulty. It does actually cost more to run a lot of single phase equipment so if cost is an issue and you have quite a few motors, this may be a large determining factor.
2. As I mentioned, if you're only running one or a couple smaller motors, up to 5hp, single phase should work just fine. I have several pieces of machinery with 5 hp motors them on single phase 220 and they perform great. I don't recommend 110vAC for motors under significant load. They run too hot and are not all that efficient, as well as under-powered.
3. Installing a 3 phase electrical system can be very expensive. I would look into this carefully, get a few estimates before moving ahead. You'll need to find out if it's even available, cost of transformers for 110 in the building as well as whether they'll charge you commercial rates for your electricity once it's installed.
There is no simple answer for this question, I fear. There are simply too many factors to consider.
This is the short answer. A simple web inquiry will give you more answers than you actually need.
Good luck.
Jan 02, 2016 | Saws
If the 10 HP motor works harder at 230 v 3 phase than 460v 3 phase would a 15 HP motor at 230 v 3 phase be sufficient I guess what I'm asking is what would work. I only have 230 v 3 phase
For a given power output, generally a higher voltage motor will be slightly more efficient than a lower voltage unit because the lower current will produce less loss due to resistance in the windings and will also have a better power factor as a result. That's why the 230 V motor appears to "work harder" than the 460V equivalent.
If the 15 HP motor is more efficient at the load point than the 10 HP motor, and you will use it enough to justify the expense, it's worth using. If this is an industrial application (running continuously for at least one shift), do investigate the newer motor drive technologies. They can save a considerable amount of money on electricity.
Aug 03, 2015 | Air Tools & Compressors
Does it hurt the performance of a 10 HP 3 phase motor to run on 230volt 3 phase than 480 volt 3 phase
Absolutely yes. Wattage or power is equal to voltage multiplied by current (amperage). The motor would have to more than double its current draw to put out the same 10 HP performance.
I have a Ingersoll Rand Compressor model# 2545E10V 10 HP,3 phase and I would like to convert it to a signle phase. would this motor here be good to go with and what other items will be needed to complete...
It might. Mounting holes match? Shaft diameter and adapter match? Power supply sufficient for 5HP motor? It's a big motor! You might get a better answer from the ebay supplier.
Mar 05, 2015 | Ingersoll Rand Air Tools & Compressors
Sometimes IR 30 goes into a strained free wheeling state
Did you change the 3 phase motor out with a single phase motor? A 3 phase motor cannot be made to run on single phase.
Feb 02, 2013 | Ingersoll Rand - Rand Type - 30...
What is the difference between neutral and phase?
neutral is the white wires on each power phase phase is the number of hot lines to run pump 120 volt 1 phase 220 volt 2 phase 3 phase has 3 lines to it let electrician handle this
May 31, 2012 | Waterway 5 Hp 230 Volt 2 Speed Side...
I have a brand new IR compressor model 2475N7.5 with a 7.5 hp 460v 3 ph motor. is it possible to convert it to a single phase power supply? or should i just exchange it? ... I ordered it thru Northern Tool...
When you google home made 3 phase converters, you will find many ways to make use of 220v single phase instead, however you are limited as to the hp that the motor will produce. If you spin the motor first then apply 220v, the motor will continue to turn at much reduced hp. You need full power to turn a type 30 pump depending on pulley combination/ setup. Best to return the unit and get one that will run on 220v single phase. It will most likely consume more power to do the same work however it would cost a great deal to install 3 phase. Most likely not even available at all. Many years ago, I worked at Sears and happened to see an electrician coming down from roof access of building. He told me that sears had a 3 phase generator being turned by a 220v single phase motor to run an air conditioning unit. He said that it worked quite well. Does not sound cost effective.
Jan 08, 2011 | Ingersoll Rand - Rand Type - 30...
Taking my P660 out out a building with 3 phase power and into one with only single phase. Converter says motor will run on 2/3 power. Good or bad idea????
Good!
MOTOR:
21?2 H.P., Hobart designed, high torque ball bearing,
ventilated within mixer enclosure. Single-phase is
capacitor-start, induction-run type.
Three-phase is
polyphase squirrel cage, induction-run type.
Single Phase 208V 20.0 Amps
240V 17.0 Amps
Three Phase 208-240V 8.6 Amps
Nov 26, 2010 | Hobart P660 Stand Mixer
I want to reverse rotation on my A.O. Smith 120/230 volt single phase 1.5 HP motor. Catalog number B762
I believe all you have to do is swap your two hot wires,that works for 3-phase but not sure on single phase
Oct 07, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Dayton 1hp 1725RPM 56C Frame 90 Volt Dc Electric Motor with 115 Volt Input Control  # 1F798 Logo
135 people viewed this question
Top Dayton Tools & Hardware - Others Experts
Craig Butler
Craig Butler
Bill Boyd
Jerry Pitts
Are you a Dayton Tool and Hardware - Other Expert? Answer questions, earn points and help others
