SOURCE: Playstation 3 won't power on?
Hello.
This is a hardware failure caused by heat. I have done TONS of research on this problem as I have a unit that is like this too. But I bought mine used. I hear that Sony will fix it or send you a replacement for FREE. I have been told by over 30 people that Sony did it for them. Just be honest and polite to the customer service people. Go to www.playstation.com choose your region, click on playstation 3, then Support (upper right corner) and there should be the contact information.
If you need any more information, please do not hesitate to hit my "Ask Me" button.
I hope this helps. Good luck to you!
SOURCE: Craftsman lawn mower can not run without pumping the red button
The fact you need to keep pushing the RED or "Primer" button says that your engine is running too lean ie. not getting enough gas.
You probably have a carburator problem due to the old gas gumming up the inside of the carb. The gum and dirt is clogging some of the internal passages of the carburator. It will need to removed from the engine and cleaned. The carburator is held to the engine by 2 bolts and is simple inside. Carefully clean the carb. with either carb. cleaner or laquer thinner or similar good solvant. Reinstall and you should be fine.
Also be sure to check your air filter and replace if dirty.
The red button is a "primer" that pumps extra gas into the engine. It is normally used only only for statrup so if need to use it while the engine's running, you're running too lean.
Dr of Motors
SOURCE: Craftsman self-propelled mower won't start
Sounds like to me that the motor is running way too hot which could cause detonation. This is cause by carbon build up on the piston crown still hot as a stove top, therefore, igniting any left over gas still on the piston. Also, it may be due to a bad kill switch connection.
SOURCE: I can crank my murray gas lawn mower 6.5 quantum
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
