I have a Sony VCR SLV-N700. When I lived in a house the VCR was connected to the televison set. I could play tapes and I could program it to record programs, using the "Setting the timer manually" option. When I moved to an apartment, a cable box came with the apartment. (The cable box is a Pioneer CATV Converter, Model BD-1100.) The movers connected everything. (There are three cords coming out of the back of the VCR, two going to tbe cable box and one going to the back of the televison set.) Now I can play tapes, but I cannot record programs. When I try to record programs, the screen comes up and I can select programs to record, but nothing is recorded. (The date and time are set corrctly on the clock on the screen.) If I remember correctly, a red rectangle on the VCR screen told me that the VCR would record a program at the proper time, but now there is no red rectangle.
  • wbayliff99 Aug 03, 2009
    Dear Mr. Danjoff
    I printed your answer, and then tried to follow your Instruction 1. I couldn't find a small switch on the back of my cable box. (I looked in the daytime, and used a flashlight, but it just isn't there.) I had previously tried to record programs when my television was on Channel 3. I tried again to record a program, this time with the television set on Channel 4, but it still wouldn't work.
    I have the owner's manual that came with the VCR, and I had reread pages 39-40 to be sure that I still remembered how to record programs. The second sentence on No. 7 says, "When using a cable box, leave it on." A little while ago I was watching the 5:30 news, which I had programmed to be recorded, so the cable box was on at the time that the 5:30 news should have been recording.
    I would appreciate your further comments. Thanks a lot. Bill Bayliff
    Novelist:
  • 190 Answers
Your VCR will record from the cable box as long as the coax cable coming out from the wall outlet goes into the VCR's IN jack, and the coax cable of its OUT jack goes into the VCR's IN jack. Your VCR then should have another coax cable coming out of its OUT jack into the back of the TV.
Both the VCR and TV have to be set to one of two channels: 3 or 4, and the output from the cable box should also be set to output on this frequency/channel.
In order to record any program, now you have two choices: Set the start and stop times on two devices: the VCR and the cable box; the easiest choice is to leave the cable box on all the time, and only set the VCR timer.
One last thing: In order to switch channels, you will have to use the cable box's remote, if you're watching TV from the cable box.
There are certain cable boxes that bypass the TV signal when they are turned off. In these cases, you may watch TV using the TV's remote control. You have to check your cable boxe's user's manual.
Posted on Sep 08, 2009
    Genius:
  • 1,043 Answers
When you have a cable box connected to your VCR, you will not set your timer to tune in the specific channel that you want to tape from. What you 'll have to do is either
1) If your box is connected to your VCR via 1 piece of the cable you will have to set your timer to go to either channel 3 or 4. If you look on the back of the cable box there should be a small switch that is either set to 3 or 4. Leave your cable box on and set on the channel you want to record.
2) If your cable box is connected to your VCR via 3 RCA cords, one red, one white, and one yellow, you would have to set your timer to record from LINE IN 1 if that is the connection used; LINE IN 2 would be chosen if that is setup. What you do then is set your cable box to whatever channel you want to tape from and leave it there.
If you have your manual handy, pages 39-40 are the ones you want to check. If you don't have have your manual, here is a link to download it:
http://esupport.sony.com/US/perl/model-documents.pl?region_id=1&mdl=SLV-N700
Posted on Jul 28, 2009
  • bvanjoff Jul 30, 2009
    When you have the opportunity could you please give my answer a rating?
    We use the rating system to gauge our effectiveness. Should you ever
    have problems with anything in the future please don't hesitate to use
    our services again.
  • bvanjoff Aug 03, 2009
    Sorry to hear that you're still having issues with your recording. Here is your latest comment:
    I printed your answer, and then tried to follow your Instruction 1. I couldn't find a small switch on the back of my cable box. (I looked in the daytime, and used a flashlight, but it just isn't there.) I had previously tried to record programs when my television was on Channel 3. I tried again to record a program, this time with the television set on Channel 4, but it still wouldn't work. I have the owner's manual that came with the VCR, and I had reread pages 39-40 to be sure that I still remembered how to record programs. The second sentence on No. 7 says, "When using a cable box, leave it on." A little while ago I was watching the 5:30 news, which I had programmed to be recorded, so the cable box was on at the time that the 5:30 news should have been recording.
    When I advised leaving the unit on channel 3 or 4 what I meant was leaving your VCR on channel 3 or 4 if that was the way your VCR is connected to your cable box. Your VCR is going to receive signals from your cable box one of two ways. Either there will be a single piece of cable running from the back of your cable box to your VCR (page 14 of your manual). This would be the cable that actually threads onto a round connector. To record these signals you would set your timer using either channel 3 or 4 as the channel, and you would set your cable box to whatever channel you want to record. The best way to see if this works is to turn on your TV and then set it to whatever input you normally use to watch your VCR. You should be able to see whatever channel you have your cable box set to receive. If this is the way your cable box is connected, and you can't see the channel, then there is either a problem with the wire that runs from the cable box to your VCR, or, there is a problem with your VCR. You stated you were watching the news and had set the VCR to record it but nothing was on the tape. Try the same thing, but make sure that your TV is set to whatever setting you use to watch the VCR.
    The other way to connect cable boxes is with 3 "RCA" type of connectors. This would be Video, and Left and Right Audio. These cables have a round connection, and the male version has a post in the middle. The female version is round with a hole to accept the post in the middle. If this is the way you are connected, then you would program your VCR to timer record and you would set the input as either Line In 1 or Line In 2. Again you would leave your cable box on and set to the channel you want to record. Most cable boxes used today have this type of connection.
    Hopefully this will help you resolve your issue. If you try the items I have outlined, and you can neither record, nor be able to watch the VCR output and see the channel you are recording, then you have a larger problem with your VCR. Try them out and then please let me know what happens.
HOW DO I RECORD WITH A SONY SLV-N77 MANUAL DOES NOT HAVE ANY DIRECTIONS
Looks like a great brand with good features for the price.
  1. Connect Video & Audio Cables to a video signal source
  2. Connect Power Cable
  3. Turn on VCR.
  4. Insert a blank tape in the VCR.
  5. Note - A Broken Tab on the back of tape will prevent recording. This is called Write Protection.
  6. Cover the tab hole if you want to record over old video.
  7. Press RECORD on the VCR remote control.
  8. After a minute, press Stop, then PLAY to see recording.
  9. Cheers
Aug 18, 2014 | Sony SLV-N750 VHS/S-VHS playback VCR
Hi there, Having some trouble with the Sony SLV-SE830 VHS VCR. It should just work once the power is switched on and the SCART lead is connected to the back of the TV and the AV channel is set to the...
If you tv has more than one SCART connector.. ensure you have the cable plugged into the proper one.
Not sure what the problem is.. if you have a modern bidirecitonal SCART cable properly connected.. you should be able to view and hear the tape as it plays.. assuming the machine is in good condition.
Of course if you want to record a program other than the one you are watching you will ned to supply an independent broadcast signal to the VCR.. and yes you may have to program the tuner on the VCR if you want to record.
However if you simply wish to view tapes.. you shoud be set to use the machine as connected.
Best of Luck!
Apr 08, 2011 | Sony SLV-SE830 VHS VCR
Sony slv-n700 has been in storage. Has been used very little. Last used successfully approximately 1 1/2 year ago. Loads tape around read head, seems to try to start to play, but cassette spools do not...
VHS tapes, VCR's, as well as cassettes have all become obsolete. Putting these in storage is bad for them. They contain rubber parts on the inside that do not do well in cold weather in storage if that is where they were stored. You could possibly get replacements from the internet. With todays technology I would recommend going digital or DVD's or maybe even Blu-ray. Hope this helps.
May 21, 2017 | Sony SLVN700 VHS VCR
Tape hanging up and will not record.
There is a threading arm that has gummed up inside the unit. I suspect that the tape is not being loaded correctly. This is a common problem with the Sony units and requires the removal of that loading arm to remove gummed up grease. Once that is completed, the unit will function correctly. Please note that the height of this swing arm is critical to the correct loading of the tape. I would not suggest you attempt this repair because the tape height adjustment needs to be exact. A local shop should be able to resolve this for you with NO parts required.
Dan
Mar 11, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
Sony SLV-D100 DVD/VCR unit won't record on a VHS tape.
Check the tab on the VHS tape be sure it is there. If not place a [piece of transparent tape on it to simulate the tab and try again.
Oct 02, 2017 | Sony SLV-D100 DVD Player/VCR
How do I get my VCR to tape programs
Two things to check here. Lets verify the basic functioning of the unit. Have you tried playing back a pre-recorded tape? If so, please post the results here. I suspect that a pre-recorded tape will fail as well. If so, I'll post instructions on how to resolve the problem.
Please keep me posted.
Thanks,
Dan
Dec 30, 2008 | Sony SLV-N55 VHS VCR
I have a Sony SLV-EZ717
It sounds like the taped program was recorded on a different speed. The other VCR that you are playing the taped program may not have the speed needed to play it correctly.
Next time when you record a program try to make sure you use a speed that will be compatible on both VCRs.
For example a tape that last 120 minutes, using the different speeds will give the following recording times.
SP means "Standard Play" >>>> 2 hours
LP means " Long Play" >>>>> 4 hours
ELP means " Extra Long Play" 8 hours
Older VCRs have all the 3 speeds but newer ones only have SP and ELP.
Hope this helps.
Jan 25, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
Recording problem on Sony SLV-R1000
The deck needs a good cleaning. Try using a brand new tape and run it on playback for 20 min or so. You could try using a cleaning tape, but many of them are abrasive. If this doesn't work, you need a deck re-alignment which will cost more than your set is worth.
Nov 13, 2007 | Sony SLV-R1000 S-VHS VCR
Won't timer record
- Does it have a tape inserted?
- Is the clock set?
- Is VCR off? (has to be off to be in timer mode for many VCRs)
- Is it recording but just plays back blank or does it not even start?
- If recording blank, make sure you are giving it a signal (Is your monitor hooked to the VCR output?)
- If timer doesn't start double check timer settings - they can be very tricky.
Nov 06, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
