Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side #ESS25LGNA CC freezer warms every month or two
Our refigerator is 7 years old. The freezer works fine except for every month or two it warms up enough until everything inside is melted and then it restarts. The whole process could be measured in hours not days. The door seals are fine and appear not to be the problem. Is this a common problem with this model and can it be easily repaired? I'm not sure if this is related or not to the freezer problem but sometimes we find frozen food in the back of the fresh food side of the refrigerator.
    Scholar:
  • 117 Answers
You have a common problem with your defrost heater or defrost thermostat. They, along with a timer regulate a cycle that periodically defrosts the ice buildup on your condensor. hence it is a frost free because it is done automatically .You will have to remove the back cover of your freezer compartment to access the problem.You should see a heater element or two and a thermostat (round thingy wired before the heater. The thermostat will have to be bypassed to perform the following test .after you bypass the therm, turn the defrost timer clockwise until you hear a loud click. you should be in defrost mode. if the heaters heat up the therm is bad. If the heaters are not on then you have a bad heater element.You can check them for continuity with a ohm meter to confirm. hope this helps
Posted on Jul 28, 2009
Water line keeps freezing on my GE side by side refigerator
Check to see if the water tank in the bottom of the refrigerator section is frozen. If it is, you will need to turn the refrigerator section temp down.
Dec 05, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Have GE profile refrigerator. It is 3 years old.
OK check the Thermistor, the actual temperature sensor element, and or thermostat if it uses a separate feed.
Sep 10, 2011 | GE Refrigerators
Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
May 18, 2009 | GE Refrigerators
GE GSS25WGMCC, Ice Forming On Freezer Interior Surfaces
i had the same problem and i replaced the defrost heater and it worked fine for about one month but now having the same issue. Most of the time from what I have heard it is the defrost heater (about $60 part). I might have another issue going on with mine like a defrost thermostat. Your defrost heater is right under the panel on the inside of the freezer section. remove white panel on back side of freezer section and remove two screws and two wires and replace it and you should be fine.
Apr 15, 2009 | GE Refrigerators
Refigerator warm
Questions? Are you sure air is blowing in to the ref side what is the temp in freezer any snow like frost on the rear of freezer compartment?
Feb 09, 2009 | Refrigerators
Fridge wont get cold and freezer gets cold then gets warm
Sounds like to me you have a defrost issue. If your fridge is only 2 months old don't sweat it and call out a Whirlpool warrenty certified tech. to fix the problem. And sorry to say age does not matter with fridges any more. The good ole days of fridges lasting 20 years is over now it's 12 years if your lucky.
Feb 24, 2008 | Jenn-Air JCB2280HES Side by Side...
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
333 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
