Linda
is there an error message? If so what is it?
you need to open your tablet and find settings icon
if it's an ipad
choose wi fi make sure it's On or choose your home network and choose join
it may ask you for a password that you need to get from your cable company or it's on your network router
when you type in password you will be on wi fi
use a safety pin or needle press till you feel the button is pressen down and hold for a few seconds ..some devices require you power them on whilst holding this down check your manual for instructions
watch this on how to do it , and leave a rating if it works pls
if you have android its easy just from settings turn on the wifi and conect if you have password on wifi write it its all anyway you can dwonload the manual from here http://www.visual-land.com/manuals.html
go to settings, select " Wireless & Networks " select "Wi-fi" ( It will turn the Wi-fi on ) after the "Wi-fi" is on, then select "Wi-fi settings" then you will see some Wi-fi networks.
then select the wi-fi networks you know, and depend on the security of the Wi-fi, you sometime have to enter the pass key to get in to the network.
Connects over the last Wi-Fi network you used that's available.
If no Wi-Fi networks you've used are available, iPod touch will scan for Wi-Fi networks and show a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show a lock icon () next to them.
Option to manually enter your Wi-Fi network name/SSID (if the Wi-Fi network is configured not to broadcast or be displayed to the public). If necessary, enter the password to join.
When iPod touch is connected to a Wi-Fi network, the Wi-Fi icon () in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
Wi-Fi Settings
Turn Wi-Fi on or off. Choose Settings > Wi-Fi and turn Wi-Fi on or off.
Set iPod touch to ask if you want to join a new Wi-Fi network. When you are trying to access the Internet, by using Safari or YouTube for example, and you are not in range of a Wi-Fi network you have previously used, this option tells iPod touch to look for another network. iPod touch will display a list of all available Wi-Fi networks that you can choose from. Networks that require a password appear with a lock icon ().
If "Ask to Join Networks" is turned off, you must manually join a network to connect to the Internet when a previously used network is unavailable.
Choose Wi-Fi and turn "Ask to Join Networks" on or off. If you turn "Ask to Join Networks" off, you must join new networks manually.
Join a Wi-Fi network manually. Choose Wi-Fi, wait a moment as iPod touch detects networks in range, then choose a network. If necessary, enter a password and tap Join. Networks that require a password appear with a lock icon.
Make iPod touch forget a network, so that the device doesn't join it automatically. Choose Wi-Fi and tap the arrow () next to a network you've joined before. Then tap "Forget this Network."
Connect to a closed Wi-Fi network (an available Wi-Fi network that isn't shown in the list of scanned networks). Choose Wi-Fi, then tap Other and enter the network name. If the network requires a password, choose Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. Ask the network administrator which settings to use.
Adjust settings to connect to a Wi-Fi network Choose Wi-Fi, then tap the arrow () next to a network.
If you are using a commercial Wi-Fi network that requires a special login or subscription, see this article for more information.
If you are in a location with multiple Wi-Fi networks, verify that you are selecting the correct network.
Verify that the Wi-Fi network settings are correct:
Tap Settings > Wi-Fi.
Locate the Wi-Fi network you are currently using and tap
You can configure network-specific settings, including IP address, DNS, and Search Domain settings.
Use "Forget this Network" to reset settings for this particular Wi-Fi network, including the password. This is also useful if you identify a network issue and want to prevent the device from automatically using this network in the future.
Use "Renew Lease" to acquire new IP address, DNS, and Search Domain information from the Wi-Fi network.
Note: If the Wi-Fi network uses MAC address filtering, you will need to add the MAC address to the access list for the Wi-Fi router. The MAC address for your device is listed as the Wi-Fi Address in Settings > General > About.
Hold the power button until "slide to power off" appears. Slide to power off your device. When it is off, press the power button to turn it back on.
Reset network settings by selecting Settings > General > Reset > Reset Network Settings. Note: This will reset all network settings, including passwords, VPN, and APN settings.
iPhone only: If you continue to experience issues, consider turning off Wi-Fi and using the cellular data connection instead of Wi-Fi.
Additional Information
If using a Wi-Fi router at home, refer to your user manual/documentation to assist you with some of these suggestions.
Check the manufacturer's website for your Wi-Fi router for firmware or software updates.
Verify the Wi-Fi router can broadcast an 802.11b/g signal. If using a 802.11n Wi-Fi router, consult the manual/documentation for how to configure the Wi-Fi router for 802.11b/g compatibility.
If you are using multiple WEP keys on your Wi-Fi router, try configuring your Wi-Fi router to use only a single WEP key.
Try or resetting (or turning off and then on again) your Wi-Fi router. Note: If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
Disable wireless encryption or security on the Wi-Fi router to rule out encryption issues. If this resolves the issue, try using a different encryption or security protocol.
You have to take internet connection on your land line or mobile and put your lap in the range of adsl and conigure your lap for net.
Hop this solution works.
