Question about Dell Inspiron 1525 Notebook
Can not connect to wirless Dell 1525
We can not connect to wirless-have a Dell 1525 laptop. We can connect to the interent only using the network cord. Have a lynksys router. Other pc we have...which is also a dell 1525 we have not issues with.....just one that can not connect wirelessly...help please!
  • 11 Answers
Http://www.tomshardware.com/answers/id-2043772/laptop-detecting-wifi.html
ur wifi adapter does not support channel of broadcast above 8
so open ur modem configuration by connecting ur lan cable(192.168.1.1)
find channel and set its value to 1
this will surely solve ur problem.
Posted on Oct 03, 2014
    President:
  • 828 Answers
Check the IP address of another PC to copy its IP address then make your own IP address with Gateway & DNS Address... on your wireless LAN.
If not you should detect first your wireless Lan to your Router to identify the Network Address is correct.
Posted on Jul 28, 2009
    Brigadier General:
  • 4,090 Answers
Does it have awirless card or just an ethernet cable card?
Cannot access internet or no network connection.
Dell Inspiron 1525: Unable to Connect Wireless Network
setting up the right option for wireless network connection at Dell 1525. Here's the following:
  1. Go to Control panel
  2. Select Windows Security Center
  3. Select Windows Firewall
  4. Click on Change settings
  5. Here you might see User Account Control will ask for your permission to continue, simply grant it.
  6. Click on the Exception tab at the middle
  7. Scroll down to Wireless Portable Devices and check the box next
  8. Click Apply, then hit OK
  9. After close the program now you can try to connect again and watch the result.
With assumption you're already make the wireless enable in BIOS setting. In the device manager you should see what the type of wireless wlan card you used and make sure it's already turned on via your switch on your laptop. If it was, then you need to find out the right wireless device driver for Dell Inspiron 1525. Here's the following:
  1. Visit Dell Support site and open the Network tab in the table.
  2. Find your wireless device and download the driver for it.
  3. Aim to a folder on your computer or any external drive if you have it.
At the Inspiron 1525 laptop
  1. go to start
  2. Right click at My Computer
  3. Click Properties
  4. Click Device Manager and Network Adapter .Here you should see a WLAN Mini-Card or might you only see "Unknown Device".
  5. Right Click on it and go to properties to select the Update Driver. Now you should browse the folder to select the driver you're already download at the first step.
NOTE:
Just follow the instruction appears completely. After installation the wireless wlan driver at Dell Inspiron 1525 finish, then reboot the machine and know your wireless connection should be works properly.
Jun 07, 2011 | Dell Inspiron 1525 Laptop
Can not turn on wirless capability dell inspiron 1545 windows 7
first,, press FN + F1 or FN + button with antena symbol...then go to network and sharing centar//change adapter settinds// choose wireless adapter with right click // connect and there you are
Apr 30, 2011 | Dell Inspiron 1525 Laptop
If i disabled wifi how to i enable in a dell laptop?
The same way you disabled it, there should be an icon on your taskbar for enabled and disabled the WLAN switch. If there isnt you need to go to control panel and go to networks, enable wirless router, search for networks etc. If that does work then you have to go into control panel, change wireless settings or change internet settings and find it that way.
Feb 07, 2011 | Dell Inspiron 1525 Laptop
Hi, I have reinstalled my window XP SP3 but after reinstalling window my wireless(Adapter name: dell wirless 1395 WLAN mini-card) is not working properly. I have installed latest driver on my Dell...
Verify that you have the correct type of authentication in wireless- if your router is set to WPA2, then you would have to go under the connection properties > security tab to change it to match that setup. If that does not work, then the issue may be that the wireless card is defective and starting to fail.
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Nov 22, 2010 | Dell Inspiron 1525 Notebook
I have switched over to the wirless modem (wifi) system. To activate this BSNL has asked me to switch on the wireless function key on which I am not able to trace out. Please help atonce. My laptop model...
There are 2 ways of which you can enable the wifi on your dell inspiron 1525:
1) Make sure the wifi catcher on the side is set to the "on" position, this can be achieved by sliding the little switch, so the line in the middle of the switch is aligned with the ' (a line) sign.
2) The next thing that you need to do is ensure that the wifi is enabled you can enable wifi by pressing "FN" (the key on the keyboard) and F2. N.B. This will only work if you have Dell quickset installed. An alternative way of doing this is by going to start > control panel > network connections, find the wifi adapter > right click > enable.
Hope this has helped slightly, add more info if it hasn't
Thanks for reading and good luck with your problem.
Good day
Nov 04, 2010 | Dell Inspiron 1525 Laptop
Got a dell inspiron 1525,no internet saying http 404 not found. what do i do?
This generally indicates a lack of connectivity with your network or internet service provider's network, whether it's wired or wireless. Check to make sure you have an established connection to your internet service provider.
Knowing what operating system and your connection status would help to assist you further.
Apr 14, 2010 | Dell Inspiron 1525 Laptop
Dell Inspiron 1525 not connecting wirelessly to Sky broadband
If your wireless router is configured with SSID, encryption, MAC address filtering (if enabled) etc. then the Dell wireless card needs to be configured with these settings to allow it to communicate with the wireless router.
Check the settings on your PC's wireless settings, and configure the Dell the same way.
Sep 08, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 1525 wireless problem
Go to http://support.dell.com and under the drivers and downloads section, enter your Service Tag, and download and install the latest Wireless Card driver for your model. Update to latest BIOS version as well.
Jan 10, 2009 | Dell Inspiron 1525 Laptop Jet Black
Acquiring network address
if you are using the dell wireless utility to manage your card, then disable it, and manage your wireless adapter through the windows network connections. that way the wpa issue will be solved by windows xp wpa. i had a similar problem with my inspiron 1525 (dell wireless 1395)
Jun 09, 2008 | Computers & Internet
Dell Inspiron 1525 Notebook Logo
245 people viewed this question
Alun Cox
