The settings should be in the manual . Rule of thumb for torque is 45 ft lb on the big ends and 65 for the mains. Sorry, don't know the metric specs, but you can check on the internet for a conversion table, just google "conversion table" and you will find the answers. You need to convert between ft lb and Kg Meter - or something!!
SOURCE: Hi can you help me with torque settings for main and big end bearings for 1.4 opel corsa
Connecting rod cap bolts (you must use new bolts)
stage 1 ... 25 Nm (18 lb ft)
stage 2 ... angle tighten + 30 degrees
Main bearing cap bolts ( you must use new bolts)
stage 1 ... 50 Nm (37 lb ft)
stage 2 ... angle tighten + 45 degrees
stage 3 ... angle tighten + 15 degrees
SOURCE: TORQUE SETTINGS ON OPEL C16SE MAIN AND BIG END BEARING TORQUE SPECIFICATIONS
Which engine size and type? Keep in mind we do not have Op[el in the USA.
if you are rebuilding the engine without the workshop manual before you, you will be missing important information including all that you ask for
manuals are available from most auto parts shops or technical publication shops
you are well advised to get a manual
Testimonial: "im unable to get my hands on one."
Test the battery for load not volts. Use a load tester. If it falls below 9volts under load replace battery. If the battery is older than 3 years old replace it. A bad battery will damage the alternator (full field condition).
SOURCE: 1998 Opel Corsa B 1.6is Bakkie Help Needed from the Opel Experts
We do not have Opel brand here.
