Question about Hardware & Accessories
Ceiling fan controled by intermatic e1010/e102 doesn't come on
Ceiling fan controled by it no longer comes on. when the unit is unscrewed from the wall box the timer is very hot to the touch on the back of the unit, is this normal? is there an easy way to troubleshoot the timer? should the timer unit be replaced? this timer and fan has been in place for about 4-5 years.
    Champion:
  • 363 Answers
If you are getting heat on the timer it is time to replace it
Posted on Jul 28, 2009
Intermatic timer model: E-1010
This heavy-duty 15 amp mechanical timer replaces single-pole switch.
Use for appliances, attic fan, 1 HP motors, lights, CLF, led ... any load.
Operates in freezing location such as garage... note; many electronic timers that cannot be exposed to freezing temperatures.
Requires neutral wire.
There are two models E1010 E1020.
The E1010 has non-replaceable, 2 On 2 OFF trippers.
E1020 version has replaceable trippers with 30 minute intervals.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#E1020
Gene
Water Heater Timers Save Money
Mar 05, 2015 | Intermatic Hardware & Accessories
My 3-speed ceiling fan is connected to an on/off wall switch that turns it on and off but the pull chain does not control the speeds. It is stuck on slow speed. I tried replacing the pull chain switch in...
Guess what? A standard dimmer switch will not properly operate a fan motor. In fact, it’s most likely going to damage the fan motor and it could even potentially cause a fire. I’ll admit I even went out and bought a dimmer switch and I sat down to just “make sure” I was doing the right thing when I figured this out.
Standard dimmer switches are designed for the wattage of lights. Fan controls are designed for the amperage of the fan motor. So if you want to control the speed of a ceiling fan make sure you buy a fan speed control that specifically says it works for fans. Fan controls come in quite a few styles. The most common type has been around for quite some time and that is the rotary or dial type. The next most common fan control I found was the toggle that has three pre-set speeds (slow, medium and fast). You can also get a fan control that has a slider control along with a toggle switch.
dimmer+switch.jpgThe type that I want to install is a toggle switch with a small slider switch next to it. I have a feeling I’ll have to order one of these but I’ll check with my electrician tomorrow to find out the scoop. The bottom line is you can’t use a standard dimmer switch to control a ceiling fan. You have to get a fan speed control switch that is specifically designed to operate fan motors.
the short wire leads coming from the switch should be attached to other wires with small wire nuts. Just unscrew the wire nuts, unscrew the finial type cap that holds the switch in place, remove the switch and take it to the store. If your lights are strictly "ON"-"OFF" there should be just two wires from the switch. If your lights are controlled - "One" "TWO" or "THREE" at a time the switch will probably have three wires coming from it.
http://www.ceiling-fans-n-more.com/
Thanks for contacting Fixya.
Jun 14, 2009 | Heritage (5BUW52WZ4HN) 52'' Ceiling Fan
Error code E102-01 for canon ir7095
E102 - A read error has occurred in relation to the laser scanner unit EEPROM data.
theres a good chance that what is needed here is the laser scanner unit has a Beam Detect mirror and sensor and after time gets coated with foreign particles(dust) cleaning these mirrors/sensors will probably allow the unit to work again- this job should only be undertaken by a qualified service personnel, as more damage than good could be caused. if the laser scanner unit appears clean then iut will need replacing.
Jan 16, 2014 | Canon Office Equipment & Supplies
Ceiling fan is all wired up and on ceiling but light doesn't come on or fan doesn't spin. I have checked connections and tested for power. Is there a switch or anything on receiver that needs to be...
Jerry, from what you said, I assume you have a remote controlled ceiling fan. If that's the case, check the batteries in the hand held and the receiver, to make sure they are charged. Also, make sure they are installed properly. The Owner's Manual should have a reference to setting or resetting the codes for the remote control (Hand Held & the Receiver). Check those to make sure they are matching. And don't forget, the wall switch must remain ON for the fan to work, even with the remote control. The remote simply overrides the wall switch, when in operation. You may have to use the pull chain to start the fan motor the first time, then the remote can take over from there.
Good luck. I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 10, 2011 | Heating & Cooling
The spring whch controls the on/off function of my wall timer has broken. Who sells a replacement?
E1010 and E1020 parts are not sold.
I research and test timers, and do not know any site selling parts for in-wall timers of any brand.
Dec 28, 2010 | Intermatic Timer E1020, Single pole/single...
The spring for my off time is broke. Can it be replaced and if so where can I buy a new spring?
Parts are not sold for E1010 120V and E1020 240V timers.
Save the trippers in case they fit replacement timer
ESO sells new E1010 and E1020 timer
http://www.electricsupplyonline.com/prod/intermatic-timers.php
Nextag shows E1020
http://www.nextag.com/Intermatic-E1020C-120V-SPST-82480963/prices-html
New E1010 appears to have different design with plastic trippers
http://www.nextag.com/intermatic-e1010/stores-html
I don't know how a device with plastic trippers can be called heavy-duty.
Dec 27, 2010 | Intermatic Timer E1020, Single pole/single...
We just moved and are in the process of replacing many of the ceiling and other lights in the house to update it. The problem we've encountered is that that screws provided in your 'kits' for the mounting...
That is the standard screws that come with that particular fixture.Your local hardware store sells longer screws for ceiling fans for this situation. Cost less than $1.00 for 2 screws
Sep 20, 2009 | Hunter 52" Ceiling Fan With Light And...
Ceiling fans on same frequency
There should be dip switches in/on both the remote control and the ceiling fan that enable you to change the control frequency. The only thing that you have to ensure is that the two components are set to a matching frequency.
The switches in the remote are located in the battery compartment just above the batteries. Remove the dome on the ceiling fan and you should find the switches for that unit. Just compare the two and match whatever changes you make from one unit to the other.
Originally answered by d0n0r in this question
May 25, 2009 | Universal Remote Control Hampton Bay...
Airtech ceiling fan with remote, unit in fan not responding
Replace the globe with a LED that will last longer
Nov 20, 2017 | Dryers
Hardware & Accessories Logo
161 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
