Question about Car Audio & Video
After matching and installing a DUAL car stereo in a 1996 chevy lumina, I turn on the car and the stereo shows 12:00, per instructions I press the button to reset it (I also tried almost every other button) and the stereo simply blinks and wont move from that screen! this is the second stereo b/c i thought it was defective but the same thing happened so i think i may be doing something wrong. plz help!!
    Scholar:
  • 164 Answers
Did you try calling the Sual car stereo comapany 1800 number to ask one there tecs
Posted on Jul 28, 2009
Should i have any spare wires when hooking up an after market car stereo
Yes, It's a very good possibility that you will have a few wires left over. Normally a wire for an aftermarket amp to be triggered on when you turn your radio on and possibly a power antenna or a dimming function that dims your radio lights when your headlights are on. It of course always depends on if you have a power antenna or not, or if you have an aftermarket amp or not or if you have the dimming feature on your car or not. These wires don't apply to everyone.
You will just match the colors between the wiring harness that came with the DUAL radio and the interface adapter that goes to your car. Make sure you use **** style crimp connectors. If not the wires could come loose or cause a popping noise or cause the radio to turn off while driving.
Other than that, installing an aftermarket radio is mostly matching the colors up between the two harnesses and crimping the wires together.3_6_2012_2_31_36_am.jpg
Mar 06, 2012 | Cars & Trucks
I have a 1996 chevy lumina. the motor wont turn
You need to check for power at the purple wire going to the solonoid while key is in the start position, if no juice then check starter relay-under hood- fuse ,and ignition switch
Feb 01, 2010 | 1996 Chevrolet Lumina Mini
Chevy lumina 1993 3.4 6cyl. car will start but only run for about 20 to 30 secoonds then it will die.
my lumina 1996 turns on the security light and 20 seconds after turns off the car. What can I do? Thanks!!!!!!!!!!!!!
Jan 17, 2010 | 1993 Chevrolet Lumina
I need the wiring diagram to install an aftermarket dual stereo in a 1996 chevy lumina
first take out the stock head unit, after the colors of the wires originally from the car is usually red black yellow orange blue or gray, blue or gray w/ stripe, and purple or green, and purple or green w/ stripe. the head unit should have a power on it for the speaker wires those are the only tricky ones. color with stripe is negative. yellow for +12 black for -12 ground and red is for ignition, turn the radio on with ignition on. purple is usually rear and blue is usual front
Jul 26, 2009 | Dual Car Audio & Video
Cannot find the turn signal flasher
where is the signal light flasher located on a 1996 chevy lumina
Apr 24, 2009 | Chevrolet Lumina Cars & Trucks
Firing order and camshaft sensor for a 96 chevy lumina 3.1 v6
Here is a diagram of your motor with the firing order:
Mar 19, 2009 | 1996 Chevrolet Lumina Mini
Car radio
ignition on, LOC appears
press MN and OOO will appear in display
press MN again to make the the last two digits agree with your code.
press HR to make the first one or two digits agree
with your code.
Press AM/FM after you have confirmed that the code matches the code you have written down.
The display should show SEC which indicates
the radio is now operable and secure.
'rock on'
Mar 13, 2009 | 1996 Chevrolet Lumina Mini
1996 chevy lumina 3.4. service engine light on
You will need to replace the valve body in the transmission.
Mar 01, 2009 | 1996 Chevrolet Lumina Mini
1996 Chevy Lumina EGV Valve Replacement
I believe you mean the EGR valve
If this is a 3.1 Liter,..it's located on the drivers side, on top of the engine. It's bolted down with (2) bolts, mounted vertically, and has a wiring harness attached to the top of it. It has a black plastic top,circular in shape, about 4 inches tall. After removing it, invert to show underside & try cleaning the orifice (with the recessed screw) with a soft brass brush & carb' cleaner....to remove the carbon build-up which causes poor running & "service engine soon" light to display. If carefully removed, the gasket can be re-used,..if it gets damaged, one can be purchased at a automotive parts supply.
If you plan on doing a lot of your own work on this van, I suggest buying a Haynes or a Chilton Manual from a local car parts store for you van, they can give you instructions on everything
Oct 21, 2008 | 1996 Chevrolet Lumina Mini
1996 chevy lumina
I have had the same problem with my 1996 Chevy Lumina Car and it was the Throttle Position Sensor. Make sure to check your Air Filter and Replace Spark Plugs and Wires. Thank you for using Fix Ya! Don't forget to rate the overall rating of this answer. Thank you.
Oct 07, 2008 | 1996 Chevrolet Lumina Mini
Car Audio & Video Logo
95 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
