Question about Amana ARB2257CSL Bottom Freezer Refrigerator
Amana DRB2201CW refrigerator does not get cold
The refrigerator doesn't get cold, but the freezer compartment appears to work fine. We tried all the suggestions in the manual, but no luck. I think something has failed, such as the thermostat or coil. We recently (about a year ago) had the compressor replaced with complete success. But now the fridge compartment won't get cold.
    Scholar:
  • 117 Answers
You may have an obstruction in the air vent from the freezer compartment to the frig .there should be an airflow adjustment next to the thermostat. Middle setting is recommended. Since you say the freezer is working properly, I cannot see any other possibility. hope this helps.
Posted on Jul 28, 2009
Mod# ABB1922FEW... the freezer works fine but the refrigerator is warm, there is very little food in the freezer.
If the vent from the freezer to the refrigerator is not blocked with food or paper particles, then it's likely the defrost system is not working properly. You will need a technician to determine the cause.
Jan 22, 2013 | Amana AFB2534DE Bottom Freezer French Door...
The refridgerator compartment does not seem to be getting cold, the freezer compartment is fine.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 01, 2011 | Amana Refrigerators
I have an Amana Refrigerator. It is a double door on top and a pull out freezer on the bottom. The freezer is working fine. The refrigerator light comes on but it is not cold and my fresh food is fading...
either the evaporator fan in the damper vent door isnt running to push cold air from the freezer up into the refrige compartment or the damper vent door between the freezer and refrige section is frozen shut and cannot open to allow cold air flow,you need to access the evaporartor coil in the freezer rear wall and check both the fan and door movement
Mar 22, 2011 | Amana Refrigerators
Amana AFD2535DEW - Freezer compartment is operating fine, but refrigerator compartment is not getting any cold air, even though both compartments are set at "4". The baffel is open were the cold air would...
either the evaporator coil behind the freezer compartment wall is iced over and you can';t move cold air over an iced up evaporator coil to cool the refrigerator compartment or the compressor relay/overload is bad
Jul 25, 2010 | Amana AFD2535DES French Door Refrigerator
Refrigerator is not getting cold although the freezer appears to be working fine
can you hear the evaporator fan motor running in the freezer? this fan motor pushes the cold air from the freezer to the food section to keep it cold. you may have to replace the evap. fan motor. also, check for any kind of ice build up around the evap fan motor.
Oct 11, 2009 | Amana ABB1927DE Bottom Freezer...
Working fridge, warm freezer.
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
In your case, the door must be stuck all the way open, allowing all the cold air to be diverted into the fresh food compartment. The compressor cycle is controlled by the thermostat in the fresh food compartment and thus 'short cycles' because the fresh food compartment acheives normal temperature while the freezer is relativel warm.
If the panel is restricted from moving (stuck in the extreme open position, for example), the fresh food compartment will get VERY cold while the freezer will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is diverting all the cold air from the freezer into the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel/door/flap itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Hope this was helpful. Good Luck.
Aug 28, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
NO COLD AIR BLOWING TO REFRIGERATOR
The fan in the freezer blows its air through the COILS in the freezer. If the coils are plugged with frost, there will be no breeze coming into the fresh food compartment. One other thing i have seen on Amana and Sears, is that the fan slips on the motor shaft. Make sure the fan blade is tight on the shaft.
May 04, 2009 | Amana ARS266KB Side by Side Refrigerator
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Amana fridge
is the freezer cold. the freezer is acualy the only refrigeratted compartment . it has the evap coil in the rear wall and a fan to cerculate the air . a potion of the air is let into the food compartment . most comonly the freezer defrost system can be the fault. so i would requier answers to the first question. is the freezer compartment working. hope this helped
Oct 19, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana ARB2217C Fridge
its under the light bulb assembly in the frigidare compartment
Dec 29, 2007 | Amana ARB2217C Bottom Freezer Refrigerator
Amana ARB2257CSL Bottom Freezer Refrigerator Logo
373 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
