Question about Refrigerators
Kenmore top freezer 795.73266304 constantly beeping
My refrigerator is beeping. It is the same beeping it makes when I leave the door open too long. The doors are closed and properly sealed. It is in the garage, and it happens when it is cold outside. Chicago area temps. I called Sears, and they said it is due to outside temp. Both sections appear to be functioning properly. When it has been beeping, and I open both top and bottom doors at the same time, the interitor lights occasionally do not turn on, and when I close both doors and reopen only one door the light turns on. Then when I close the door and open both, the lights come on. The only time the lights do not turn on is when I open both after it has started beeping. How do I stop the beeping? Could it be a switch malfunction? Maybe I should just blow it up, or tie it to the back of my car and drag it down the highway. I am sure the beeping will stop for sure. Thanks for your help and advice.
Richie_asg1
  • 1036 Answers
SOURCE: refrigerator trouble shooting
Condensation only ever happens if the door is left open for a long period. - The warm ambient air condenses on anything cold - like the food in there.
Because of convection, the door need only be open 1/4" to be affected. Quite often a bag pushes the door open a little.
Check all door seals for splits - clean them.
Make sure nothing is touching the back cooling plate, and it should be fine from there.
Hope this helps.
Posted on Jun 11, 2008
SOURCE: Kenmore Elite bottom freezer refrigerator model 795.77573600
My Kenmore Elite (Model 795.7755 3600), less than two years old, had the same problem. One morning I opened the doors to a hot fridge and burning plastic. The light housing was sizzling hot - much of the unit literally melting away. Another hour or two and it could have been much worse.
Called the 1-800 number listed in the fridge. After about 45 minutes of patient talking, I learned that Sears (or Kenmore) have issued what they refer to as a "flash warranty) on the light fixture kit (Kit # 6871JB1423N) which in effect, for this part only, extends the factory warranty from one year to three years. I may even be able to have a factory tech install the parts. Hope it works out.
Bottom line: if you have this fridge, be very careful and monitor closely. An pursue the part warranty!
Posted on Jan 13, 2009
  • 172 Answers
SOURCE: Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
(865)945-3808
Posted on Feb 17, 2009
  • 363 Answers
SOURCE: LG Fridge door constantly beeping when closed
On the display panel press the right key that turns the door alarm on and off
Posted on Jul 21, 2009
VtToolMan
  • 704 Answers
SOURCE: Refrigator not cooling properly, freezer works fine
I'll assume you don't have much food/items in the freezer section. Because you have the fridge set on the max cooling setting and the freezer set higher than the mid setting, it could be that you have frozen the cold air passage from the freezer to the fridge.
If you can, 1) remove all contents that would spoil; 2) turn off the fridge 3) open both doors and allow the fridge to manually thaw out completely (this will speed up the opening of the cold air exchange passage between the freezer and fridge, which is likely blocked and frozen solid. Have plenty of towels handy to soak up the water from the defrosting process,
After a FULL day of being left off and doors open to thaw out, check for any further thawing and dripping water inside, if present wait another 8 hours (you really want to get it thawed out the first time!) When that's done, reset BOTH temperature controls to the factory mid-point setting (5?) as marked on your control knobs.
The key to having a refridgerator run properly is to allow for it to run at the factory settings for at least 24 hours BEFORE you adjust the controls higher and/or lower for each section. Adjust it up or down in ONLY 1 setting increments so as to not cause ice build-up and freezing of the internal air exchange passages.
Also, as you've relegated this fridge as a garage "beer & backup" unit, make sure to keep the freezer as full as possible to make it run as efficiently as possible. You can freeze jugs of water and pack it with cheap thrift store bread to help it run correctly. An empty freezer has to work harder to keep just air at freezing temps. As such, it will pass much colder air into the fridge, and cause these types of freeze ups. By the way, turning up the temp controls only makes it worse and just results in a total "freeze up" inside the cabinet panels that you can't easily see or get at to rectify, hence the reason to shut it off and let it fully defrost.
When you're done, you should have your fridge back in action working like it should, but remember, don't rush temperature adjustments, even thou we all want those frosty beverages, it'll take a couple of days to achieve the desired "chill" you're likely used to getting when it was your primary fridge.
Hope this helps and Best Regards! Semper Fi!
Posted on Aug 03, 2009
Hi, I have a kenmore elite deep chest freezer. Model 253.16582105. can't stop the beeping, even after replacing the 9 volt battery.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Mar 26, 2016 | Kenmore Refrigerators
Freezer bleeps as if door open. Temp goes down on its own
Kenmore freezer door alarm beeps but door is closed ...
www.shopyourway.com > Manage My Life > Questions
Every once in a while, the door ajar light goes on and the alarm beeps and will not ... Ifthe door is closed good and the door alarm is sounding, it will indicate the ...
How to fix constant refrigerator door alarm beeping? - Shop ...
The doors aren't open and we have checked the air flow vents and made sure ... We have to turn the alarm off to get it to stop beeping but I more concerned about ... If the fresh food section lights are working, meaning you can get the lights to go ... Thefreezer fan motor would need to be checked to make sure there motor is ...
Jan 12, 2016 | Refrigerators
I have a Kenmore refrigerator top mount freezer, which quite often starts sounding 3 beeps.
This refrigerator should have an alarm for an open door.
If the beeping is indicating a fault code, you should see this indicated on the display.
If no fault code is indicated and the alarm is due to an open door even with the switches pushed in, then you could have a bad door switch or a failed control board.
Oct 19, 2015 | Kenmore Refrigerators
There is a constant buzzing noise coming from the lower freezer ice maker. It is producing very few ice cubes. The control bar is down and in proper position to make ice.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
May 21, 2015 | Whirlpool Gold Series GB2SHTXTS (219 cu...
I hav a kenmore side by side refrigerator that makes a beeping sound in the. It's a triple beep not the door open beep its only in the morning 9:30 to 12:00?
Check the freezer. I think someone put an alarm clock in there. :)
Either that or it may be the water filter, times up, alarm.
Feb 09, 2015 | Kenmore Refrigerators
What causes my Kenmore to buzz when dispenser door is closed?
Sep 14, 2014 | Kenmore Refrigerators
Auto-defrost refrigerator freezer ice build-up
Check vents/grills to make sure they are dust free. May need to be replaced. In meantime, leave freezer door open to thaw away ice (remove food not wanting to get thawed)
Mar 06, 2014 | Kenmore Refrigerators
I have a Kenmore 18 refrigerator (freezer on top). When we open the refrigerator door, water drips down from the inside door panel.
Hello
Check you door and door gasket to make sure you have a good seal. What happens is warm air and moisture is getting in and condensing on the panel. I hope this helps. Please leave feedback. Thanks
Aug 25, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Beeping sound coming from control panel model#10656562400
Hi!
Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause which can't be lubricated or repair instead required to be replaced.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 01, 2009 | Kenmore 56562 / 56564 / 565 / 6656569 Side...
Freezer door not sealing
replace the seals and / or have the hinge adjusted
May 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
101 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
