Question about RCA RP5010 Digital Voice Recorder
My file also goes to the end of the recording without a sound
Has anyone solved the problem of the file going to the end of the file without hearing any of the recording. I too have the very same problem with very much the same urgency can anyone HELP....-
    President:
  • 566 Answers
No sound from speaker during playback?
• Make sure volume is not set to 0.
• Headphones should not be connected.
Posted on Jul 28, 2009
I have a number of files on my digital recorder where I have recorded interviews. When I press play, it shows up the length of each interview and the countdown starts, but there is no sound, just a qu
Did any of the files ever playback with sound? You can record sounds, but that doesn't mean the recorder is picking them up. A bad connection, level control setting could be wrong.
Try to do another short recording. If you are using a microphone pull the jack out during recording and put it back in again. Then listen to the recording. If there is sound when the microphone is in and it goes when it is out, then there is a possibility that somehow you recorded the other stuff with no connection and that's why there is no sound. If there is no sound on the new recording at all, then you might have a faulty playback amplifier inside the device.
Apr 09, 2017 | Sony ICD-B200 Digital Voice Recorder
Pontiac Trans Sport knock in motor
The best way to diagnose the noise is to hear it. Without hearing it all anyone can do is guess.
Is it a low dull thud? Goes up as the RPM go up? sound like its low in the motor?
That could be the lower end of the motor going out (worn bearings/rod knock).
Make sure you have oil in it.
Oct 20, 2011 | 1995 Pontiac Trans Sport
When i make a call or get an incoming call, i can hear people at the other end speaking. but they cant hear what i say. Please do assist me to solve this issue
It may be a hardware problem. to check it go to voice recorder in your phone in record any sound and save it and play it. if you hear good quality sound (loud and clear) then it is not hardware problem. try formatting your phone it will do for you.
and if you hear bad quality or not at all able to hear any sound of recorded clip then it is hardware problem. you can not fix it by yourself you have to go to mobile repairing shop and ask them to install new mike in your phone. it india it cost around Rs100-150.
hope this was helpful.
THANKS FOR USING FIXYA.
Mar 09, 2011 | Nokia 5200 Cellular Phone
My microphone will not work after buying a new keyboard
look at you Sounds & Audio Devices under the Control Panel, go to the Voice Tab and pick your Default Device to use as your Voice recorder
Aug 17, 2009 | Logitech 967437-0403 Keyboard
Not able to record onto Adobe Audition 1.5
Sounds like you do not have your audio recording source set correctly.  If you're recording from a file on your computer or a CD via the CD-Rom drive of your computer, you need to probably set the recording to either "Wave" or "What you hear", one of the two.  The "What you hear" can be easiest, but then again, if any other sound comes accross your computer at the same time, you'll end up recording that as well, so it's best to stick to "wave" if you can... or make sure all Windows sounds are turned off (Audio settings ->Sounds ->Select "No Sounds" as the theme).
Oct 25, 2008 | Adobe Audition 1.5
Inbuilt speaker is not working
u need check u r sound setting click on sound icon on u r taskbar and then click on properties and playback or recording click on microphone and try to scroll lolz try dear
Oct 21, 2008 | Compaq Presario 700 470024-192 Notebook
IHP120 20gb multicodecjukebox-voice recording
Sir,
I solved the problem .Actually under the SOURCE title it was under the LINE IN.There were some more options like INT.MIKE, EXT.MIKE, OPTICAL. So i first tried under external mike by connecting to the EXT.mike and selected the source and by removing the external mike switched to Int. mike and changed the source. It automatically picked according to the source and played the recording and saved it in the file and later heard the lecture with the head phone and later converted in to a file in the laptop. Now it is working nicely. A really a good product to make use and it is very much user friendly.
Thanks again.
regards
crsrinivasan
Aug 02, 2008 | iRiver iHP-120 MP3 Player
Casio CTK-720 USB computer/music connection
1.Download Audacity -
http://audacity.googlecode.com/files/audacity-win-unicode-1.3.9.exe
2.buy a cable for sound input, with 3.5" connector on both sides (like
the end of mic/phones)
3. connect cable from Phones/Output on keyboard to a PC where you
connect your stereo
4.run Realtek program for sound, go to Mixer/Record and enable Stereo Mix,
then in Audio I/O click on connected device and assign Line In.
%. Now run Audacity and start recording sound,you should hear your keyboard
May 16, 2008 | Televison & Video
Recording
The microphone on most of these slip cameras are very small and it is possible your finger or hand was over it. And to be honest since this microphone is so small the quality is not going to be very good at all. I don't know if there really is a solution to this outside of buying a high end camera if sound quality is so important.
Aug 11, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sound not recorded
You need an 1/8" male jack plug (both ends) cable. One end plugs to audio out on TV card, the other end plugs to audio in on the sound card. Or is it the other way around. Anyway, thats what you need. I think Radio Shack sells them maybe BestBuy or Circuit City.
Jul 02, 2007 | Philips SAA7130 TV Tuner/FM Radio/Video...
RCA RP5010 Digital Voice Recorder Logo
48 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
