All the lights flash on my modem when i connect the power
But when i connect to the internet it doesnt work and when i turn off my computer the model has the light of reiceive on and doesnt come off even when i turn on my computer what is wrong with it
Its a Scientific Atlanta Comcast modem DPC 2100
    Brigadier General:
  • 4,090 Answers
Try using the basic vanilla driver in mS windows
standard modem and see if that helps it may be an incompatibility in your operating system with the generic driver for that modem
Posted on Jul 28, 2009
2wire 1701 hg dsl connection drops when laptop is connected via wireless
This is a known issue with this model.. The power supply is not large enough to handle the extra current that is needed when the unit broadcasts on wifi.
May 05, 2017 | 2wire Computers & Internet
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
My modems LAN light is blinking and I can't get Internet, I've tried unplugging it, but the problem still exists, please help
There will be 4 lights...
Power
Dsl
Internet
Ethernet
Power light indicates power supply is good...
Ethernet light indicates connection between modem and computer is good...
DSL light indicates connection between modem and telphone line is good... Also DSL light should be steady and it should not flash...
If it flashes then it says there is a lot of noise in telephone line...
Internet light says whether the internet status is connected or not...Internet light can flash depending upon the internet activity...
Feb 03, 2011 | Paradyne 6381 ADSL2+/ReachDSL Router...
What does it mean when the far ethernet light is flashing fast and the cable light is flashing slowly. the power light and on line light are on steady. I have internet access when connected direct to...
Try this:
  1. Disconnect power to modem
  2. Disconnect power to router
  3. Shut down PC
  4. Wait 2-3 minutes
  5. Reconnect power to modem, and wait ~ 1 minute
  6. Reconnect power to router, and wait 30-60 sec.
  7. Reboot PC
  8. Try to reconnect to internet...
Jan 15, 2018 | Arris Touchstone 450a (CM450) Modem
I have an N+ wireless router that will not talk to my motorola SB5100 cable modem the modem and internet lights flash amber and the setup assistant does not help.
IF Your ISP is Cable then
Step 1 : Connect Modem - Router - Main Computer *(Wired)
Step 2 : Open RSP By typing 192.168.2.1 On the Address Bar of the Internet Explorer
Step 3 : On the left side under internet WAN Click Connection Type
Step 4 : Leave the password Blank And click Submit
Step 5 : Select the Connection type As Dynamic
Step 6 : Click Next
Step 7 : Leave the Host Name Blank And click Apply Changes
Step 8 : On the Left Click on MAC Address Cloning
Step 9 : Click Clone , Apply Changes
Step 10 : Turn off the Modem And the Router
Step 11 : Turn ON The Modem First, Wait Until All the Lights Are ON
Step 12 : Connect the Power To The Router
Step 13 : Wait for 5 Minutes
Step 14 : If The Lights Are Still Flashing
Step 15 : Connect Modem - Computer
Step 16 : Check if It is getting the Internet
Step 17 : If its Not then Restart the Modem And Try It
Step 18 : Make Sure You are getting the Internet When you Connect Modem - Computer
Step 19 : And after that Connect Modem to the Yellow Port on the Router
Step 20 : Check the Lights After 5 Minutes
If it is Still the Same then call Belkin Tech Support
The number is 1800-223-5546
Nov 07, 2009 | Belkin Computers & Internet
I CAN NOT CONNECT TO THE INTERNET ..using Linksy wireless remote
the wireless card installed to your computer is working..as you said you can view all wireless networks...your computer is good too...the only issue is you cant connect to the wireless router...
turn off and unplug the power cable of the Modem
turn off and unplug the power cable the router
wait for 30 seconds
plug in and turn on the modem, wait for all the light turn to solid green ( no blinking lights )
then power on the router
if you saw the wireless icon light turn solid...
go to your computer...right click the wireless icon...select repair
if this doesnt work....reset your internet router by press and hold the reset button behind the router near the power plug (atleast 15 sec)
then connect your PC..the wireless network dont have the WEP key anymore because of the reset..you can reconfigure and put back the WEP key when you get connected.
Mar 16, 2009 | E-Machines (T2958) PC Desktop
Wireless printer stopped printing-wireless router light flashing
Restart your Printer so that it can Look for the Connection again, if you havent done this already.
If this doesnt assist in the problem, please give me the complete Model Number for your printer so i can find the solution
Jan 14, 2009 | NetGear WGT624 Wireless Router
Doesnt connect
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, try to call supportrix and use supportcall as your promo code for 1 free technical support. :-)
Jun 08, 2008 | Linksys WRT300N Wireless Router
Arris cable modem
try shutting of your computer then shutting off the modem, the modems have batteries you might have to remove them theres usally a panel on the bottom, in the back you should have a wire for comcast cable and an ethernet chord telephone too if you have everything. also your modem could be broken, i had the same problem
Jun 06, 2008 | Arris Touchstone 450a (CM450) Modem
Motorola sbg900 wireless modem
have you tried powercycling your modem? turn of your computer, unplug the power cord from the back of the modem. wait a minute (literaly). plug power back into modem and wait for lights to come on and stop flashing. power computer back up. Check to see if connections works. Also check your cable connections between the modem and the computer. If all fails contact your Internet Service Provider, who most likely provided you with the modem.
Apr 08, 2007 | Arris SURFboard SBG900 Wireless Router...
Computers & Internet Logo
263 people viewed this question
David Payne
David Payne
