Question about Tomtom GO 700 GPS Receiver
TOMTOM GO 710
I charged the unit on the mains docking station overnight.everything looked fine,went to the car and the screen went blank and now does not respond.If I put it back on charge either in the docking unit or by the car cable,the green light comes on but it doesnt switch on.If I take it out of the chargers the green light goes off
  • ms07 Dec 26, 2007
    I have the same problem
  • aussie-girl1 Mar 21, 2009
    The green light comes on on the sat nav and on the in car charger but the sat nav will not turn on, I rely on my sat nav for work, can any1 help?
    P.
    Problem Solver:
  • 6 Answers
Could be a loose contact at the connection between the wire and at the gps unit.
Think the green light must be on at the charger port and also on the gps unit.
This green light can be found near the power button on the gps unit.
Posted on Dec 24, 2007
Will a kensington universal docking station work with my sony vaio pcg-7d2l
Yes it should if you are running Windows XP, Vista, 7 or 8. You just connect to the unit using a spare USB port on your laptop and a plug-plug USB cable. It has it's own power so you'll need a mains socket. This means you can unplug your laptop and leave any devices charging on the docking station USBs. Your laptop should auto-instal the station. I believe there is a table/support available which combines with this unit. There a varying prices for this unit so look around.
Good Luck
Feb 27, 2014 | Kensington SD400V USB Docking Station with...
Dropped on the floor and will not work. Got green light when plugged into car overnight but nothing on screen. Can it be fixed?
Well for a price, you must send back to TomTom. You can ask for a "Quote" before proceeding, they are a good unit,it may not cost too much, but factor in shipping too...
Mar 24, 2010 | Tomtom GO 710 Car GPS Receiver
My tomtom go 710 4v00 will not switch on
Fix it yourself, you need either a new battery and or motherboard. Relativly easy to do! 10 small torx screws for motherboard and 2 ribbons, then a few more screws and loosen the harddrive and screen for battery
Battey and motherboard for less than £50 pounds off ebay
Aug 09, 2009 | Tomtom GO 700 GPS Receiver
I lost the dock that connects to the computer
Your only option is to purchase another Home dock for your TomTom GO 510. The 510, 710, and 910 all use the same dock. The cheapest place to purchase a home dock is ebay. The answer to the second part of your question is no, you cannot purchase a usb cable to connect your TomTom GO 710 to your pc. The TomTom GO series uses a proprietary dock.
Jul 16, 2009 | Tomtom GO 510 Car GPS Receiver
Tom Tom Go 710 - Won't turn on
not sure but try an other device on the car plug to see if it works??????????? could be the plug.
Dec 17, 2008 | Tomtom GO 700 GPS Receiver
Battery replacement for TomTom 710
I have found a trick for those bad battery ,but you lose your waranty
you need to open your tomtom , behind the screen you wil find the battery(for the Go 710 it is an 3.7 V ,2400mAh,samsung ICR18650-24)
you find 3 wires : red, black,yellow cut them of at the half of the wire size
, then cut off your car loader wire (tomtom)(5v), you will see again 3 wires inside :red,black,white
connect the red with red, black with black, white with yellow
(the best thing is to make a little hole in the cover to pass the wire, so it will be beter for closing the all thing)
I did it and it works pretty fine ,I had save 30 dollars ;) :D
I did in approximatly 30 min
remember you will have no battery any more and no waranty of tomtom!
It only whorks then with your car loader tomtom
Jan 20, 2008 | Tomtom GO 510 GPS Receiver
DEAD PRESARIO 1925 NOTEBOOK
Try this, with laptop removed from docking unit:
1. Press and hold the laptop power button down, for 10 seconds.
2. Now remove the battery
3. Repeat step one above
4. Let the laptop sit for 10 minutes.
5. Reinstall the battery
6. Make sure docking station is unplugged, and insert laptop into docking station.
7. Plug in power supply (to dock)
8. Start the laptop.
9. IF IT STARTS, let it run a while to see if the battery is charging
10. Remove it from the dock and repeat steps 1-5 above and then go directly to 8 (start without connecting dock).
CONCLUSIONS: If the laptop started in the dock on step 9 but not 10 (only on battery), your battery or power regulator circuit may be damaged. However, if it starts in step 10 but not step 9, your docking station -or its AC power supply may be damaged Let me know how this comes out, please.
Jan 15, 2008 | Computers & Internet
Blank screen
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
If its NEW take it back!
or
contact tomtom about the problem...
http://www.tomtom.com/support/support.php?ID=2
Dec 16, 2007 | Tomtom ONE GPS Receiver
710 unit wont switch on again?off. 4 hour latter tried to turn it on again but does not switch on. Battery is charged but still not switching on?
Found the reset switch on GO 4V00.710 - look underneath, where the unit docks - small button - need a paper clip to press
Also, reset switch is documented in the Quick Start Guide - see label 'F' in the 'Your TomTom GO' what's in the box.
Dec 09, 2007 | Tomtom GO 700 GPS Receiver
Blank screen
To reset your TomTom device:
1. Charge your device.
Charge your device for at least 2 hours. Make sure the charging light on your device is on (except RIDER which has no charging light).
2. Remove the SD card.
If your device uses an SD card, remove it.
3. Reset your device.
Use a straightened paper clip, or something similar, to push the reset button. For a visual representation of the reset button, see below.
4. Turn your device on.
Press and hold the On/Off button for at least 4 full seconds.
5. Insert the SD card.
If your device uses an SD card, insert the SD card.
images of where to find the reset button can be found here.
Sep 04, 2007 | Tomtom ONE Regional Car GPS Receiver
Tomtom GO 700 GPS Receiver Logo
467 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
