SOURCE: i need codes
Sorry it took so long to respond to your request for assistance.[Motorola... 5000, 5002, 5003, 5028] These are the listed codes for your remote control to use with a Motorola cable box. I hope this information solves your problem, of needing the codes to use with the remote control and you Motorola cable box. Thank you for using FixYa and have a nice day!
SOURCE: looking for bushnell rifle scope repairs in Canada
the canadian office can be reached at 800-361-5702.
SOURCE: toliet won't get rid of solids
first shorten the chain from flush lever to the flapper valve by one or two links at a time until flushing properly
second the flapper valve might need a wipedown as well as its seal (top edge of tube where water goes down into bowl) the leaking is because the flapper valve is not seating properly.. you may need to replace the flapper itself.. easy to do, and a common part at hardware store.
SOURCE: I have a Paragon time
The following website that shows Paragon parts > the chart shows you need the X2772 tripper
http://www.icca.invensys.com/paragon/parts_accessories.htm
1) Here's a website that sells X2772 for the unreasonable price of $16
http://www.gellert.com/index.php?action=item&id=2684&prevaction=pricelist
2) Here's a website that sells X2772 for the unreasonable price of $9 (marked down from $13 whow)
http://www.frontierlighting.com/product.jsp?part=49598&process=search
Up-vote if this information helped. Thanks for the feedback.
SOURCE: when i flush the toliet
Make sure chain or rubber lift device isn't holding it up, or it isn't rubbing against side of tube beside it. A new flapper can be purchased at most hardware stores, and are easy to replace, if it comes down to that. Did this just happen suddenly, or was something adjusted or changed in the tank?
