Question about Brother HL 5250DN Laser Printer
I have a HL-5250DN and every time I print a document down the center fades out if not completly but usually only on a light gray color, sometimes however on black. Please HELP ASAP! Thank you in advance
    Brigadier General:
  • 4,090 Answers
I think in this case you need a new Fuser wire fitted
Posted on Jul 28, 2009
I've installed a new drum AND a new toner cartridge. have followed all directions to reset the drum and the light still flashes and I can't print, this is for a brother HL-5250DN printer
Try this....
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Jul 20, 2010 | Brother HL 5250DN Laser Printer
Brother HL-5250DN Laser Printer TONER LIGHT ON & NO PRIN PAGE
When the toner light is on this means the toner is empty and needs to be replaced before it can print again. Replace the toner and you will be able to print again.
Jun 05, 2010 | Brother HL 5250DN Laser Printer
The documents are faded even after putting in a new cartridge
  • make sure you are using inkjet papers as inkjet printers work on inkjet papers.
  • Lift the printer access door, then remove the ink cartridges from the printhead.
  • Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  • Close the printer access door.
  • Reprint the picture or document that had the quality problem.
  • if still light prints then proceed further
  • Print Test Page
  • Review the printed test page and verify that:
    • the left color blocks are gray, cyan, and black.
    • the right color blocks are magenta, yellow, and black.
    • each block is completely filled with color.
  • If no---> Clean Printhead, the On/Off light flashes during the cleaning procedure.When the On/Off light glows steady, print test page again.
  • If Yes---->The problem could be caused by the type of paper you are using.
May 28, 2010 | Kodak Office Equipment & Supplies
Brother HL-5250 printer toner Light on but Cartridge has Toner it
Try this....
Mar 08, 2010 | Brother HL 5250DN Laser Printer
Black stripes down paper
You remove the drum/toner cartridge and run the blue tab on top back and forth several times then blow out the slot with canned air, while it's out you reach inside with a soft cloth and wipe the narrow window above where the drum sits, open the back door and shine a light inside to see if the lines are on the fuser roller, if there you will need a new fuser.
Feb 01, 2010 | Brother HL 5250DN Laser Printer
I have a brother hl-5250dn with an extra tray for legal size paper. I have a problem printing loan documents sent via swiftview or elynx. I can only print on letter pages or legal pages but not both and...
Sounds like your secratery's printer is set to ignore paper mismatch errors. It depends on the setting you have in your driver. Can you set your driver on your printer to ignore paper mismatch errors. If not when your printer errors, just try hitting the go button and it should print the document any way.
Sep 07, 2009 | Brother HL 5250DN Laser Printer
All lights on solid, not flashing, wont print
Recommendation: See HL-5240/HL-5250DN USER'S GUIDE: Section (4), Control Panel: LEDs, (light emitting diodes) starting on pg. 44.
Apr 14, 2009 | Brother HL 5250DN Laser Printer
Brother HL-5250DN Laser Printer Problem
hmmm...so, your laser printer has a copy document feature? Is that in the printer management software settings, perhaps?
check here for latest print drivers
Mar 02, 2008 | Brother HL 5250DN Laser Printer
Brother HL 5250DN Laser Printer Logo
186 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
