Question about Samsung SF-330 Plain Paper Inkjet Fax
Machine sleeping even when re-powered on
We turned on teh machine after moving from one room to another.
(A book was left on the panel when the wire has been connected, and probably it pressed a button during the power-on.) Then the dispaly said "download waiting"... no lights or noises..and we waited too, for two or three minutes. Then nothing changed, and we disconnected and reconnected the fax machine. Nothing appears now on the display and, except for a "click" when it's powered, nothing happens. The fax machine seems to be dead.
Is there a solution?
  • 417 Answers
Re: machine sleeping even when re-powered on
Hi try changing the fuse in the plug first. Once you have done this then power in and open the cartridge cover and press the cartridge button. If the cartridge moves then the LCD has blown and will need replacing if nothing happens then unfortunately the power supply board has blown then replacing the whole machine is the cheapest option.
Thanks J
Posted on Jan 06, 2008
0 characters
3 Points
There is nowhere I can find whether I should switch on the Machine 24hr a day x 7 days a week. Or shall I swtich it off after-office-hours? Any effect on the life-span of the machine?
In a business environment most fax machines are left on 24/7......who wants to miss an order coming in because your fax was OFF. However, many fax machines can be programmed to go into a "sleep mode"...this would be in the evening when the office is still want to be able to recieve fax's if any come in..but you don't need the machine ON "fully" ready to print. Another-words, the machine is in a sleep/half power mode( because no-one is in the office to use it )..BUT if a fax comes in then the machine can still recieve it, then it "wakes-up" fully..prints out the recieved pages, and then goes back to sleep again. The details on how to program this function will be in your operators manual IF the feature is available on your model.
The benifits of programming a machine this way are pretty obvious...savings on Hydro, extended machine life ( due to machine going to sleep.) and yet you still dont miss any calls.
Pretty good hey.!!
Nov 07, 2010 | Brother IntelliFax-2820 Laser Fax
System error 004
E004 Fixing unit failure
E100 Scanner unit failure
E246 The Counter board is left out
E676 Communication error
E677/6F-61 ROM check error
E677/6F-63 RAM error
E733 A fault occurred in the communication between the SCNT board
and ECU board/TOP signal cannot be detected
New E805 Fan failure
Cause: (1) Shorted/broken wired main thermistor
(2) Shorted/broken wired sub thermistor
(3) Broken wired heater/blown thermal fuse
Solutions: (1) Turn the power off and remove the fixing unit from the machine.
Measure the resistance between the fixing unit connector J301-1
(FSRTH) and J301-2 (GND).
If the resistance is not within the range between 350 W and 520 W
(room temperature of 20°C), replace the fixing film unit.
(2) Turn the power off and remove the fixing unit from the machine.
Measure the resistance between the fixing unit connector J302-1
(FSRTH2) and J302-2 (GND).
If the resistance is not within the range between 360 W and 530 W
(3) With the fixing film unit removed, if there is no continuity
between the fixing unit connectors J303-1 (ACN) and J303-3
(ACH), replace the fixing film unit.
(4) Replace the EPU board.
(5) Replace the ECU board.
Jun 24, 2010 | Canon Fax Machines
The fax continually registers as being in "sleep" mode. Says it's in "Sleep" mode all day even when it is receiving and or sending out. How do I correct that?
Setting the Sleep Mode reduces power consumption while the machine is idle.
You can choose how long the machine is idle (from 00 to 99 minutes) before it drops into sleep mode.
The timer automatically resets itself after the machine
receives a fax or PC data, or makes a copy. The default setting is 5 minutes.
1 Press Menu, 1, 8.
2 Use the Dial pad to enter the length of
time the machine is idle before it drops
into sleep mode (00 to 99 minutes), and then press Set.
3 Press Stop/Exit.
Jun 15, 2010 | Brother IntelliFax-4100e Fax
Panafax UF-8000 not responding, energy saver light flashing.
It sounds like the operation panel is bad or has a loose plug.
Remove left and right top screws that hold the left and right panels on.
Wiggle the op panel towards you and up, check the white wire harness.
Good Luck!
Jul 07, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Print Unable 51 see Troubleshooting and routine maintenance
the purge unit is not functioning properly. it is a part of the machine that caps up your print head when not in use. it is not moving out of the way of the carrier for it to move properly.
turn on the machine, open the top cover . Unplug the machine. move the carrier to the left. Look to the right under the cover where the carrier goes back & fourth, see if any paper or fourn objict is in the area where the carrier sleeps. hope you fines somthing.
Jan 30, 2009 | Brother IntelliFax 1860C Plain Paper...
How can we exit Sleep mode?
what was the password to remove form the sleep mode
Aug 28, 2008 | Brother IntelliFAX 4100 Laser Fax
How do you turn on a Xerox 7232 copier that is asleep on power save?
You should just be able to press any key. You can go into the customer programs and set the sleep mode to 4 hours before going into sleep mode.
If the machine has been idle for more than 4 hours, it will physically turn the machine off, I will look up the adjustment and post it back to you here in a couple of minutes.
Jul 23, 2008 | Xerox Fax Machines
Brother intellifax 4100e
Hi, the error code refers to the heater thermistor short circuited or heater thermistor disconnected or broke when the power was turned on, front cover is open or closed or when the machine exits from sleep mode.I hope this help!!
Dec 04, 2007 | Brother IntelliFAX 4100 Laser Fax
Can't receive outgoing faxes, but CAN receive in-house faxes
Oct 23, 2007 | Brother IntelliFAX 4100 Laser Fax
Samsung SF-330 Plain Paper Inkjet Fax Logo
63 people viewed this question
Top Samsung Fax Machines Experts
Kevin Cole
Level 1 Expert
Paul King
Paul King
Are you a Samsung Fax Machine Expert? Answer questions, earn points and help others
