Question about Hayward Navigator Pool Cleaner
Cleaner goes in cicrles and the hose gets all tangled up.
My Hayward cleaner had some junk stuck inside, so I took it a-part. After I re assembled it, it has been working very badly. Problem is that it seems to be somehow tangling up the hose. After I untangle the hose, it takes less than one hour, and it is all tangled up in big nuts so that the cleaner is unable to go very far.
Can someone help?
Victor.
PS: I am not sure if I have put the 'Red Wheel" in exactly the same position that it used to be before I had taken it apart.
  • 366 Answers
Make sure the bearings are installed properly, there is a groove where the bearing sits and the bearing should have a spline that will match up with the groove in the turbine and housing. Also, check that the bearings on the a-frame spin freely and all the bearings are in place. Also check that the right and left pods are tightened sufficiently.
Posted on Sep 16, 2009
How can I stop my aquadroid hoses from getting tangled up during cleaning. How can I fix this?
these little gems of technology are supposed to rotate on the top pipe so that the hose doesnt tangle. if you can grab the pipe and gently rotate it, the hose might just be too long.
Jun 28, 2014 | Hayward Aquabug Above Ground Pool Cleaner...
My Hayward pool cleaner hose keeps getting tangled
check to see if swivels are free if not move them or replace also cold water will do it
Aug 24, 2013 | Polaris 3900 Sport Pool Cleaner ()
VIPER 5500 SPINS AROUND IN CIRCLES CAUSING HOSE TO GET TANGLED. ANY SUGGESTIONS WHY?
There are a couple of things that you should try if this pool cleaners hose is frequently becoming tangled. Make sure that your floats are evenly and correctly spaced. One float should be 18" inches from each end and a third float located in the middle, 5 feet from either end. You should also make sure that the hose length is not too long for your pool size. Your spin out might be too high. Try moving it to a lower setting and then running the cleaner again.
May 10, 2011 | Hayward Viper Pool Cleaner
Hose getting twisted
It could be a steering error that is causing it to tangle the hose. Try these suggestions first. Check and clean the rear screen. Make sure that you cone gear is free and rotates smoothly. Also check your turbine and spindle gear assembly. You will also want to try readjusting your return lines to redirect your cleaner. A common problem with these pool cleaners is that the return lines are directing them to circle, causing the hose to tangle. Finally, make sure that you are storing the hose in a NON-coiled position. If you coil the hose, it will cause it to be permanently bent and interrupt movement. If you have done this, lay the hose out flat in the sun for a few hours to help mold it to the original pattern.
Apr 29, 2011 | Hayward Navigator Pool Cleaner
The phantom just goes around in circles & gets tangled until it stops.
It sounds like the gear box has failed inside the unit. Causing it to not go straight anymore. Replace the gear box assembly.
Apr 02, 2011 | Hayward Phantom Pool Cleaner Complete with...
Why is my phantom cleaner stuck spinning in a circle?
It is most likely that your hose is bent. Check the hose at the hose cleaner end assembly. If you notice that it is bent or warped, lay the hose out in the sun (stretched out) to try to remove the bend. Make sure that you are not storing your hose in a coiled position. This will cause this. It could also be that the pressure though your pool cleaners too high.
Feb 21, 2011 | Hayward Phantom Pool Cleaner Complete with...
I HAVE HAYWARD NAVIGATOR POOL CLEANER. MY HOSE TWIST UP WHEN IN USE.
With these pool cleaners, it might not be the hose. It could be that your cleaner head has water and is floating, causing the hose to tangle. Check for that problem. If not, it could be that your hose is too long for the pool size that you have. You might need to remove sections on the hose to shorten it.
Feb 15, 2011 | Hayward Navigator Pool Cleaner
Hose gets twisted all of the time Have replaced almost everything
Try laying the hose out on the ground and stretching it out as straight as you can get it. Let if sit this way in the sun for several hours. You might have a warp in the hose material that is causing these tangles. Allowing it to sit stretched in the sun for several hours will help. Also, try readjusting your return lines. They could be interfering with the pool cleaners pattern and causing the cord to become tangled.
Aug 20, 2010 | Hayward Navigator Pool Cleaner
Navigator Pool Cleaner: When I run my hayward cleaner the hose twists up a...
You have either a bad or stuck gear box or a loose or damaged a frame bearing. The gear box controls turning and the a frame controls propulsion, but one bad bearing will cause the cleaner to move more in one direction, causing the hose to coil. You can hold the cleaner under the water by the top of the hose, and it should turn in all directions within a few minutes. If it doesn't, then it is the gearbox. If it does, then likely a problem with the a frames.
May 16, 2010 | Hayward Navigator Pool Cleaner
The hose gets tangled and then the cleaner stops
This is probally your upper gear box. If you take your head to your pool store they will usually work on this for just the price of parts.
Feb 24, 2010 | Hayward Navigator Pool Cleaner
Hayward Navigator Pool Cleaner Logo
638 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
