Hi, my turntable Sansui P-L51 is lock,the table doesn't turn and arm block,I have the power.So how can I unlock it. Thank you for your help.Michou
CompuGuy44
  • 432 Answers
SOURCE: Suitcase Turntable stopped turning
It you hear the motor spin and nothing is moving, the belt could be broken.
Posted on Jul 07, 2007
  • 864 Answers
SOURCE: table does no rotate
If it is belt-driven the belt may be broken or fallen off.  Lift the turntable to check underneath.  There may be a spring clip near the center of the turntable that you have to remove to lift it.
Posted on May 20, 2009
  • 8404 Answers
SOURCE: Background hum from speakers when turntable is
You need tro ground the Zero 100 to the amp frame. Also, you may want to reverse the plug in the outlet, if that is an option (Try to plug the turntable into the amp if possible) Keep trying different arrangements until you minimize the hummmmmm
Where the heck did you find a Garrard Zero 100? That turn table is at least 35 years old ... I have one, BTW and that is how I solved mu 60 cycle hummmmmm
I hope this helps you
Positive comments welcome
Thanks for using FixYa.com
a
Posted on Oct 28, 2009
SOURCE: Technics SL-5 Turntable will not turn.
now iam using the technics sl-5 turntable.it is tonearm damaged.
replacement tonearm are available? or pl inform tonearm model number
Posted on May 12, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have a problem with a Sansui turntable
Linear tracking tonearms probably don't move much under manual control. It would still help if we knew the model number.
Posted on May 17, 2010
Want to unlock sansui turntable p-l51
I don't know what you mean by locked, but if the table won't move and is locked in place, you probably still have the shipping screws in place. Remove the rubber mat and the platter. Under there, you will generally find red screws or screws with tags that must be removed to allow to platter to turn. For more information, please visit my website at audioserviceclinic.com. Thank you.
Dec 04, 2013 | Audio Players & Recorders
Turn table arm will not move freely, table wont turn, cueing light bleaking
I would need more information, starting with make and model number. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 25, 2013 | Audio Players & Recorders
Turn table doesn't start when tone arm is lifted
Did it used to start when you lifted the tonearm?
Many turntables start when the arm is moved over the record.
Jan 29, 2013 | Audio Players & Recorders
Why does my turntable not spin when I move my Tone arm over?
Hi Daniel, its a bit of a long shot however try this. With the turntable powered of manually rotate the platter approx 12 times to reset the auto operation back to default. John styluscity.com
Nov 30, 2011 | Sony PS-LX250H Turntable
It doesn't work. I have followed the instructions though i couldn't find the EG switch but the table doesn't turn when its plugged in turned on and started.
hi,
check whether you have inserted the belt or not. in new turn tables you hvave to set the belt in proper position before starting use. u have to make the belt engaged with the motor pulley.
I have added here a video which demonstrate the installing of belt in a turn table.
In your turntable you can see the belt under the plater when u remove the plater.
remember one thing after installation of belt before plugging it mains , do the following
1. lock the arm in the arm rest
2. rotate the plater 10 times with you finger (for resetting the start position
Then connect the power release the arm lock insert a record press start
If you need any further assistance from me , feel free to contact me through fixya
ok
Jan 17, 2011 | Sony PS-LX250H Turntable
May 17, 2010 | Audio Players & Recorders
I HAVE A 1951 AMI D-80 JUKEBOX,THE TURNTABLE IS JAMMED.
There are two motors with beige/tan plastic covers over them, one on turn table platter and the other on the record changer mechanism table. Take the cover off the one on the turntable and spin the motor by hand. Depending on how you spin it the arm will either go back up or down
Jan 03, 2010 | Audio Players & Recorders
Have a Sansui compu edit p-m70 turtable. I turn
Lift off the turntable mat and the platter. Near the tone-arm, remove two screws holding down a panel and then inspect the tonearm belt. They wear out and stretch out and this could be the problem. Replacement is easy and does not require any special tools or further dissasembly.
Lock light indicates that turntable platter speed has reached correct speed.
Aug 21, 2009 | Sansui Audio Players & Recorders
Sears Tape deck/Turn table skipping!
Hi the pennies will mess up the stylus. There should be an anti skate setting at the back of the turn table, a round adjustable bit with numbers, increase the anti skate and then use the balance weigth (weight right at the back of the arm that turns to get the weight right. Set the anti skate with the tone arm light, then increase the weight a bit. Hope that helps
Jun 14, 2009 | Technics SL-1210 Turntable
try gently pushing the tone arm (actually the piece of plastic holding the tone arm) over to the right a little. works for me, but it still gets stuck often
Apr 06, 2009 | Audio Players & Recorders
245 people viewed this question
 Grubhead
Grubhead
