Question about Eureka 5892AVZ Bagless Upright Cyclonic Vacuum
Belt how do you put on a new belt?
  • 1,673 Answers
Turn vac over, remove 4 or 5 screw, then the top cover should come off, the belt is a cogged belt # 72393. Belt goes between the brush roll motor and the brush roll.
Posted on Jan 15, 2008
New belt now harder to push than before
the new belt already snapped is what it sounds like try taking it into guarantee vacuum and sewing center
Mar 26, 2014 | Dirt Devil Featherlite Bagless Vacuum...
How to put a Kirby Vacuum belt back on New belt seems too short
To put on a kirby belt all you need to do is put on the belt on the brushroll, put the brushroll into the housing making sure the marks on the end of the brushroll are the same. Take the spin dial in the front and "hook" the belt till the dial reads off. Put the head back on the machine and spin the dial to "on".
Jan 27, 2010 | Kirby G5 Bagged Upright Vacuum
How do I change the belt?
Turn the vacuum over so the bottom is up.. Remove scews from plate surrounding the brush area..
Pop of the cover plate..
Lift out the side of the brush that the belt connects to..
Put new belt on..
Put the brush back in place.. It might be a bit tough because the new belt will have a bit of tention..
Put plate cover back on and screws..
Jul 28, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
How do I put a new belt on Hoover Concept One vaccume cleaner?
you most likely have to remove the cover over the roller, which has screws usually. then you will see the belt. the roller slips out replace the belt by putting it over the roller and a metal rod that is up under the cover you removed. this will be a hard job putting the roller bar back in the vacuum because the belt is so tight.
May 18, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Cannot fit a belt to hoover whirlwind
on the top of the base you will see three slots on each side of the top of the base the middle slot has a screw one on each side take those out and the cover will lift will be at the roller and belt.lift up on the roller and put it on the side .you must clean the old rubber left on the motor shaft first before installing the new belt.otherwise the new belt won't last long.slip the belt over the motor shaft then put your roller brush through the new might have to pull forward on the roller to get it in place because of the new belt ,they are a little tight at the beginning.then alighn your roller ends and put the roller back in their slots.turn the roller by hand till the belt in in the middle of belt guide on the roller .now you can put the cover back on .then your in buisness.
Apr 10, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hi This is quite complicated but I'll try and simplify this for you:
If this is a Panasonic upright then there are two drive belts as you know. Once you take off the sole plate (where the beater bar is) by undoing screws and the beater bar is looking at you, you would have to take off the smaller belt motor pulley first before putting on a new larger drive belt. If the smaller belt is still intact and you only need to replace the larger belt, you'll still have to take off both belts to put on the new drive belt.
Motor pulley belt has to be taken off first then the old drive belt, then grasp the beater and slide on new larger drive belt before having to attach the motor pulley belt and then the larger belt onto the motor pulley. Once all belts have been attached ensure that the beater bar is pushed in correctly before you screw the sole plate back on.
Apr 03, 2009 | Panasonic Vacuums
How to replace a belt successfully on a Bissel Powrforce 3522?
How do I replace the belt? I don't know how to get into that area.
May 21, 2008 | Bissell 3522 PowerForce Bagged Upright...
Eureka 5892AVZ Bagless Upright Cyclonic Vacuum Logo
73 people viewed this question
Top Eureka Vacuums Experts
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
