Question about Samsung L100 Digital Camera
All of a sudden became blurry when viewing through lcd screen and the pictures are blurry when downloaded on the computer
  • 744 Answers
Hi..
You can try a different memory card, but I don't think the problem is memory card, if pictures look scrambled, and colors and brightness are not uniform, that is either a problem with CCD sensor (optic sensor that takes the picture), or logic board.
In either case, this is not an easy repair.
Reset the camera to default settings from camera menu, and try a different memory card, but the camera will probably need to be sent in for repairs...
thank u
rate me!!
Posted on Jul 28, 2009
Actually upon googling the same issue I came upon this site. I found that by pulling ever so slightly on the zoom lens, the image came into perfect focus. Which indicates an issue with the motor, and the zoom function. With my gf's camera, the lens was not extending all the way. So I gently pulled the lens out a little further. It solved the problem, but upon turning off the camera, I had to nudge the lens into the camera a lil to get it to retract. If not, the motor kept running. Do not touch the lens itself, but the housing of it.
Posted on Oct 16, 2009
The camera took great pictures then all of a sudden the screen appears as a purple haze -- and the pictures come out as just a purple blurry haze. Adjusting brightness doesn't work. Yet, the shutt
If the LCD displays correctly on previous photos then the problem is more than likely a CCD or associated ribbon connector failure due to moisture/condensation or age/misuse. Good luck with finding a replacement part!
May 31, 2012 | Panasonic Lumix DMC-TZ3 Digital Camera
VIEW SCREEN IS SO BLURRY I CAN'T TELL WHAT ITS SHOWING.
Is it the viewfinder (that you hold up to your eye) or the screen that's blurry?
If the viewfinder is blurry, there should be a diopter adjustment to fix it, probably right above the rubber eye cup.
If the screen is blurry, you should take some pictures and video and view them on a computer. I they are sharp on the computer but blurry on the camera screen, there may be a problem with the screen and you may need to take it in for repair.
If the pictures are blurry on the computer as well, the camera may not be focusing properly. If you can't focus manually, or the camera can't focus when auto focus is turned on, you have good light, and aren't too close to your subject, then it may need to be serviced.
Feb 26, 2011 | Sony Cyber-Shot DSC-F717 Digital Camera
KODAK EASYSHARE V803 LCD REPLACED!!
you should call KODAK Technical Support thru this number 1800 235 6325 op 12 op 2
Aug 23, 2009 | Kodak V803 Digital Camera
My Minolta Z6 used to take clear pictures. Suddenly almost every image became is blurry. I then stored for about a year, now I have cleaned the lense to no avail. Focus l through lcd screen is also now...
I think you may be doing what I have ben doing. The auto focus beam I think emits from the small sender between the hand grip and the lense portion of the camera, ( Bad Design) When gripping the camera my fingers sometimes block the sender and causes it to be blurry as in not focused. .Try to keep your fingers from going in between the grip and lens and I think it will work for you.Let me know if this helps. I am so glad I found this out because this camera takes nice pictures.
Bob zeisjr@aol.com
Jun 26, 2009 | Konica Minolta DiMAGE Z6 Digital Camera
Blurry streaked lcd screen, blurry picture results
call SONY it is a known problem they will do it FREE just call them see link for sample service advisory dont worry if ur model is not there just call and ask them about BAD CCD
Kindly rate me WELL !
May 31, 2009 | Sony Cameras
Lumix FX12 LCD screen shows purple haze
raegag
wsd*g
jagskfsda
vwomcjcwkjksdfs;adjkfksjcvijsiarue45646514sd5v13sd4f86vaf21g623g4f861++-+sv+svgsfgsg+fgasvcsdgwg
the answer is 123456789654321456789654123 dota boysssssssssss
Jan 16, 2009 | Panasonic Lumix DMC-FX12 Digital Camera
NEC flat screen monitor reset screen keeps popping up.
Call 800 836 0655 and ask for directions from tech support.
Nov 14, 2008 | NEC AccuSync LCD71VM 17" LCD Monitor
It became blurry
Are you using the auto function on the disc on top? If you are not it may be that your lens is open for too long.
I often get the same problem when using any other option as I'm not a pro, and when I zoom in very close on something far away.
Dec 06, 2007 | Samsung Digimax S730 Digital Camera
Samsung L100 Digital Camera Logo
257 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
