Question about Bosch Classixx WFL 2066 Front Load Washer
Fuses for a bosch washing machine
Exactly where are they? and what do they look like.
  • 631 Answers
You might try this site. They have diagrams of a lot of different appliances.
http://www.appliancepartspros.com/partsearch/
Posted on Jul 28, 2009
Bosch washing machine logi xx7 no power cant open door. fuse ok
Check power at outlet and make sure you are getting power to the machine. If you are then the board on the machine may have had a surge and burned out
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Sep 25, 2016 | Bosch Washing Machines
My Bosch 1244E will not go on I plug it and no power?
Washing Machine Won't Start - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 21, 2013 - If wall socket & fuse are OK but washing machine won't start ... didn't work - so I tried plugging my Hoover washing machine into another plug and all systems are go! ... I have a bosch washing machine which is 16 months old.
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - Washing machine will not start, no power. ... So begin at the plugand make sure that there is power to the socket and that the fuse is okay ... I have aBosch washing machine which is leaking from underneath and the water is coming out the front at the bottom. .... It washes but won't go into rinse or spin.
Washing Machine Will Not Start - What To Check - How To Fix
removeandreplace.com/.../washing-machine-will-not-start-what-to-check...
Apr 10, 2015 - Be sure the washer is plugged into the electrical outlet in the wall. ... If the lid switch is faulty, then the washing machine will not start. ... If the lid switch is being pressed but no power is being supplied to the washers motor, ..... October 28, 2014; Bosch Washing Machine Error Fault Codes October 28, 2014 ...
Dishwasher Will Not Turn On - How To Fix ...
Jan 19, 2016 | Bosch Washing Machines
Bosch exxcel 8 washing machine, display dead when you turn on and door locked, fuse is fine..
probably the main board, you need a proper machine expert these day to reset the codes, designed so only they can do it.
Aug 17, 2014 | Bosch Exxcel 8 WAQ28461GB White 598 mm...
Can't get a Bosch MAXX 5 WAA24161GB to start. Changed fuse and socket, but machine still won't work?
hello, have you checked the glass fuse inside the washer make sure you use the same rated fuse the value will be on the end of the fuse hope it helps
regards
shaun
Mar 06, 2011 | Bosch Washing Machines
How do i fit a new door seal to a bosch washing machine
This video will show you how to change a door seal on this Bosch front loader washing machine
Aug 22, 2010 | Bosch Classixx WFL 2066 Front Load Washer
I have bosch classic, the fuse goes off after 5
Make sure you hace a 13 amp fuse fitted in plug.
Could be a faulty heater element.
Locate heater,remove connections to heater and try without the
heater.
If it still blows, then could be a faulty motor, unplug motro, and try again.
Hope this helps.
Jan 12, 2010 | Bosch Classixx WFL 2066 Front Load Washer
I have a Bosch Exxcel 1400 S Express which blew
There is no internal fuse in the washer to replace.
If you have replaced the fuse, make sure that is is a good one.
If you are satisfied that you have power to the washer, then I'm afraid it sounds quite serious.
Trust this helps.
Dec 04, 2009 | Bosch Washing Machines
My washing machine keeps blowing he fuse in the plug
That means that there is a short or a contact inside the machine.
The short can be on power cable, on control panel, on in the internal wiring harness.
Apr 13, 2009 | Bosch Classixx WFC 2465 Front Load Washer
Door open? is displayed
Exact same problem happened to me (door open? when start button pressed); was not the machine, it was the wrong volts. An electrician tested the wall plug (it was 110) and changed the fuse in the fuse box to 220 volts and has ben running smoothly.
May 28, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
203 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
