Question about HP Vs17 17" LCD Flat Panel Monitor
HP vs15 monitor Flickers then blacks out.
I can make it work for like 5 seconds when i power off then on the monitor.
Then again it flickers and turn off. I checked/changed the cord nothing happened. The Computer is just fine. Can someone Help me out? please
  • 748 Answers
Hello
This monitor has 5 capacitors in the power supply that age prematurely. I can repair this for $50.00 +parts + shipping. Or you can take it to a local repairperson.
Posted on Jul 28, 2009
My monitor (HP vs15) is flickering for about 5 seconds and then goes black. I managed to get it to turn back on and stay on, but now it is very dim.
It sounds like the LCD inverter is dying.
It would be cheapest to have it repaired but it would make the most sense to buy a new monitor.
If you have it repaired it might just be another part that dies next week.
Mar 06, 2011 | HP Computers & Internet
Sounds does not work even trying to check it over and oveR. It also flickers and light comes too fast or is to blurry.
you may have an issue with the main board.
Flickering is a result of a malfunctioning inverter which also ties to the power supply which will not allow voltage to the sound module if built into the main board. You monitor will need service.
May 01, 2010 | HP vs15 15"LCD Flat Panel Monitor
HP monitor vs17 goes black with power light flashing
I have repaired an HP 1702 monitor that had similar symptoms by replacing the capacitors on the power supply board but you have to have some electronic knowledge and do some soldering if you can buy the replacement capacitors($10+/-) from a supply store. They (at least 1) will be swollen up on the ends and may have a tar-like substance leaking from them. It is best to replace them all (may be 4 depending on the model).
Jan 08, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Acer al2002w flickers and goes black
Hi....there,
Well, you've got a busted backlight inverter... Need to replaced a new one...
Nov 30, 2008 | ViewSonic VX2025wm 20.1" LCD Monitor
Flat panel hp f1503
Most likely you have degraded electrolytic capacitors in the internal power supply. If you can disassemble your monitor to liik at the power supply board you might notice bulging capacitors which if replaced will likely restore normal function.
Mike
May 29, 2008 | HP vs15 15"LCD Flat Panel Monitor
Black screen
Hi
my problem was fixed by viziks from FixYa dated Sep 12
replaced 2 push pull transistors 2sc5707 in high voltage transformer circuit
Transformer used for backlight lamps
Both monitors now working THANKS VIZIKS
Feb 09, 2008 | HP vs15 15"LCD Flat Panel Monitor
Power button stay on for 2 seconds, black screen,no picture
hi there, yes, you do have a broken monitor, bring it to qualified service personel how can repair the monitor. or you can just simply replace it. TY
Nov 29, 2007 | HP vs15 15"LCD Flat Panel Monitor
HP 15 in. Flat panel Problem
plug in a different monitor temporarily, check your display settings (right click background, settings, advanced, monitor) and set refresh rate to 60hz. plug in this monitor again and see if that helps some monitors (lcd's especially) cannot handle beyond 60hz
Aug 14, 2007 | HP vs15 15"LCD Flat Panel Monitor
Hp vs15, black screen, power light goes on and off like it is in sleep mode
Monitor is dead. The LCD inverter board probably went out and needs replacing. More than likely, it will cost you over $100 to get it fixed. It's better to spend the money on a new monitor.
Jul 13, 2007 | HP vs15 15"LCD Flat Panel Monitor
HP Vs17 17" LCD Flat Panel Monitor Logo
729 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
