SOURCE: not charging battery
hi
Check the alternator,it charges the batteries when the engine is running.
best regards savumihai71
SOURCE: i want to change the
I have a 2003 Foreman ES and the engine and transmission share the same oil on mine.
SOURCE: My Gateway went black screen no lights what happened
Hi flady_98,
You don't specify model, so what follows is fairly generic. If you can provide more details, perhaps I can too.
If it's booting (start-up chimes/sounds), then I'd suspect the display (either the back-light, or perhaps the inverter/controller circuit board). Backlights require (in my experience) replacement of the display, likely more than the value of the laptop if it was a refurb (~$500 and up in my exp.). Inverter boards are less spendy, but you have to get the right one, and get it installed (how tech-savvy are you?)
If it's not booting at all, (don't hear the hard drive spooling up, etc), then we start looking at power supply issues and go from there. But I really need more details.
If I can be of further assistance, let me know, and include as much
detail as possible (you should be able to load digital pictures onto
this space using the toolbar above).
If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
SOURCE: Will not crank, battery is good, starter has been
If automatic....neutral safety switch or anti theft.
If manual trans....clutch safety switch or anti theft.
