Question about Toys
Hummer Electric Riding Toy Won't Run
Two years old, battery is fine. Just suddenly started making terrible noise when you push gas pedal in any gear and doesn't move. Took it apart and noticed gray round cylinder looks like it has come loose from the car. When you hold it tight, the noise stops and wheels move, so makes me think this is the problem. Previously heard that this thing is the motor and that the gears aren't meshing. Question is, how do you fix this? Can't figure out how to get this cylinder off. Thanks.
  • 850 Answers
Remove wheels & pull axle through to release the motor/gearbox combo
Posted on Jul 28, 2009
On my 4 year old son's John Deere gator prediger riding toy when you put battery in it goes before you push the accelerator?
it sounds like the foot switch is wired backwards or if the switch was put in backwards. I would take out the foot pedal and check the switch and make sure that is wired correctly.
Apr 20, 2015 | Toys
Replaced shifter and gas pedal on gator and still wont run?
check the battery with a multimeter and make sure that its putting out at least 12 volts
Aug 15, 2011 | Peg Perego John Deere Gator HPX Ride on...
Push the gas pedal and switch gear just maks a click noise i replaced that thermal fuse but still just clicks. i relaced the switches and pedal and battery. im runnin out of things to replace. please help
I had this same problem with a turf tractor and it ended up being a bad motor, so disconnect one of the motors and see if the problem persists if it does then disconnect that motor and reconnect the other motor and see if the problem persists, if it works fine with one motor connected but not the other then the disconnected motor is probably bad, but then i would test the wires from that bad motor on the good motor just to make sure that the wiring isn't bad
Aug 08, 2011 | Peg Perego John Deere Gator HPX Ride on...
Ranger on a full charge stops working within 5 minutes. After 3 minutes or so, it runs again. Is the battery fried? Or is it overheating? It is aprox 1 year old. It is being run on flat ground. Please help
If power stops abruptly then theres a chance there coul be a loose connection and needs investigting. If power winds down and stopsthen yes the battery is probley fried.
Jul 16, 2010 | Polaris Ranger RZR Ride on Toy
Gator stops suddenly and will not go with pedal depressed.
it could be a switch problem, or loose connection. I use the repair help at
http://www.mypegperegoparts.com/ when I need repair advise for these toys.
hope this helps
Jun 01, 2010 | Peg Perego John Deere Gator HPX Ride on...
I have a little tikes 451 K Hummer h2 riding toy,
Hi Susie,
There are several options available.
There are numerous new chain stores popping up that specialize in batteries only. Batteries Plus, Batteries Only, etc.
These type batteries are usually sealed lead acid. So another alternative is an auto parts store for a motorcycle battery or a lawn garden dept, for a riding mower battery.
Just bring the old one with you to get the size right. You want to make sure it fits and the terminals should match.
Best regards
Mike
May 06, 2010 | National Little Tikes Hummer Yellow
Hummer is 2 years old and no longer working.
That cylinder is the motor. the gear are not meshing and they are grinding on each other.
Jul 10, 2009 | Toys
Rear wheels-
Both wheels should spin in 2nd gear. Only one wheel may spin in 1st, but if you put a little pressure on the one wheel that spins it should make the other wheel start spinning.
But both wheels should spin in high gear at the same time.
Hope this helps. If there is more help you can also ask these guys at this website. http://www.shopjandl.com/ I get my parts from them and they seem to also work on them as well
Apr 17, 2009 | Peg Perego John Deere Gator HPX Ride on...
Toys Logo
199 people viewed this question
Top Toys Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
