Question about RCA F32650 32" TV
RCA 35" TV
TV does not turn on by power button or by remote. Makes a chirping sound when plugged in to the electrical outlet?
    Genius:
  • 1,694 Answers
Bad IHVT transformer part # 257805 or ASTI 2078......T.
Posted on Dec 11, 2007
When I turn on my Sony TV, ti stays on about 30 seconds then shuts off, What do you think is wrong?
Do a Power Reset.
1. Turn off TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If issue persists after doing the steps, reset the TV to factory default settings.
1. Turn on the TV.
2. Using the supplied remote, press and hold the UP arrow button.
3. While holding the UP arrow button press the POWER button on the TV itself.
4. When the TV goes off, release the POWER and UP arrow button.
5. The TV will turn on by itself and the initial setup screen will be displayed. Just follow the on-screen prompts to finish the setup.
Sony KDL 46V5100 random shut off 15 20 sec
Feb 25, 2016 | Sony Televison & Video
TV WILL NOT TURN ON
      NOTE: If the TV turns on and off using the POWER button on the TVbut does not respond to the POWER button on the remote control, troubleshoot the remote control. Unplug the TV power cord from the electrical outlet for 30 seconds. Plug the power cord into a known working electrical wall outlet.Aug 15, 2015
      The TV will not turn on or does not have any power. - SONY
      https://us.en.kb.sony.com/.../the-tv-will-not-turn-on-or-does-not-have-any-...
    Feedback
    TV Will Not Turn On - Troubleshooting Help for Finding ...
    ? 2:32
    https://www.youtube.com/watch?v=kEDVc-BXf0I
    May 1, 2014 - Uploaded by ShopJimmy.com
    TV Repair Help for a TV that Will Not Turn On - Troubleshooting Tips for finding symptoms and causes of ...
Jan 14, 2016 | Televison & Video
My tv is not working right with picture.
Press the TV button on the remote, make sure the TV is plugged in, check the electrical outlet to make sure it is live if the TV does not turn on. If these actions do not solve the problem, press the Power button on the front of the TV. If the TV turns on, replace the batteries in the remote control and reset it by pressing the number 1 button for 60 seconds. If necessary, reprogram the remote.
Unplug the TV for two minutes, then plug it back in if the buttons on the remote don't work. Make sure the remote is in TV mode.
Change the settings on the sleep timer if the TV turns off unexpectedly. Unplug the TV and wait five minutes before plugging it back in if necessary.
Check your antenna connections and cables if the sound is okay but the picture is poor. If all the connections are good, adjust the sharpness function.
Jul 21, 2011 | RCA 20F512T 20" TV
My tv won t turn on i just purchased it today i plugged it in and it won t turn on
Check the electrical outlet which the tv is plugged into. Make sure nothing is loose at the outlet as well as on the back of the tv where the power cable plugs in. Another thing to try is plug a different device into that same electrical outlet and see if it turns on. If it doesn't turn on, it could be a faulty electrical outlet. If you've tried both the remote & the power button on the tv, a shot in the dark would be to change the batteries in the remote.
You could always try calling their tech support at 1-800-256-2487. A last resort would be to return the tv from where you purchased it.
Mar 09, 2011 | Emerson Televison & Video
Remote control work very slowly and sometime do not work
Please follow the troubleshooting steps:
  1. Remove the batteries from the remote control.
  2. Press each button on the remote control twice.
  3. Make sure none of the buttons on the remote control are jammed.
  4. Install fresh batteries into the remote control.
  5. Make sure nothing is blocking the Infrared (IR) sensor on the TV.
  6. On the remote control, press the TV FUNCTION button.
  7. Press the POWER button and other buttons to test the operation.
  8. Try using the remote control at varying distances from the TV.
  9. Power reset the TV by follow the steps:
  • Unplug the television power cord from the electrical outlet.
  • Let the television remain without power for 60 seconds.
  • Plug the power cord back into the electrical outlet.
Jan 09, 2011 | Philips 32PF9964 32 in. Television
Tv won't turn on at all
no remote but tv was working with front power key? unplug from ac outlet and plug back and listen for any type of indication (noise or chirp) that something energizes inside if theres nothing then suspect a power supply problem, main fuse blown, shorted low volt rectifiers other components could be at fault.
Aug 05, 2009 | Panasonic CT-32SL13 32" TV
TV Zoom mode
Change the batteries on the remote, point the remote at the Sony, and hold in the power button for 5-7 seconds. Then depress and re-press the power button - see if you can get the tv remote to respond again.
Then, always try the quick reset:
How to perform a power reset on a Sony® television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
May 16, 2008 | Sony KV-32FS13 TV
TV Turned itself off, and won't turn on...makes a chirping noise
try to check the menu your the timer is on.if not resolder the main board of your tv.
Oct 18, 2007 | LG 30FZ4D TV
TV making chirping sound
If one of the secondary supplies is shorted, the power supply will "chirp" when plugged in. This is the power supply's way of protecting itself and this usually happens when the horizontal output transistor is shorted. If this set was in my shop and needed a new output transistor, a fair price would be right around $100.
Jun 28, 2007 | Toshiba 32DF46 32" TV
RCA F32650 32" TV Logo
80 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
