Question about LG VOYAGER VX10000 Cellular Phone
LG Voyager. Voice mail indicator does not show. I have tried turning it on and off from the voice mail main menu
Wont tell when I have a voicemail
you have probably turned off the voice messaging indicator, log into your voice mail and choose the number option for voicemail settings/options and then make sure that the voice messaging indicator is set to on
Aug 04, 2013 | LG enV VX9900 Cellular Phone
Voice Command Problem
Hi sherri you are sure the connection the rear Audio/input is in the right location and the menu should have a selection under the menu/title that is a mute function
Sep 07, 2008 | Kenwood DNX5120 DVD Navigation System GPS...
I need to change my voice message
1 Call your Motorola voice mail service. Press the "Contacts" or "Address Book" button and select the "Voice Mail" entry. Press the "Call" button.
2 Enter your password. Call the service provider for your Motorola phone if you cannot recall it.
3 Delete all voice mail messages. In order to access the main menu you'll be required to empty your inbox.
4 Select "Change Personal Options," then choose the "Change Voice Message" menu. Disconnect the phone call to save your settings.
Jan 14, 2011 | Motorola Mobility RAZR V3
My LG Optimus will not receive incoming calls. Whenever someone tries to call my phone it goes directly to voice mail. I can still receive all other alerts such as sms, mms, and e mail but my voice calls...
My LG Optimus will not receive incoming calls. Whenever someone tries to call my phone it is showing missed call onlyl. I can still receive all other alerts such as sms, mms, and e mail but my voice calls are not coming through. What to do
Dec 17, 2010 | Computers & Internet
How do I access the voice mail on my LG Neon 2 cell phone?
  • Press and hold the "1" key to call into your AT&T voice mail.
  • 2
    Enter the default passcode (your seven-digit telephone number--not including the area code) using your keypad.
  • 3
    Press "4" to access the "Personal Options" menu. Press "2" to enter the "Administrative" menu, and then press "1" to change your passcode. Enter the default passcode, and then enter your desired passcode. Listen to the playback for verification.
  • 4
    Wait until you are returned to the main menu. Press "4" for "Personal Options," and then press "3" to change your greeting.
  • 5
    Press "1" to change your "No Answer/Busy" greeting, or press "2" to change your "Extended Absence" greeting. Follow the voice prompts to record your personal greeting (this replaces the standard "answering machine" recording).
  • Read more: How Do I Set Up My LG Shine Voice Mail? ' eHow.com http://www.ehow.com/how_5984327_do-lg-shine-voice-mail_.html#ixzz15IGt4VZz
    Nov 14, 2010 | Cell Phones
    It won't tell me when I have a voicemail message
    Check your voice mail options and make sure the message waiting indicator is turned on.
    Jun 16, 2009 | LG VOYAGER VX10000 Cellular Phone
    My LG VX6100 won't accept voice messages
    Problem solved! Turns out that my son didn't realize that you have to call your voicemail box and delete voice messages by pressing "7" on the keypad. He thought that when you pressed "erase all" on the text message menu it erased voice mail, too. So the mailbox was full, as it only holds twenty messages. Sometimes the most obvious solution is the solution!
    Jan 12, 2009 | LG VX6100 Cell Phone
    Speaker key and deleting voice mails
    you hit the speaker button on the left side of the phone and the pad shows up...
    Apr 22, 2008 | LG Prada KE850 Cellular Phone
    Displays new voice mail and VMWI constantly blinking when no voice mail
    Subscriber is T-Mobile@Home. First, cleared all messages from T-Mobile voicemail.
    Now to fix your GE phone:
    Push the program key. Select Handset Setup Push the program key Select Default Settings Push the program key Select 1 Yes. Push the program key
    Hope this helps.
    Mar 06, 2008 | Uniden Cordless Phone
    Voice Dialing
    voice dial number is depend on operetor. in ur phone goto menu-message-(setting) voice mail server
    Feb 15, 2008 | LG CU500 Cellular Phone
    LG VOYAGER VX10000 Cellular Phone Logo
    204 people viewed this question
    Top LG Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Raphael Josiah
    Are you a LG Cell Phone Expert? Answer questions, earn points and help others
