Question about Panasonic KX TG5100M Cordless Phone
Panasonic Kx-TG2432 Displays E9
The base displays E9 and the charge, message play and answer on LEDs remain flashing. The problem won't go away. Pls, help!
Same here on KX-TG2248:
"Answer on" is flashing rapidly.
"Message/Slow Talk" is flashing rapidly.
"In Use/Charge" is flashing irregularly.
LED displays "E3" (and "set clock" symbol is flashing).
Removing and restoring power, many times,
produced one "spontaneous remission"
(it worked fine for several hours)
but next time moved (having to disconnect power),
it's now quite "committed" to remaining "insane" as above.
Posted on Sep 15, 2010
  • SarahNoName Sep 15, 2010
    but next time it was moved (also having to disconnect power),
    it's now quite "committed" to remaining permanently "insane."
My answering machine is not picking up voice messages
Make sure the answering system is on. (You can use either the base Answer On button or Menu > Message Play (press Select) and then 8 on the handset.) Make sure the memory is not full; the unit can hold ~64 messages including the greeting. The base will show a flashing "Full" when the memory is full.
Finally make sure the system isn't set to "Greeting Only". From the handset, press Menu and navigate to "Initial Setting" then press the right arrow. Scroll to "Set answering" and again press the right arrow. Scroll to "Recording Time" and again press the right arrow. Select the choice you want either by scrolling or by pressing 1 through 3. If you press 0, you get Greeting Only. Press Save and then Off.
Please note that the unit's answering system is not compatible with Voice Mail service from your telephone line provider. You will need to have the Voice Mail disabled or leave the unit's answering system off.
The manual is available here: http://service.us.panasonic.com/OPERMANPDF/KXTG2431.PDF for more information.
I hope this helps.
Nov 21, 2010 | Panasonic KX-TG2432 Twin Cordless Phone
Panasonic KX-TGA430B randomly drops the call and displays 'No link to base' error.
Hi there, your phone is experiencing a signal problem or a line problem you should try using another phone to see if the problem will remain if does remain this mean its a problem with the phone line but if the problem go away this mean the phone antenna need to repair or replace.
Jul 07, 2010 | Panasonic KX-TGA430B Cordless Phone
KX-TG4321 & KX-TG430B - Purchased separately, can't register handset to base
(Got this from a Panasonic Support Tech...Thanks Panasonic!) The following steps should help.... Resetting Handsets
Oct 22, 2008 | Panasonic KX-TG4321B Cordless Phone
Deleting messages from KX TG 2432
*4 will erase the currently playing message; *5 will erase all messages.
Jun 16, 2008 | Panasonic GigaRange KX-TG2432 Cordless...
I need to know how to retrieve messages from this phone From another number
1.Call from a touchtone phone.
2.During greeting message, enter your remote code. (Code is "11" by default, or you can set your own beforehand via Menu>Initial setting>Set answering>Remote code>enter your desired 2 digit number)
3. Unit will announce number of new messages, and play them back.
4.After 3 seconds, voice guidance will start; follow as necessary.
Bypass voice prompt by pressing:
1 Repeat message (during playback)
2 Skip message (during playback)
4 Play new messages
5 Play all messages
9 Stop (to resume, enter a command w/in 15 sec, or voice prompt resumes)
0 Turn answering system off
*4 Erase this message (during playback)
*5 Erase all messages
If answering system is off, you can force it back on by calling and letting phone ring 15 times.
Good luck. Hope this helps!
Apr 04, 2008 | Panasonic GigaRange KX-TG2432 Cordless...
Panasonic Phone KX-TG2432
I have the same probloem with a KX-TG 5672. I am going to call 1 800 2111 7262 on Monday and ask for technical support. If you get a solution, pls notify me.
Jan 07, 2008 | Panasonic KX-TG5632 Phone
Panasonic cordless KX-tg5432
Message on phone is "get closer to base
Jan 03, 2008 | Panasonic GigaRange KX-TG2432 Cordless...
Answering machine
Try this. Erasing all messages 1 Press {ERASE} while the base unit is not being used. LThe unit will announce ?To erase all messages, press ERASE again.? 2 Within 10 seconds, press {ERASE} again. The unit will announce ?No messages?. If there are any further questions or comments, please post here. Please rate this solution through fix-ya.com Thank you
Jun 20, 2007 | Panasonic GigaRange KX-TG2432 Cordless...
Panasonic KX TG5100M Cordless Phone Logo
541 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
