Question about Roper FEP320 Electric Kitchen Range
Roper display says "door" oven will not work
I have an old Roper F9257LO model with digital display. After having run the timer for cooking something, when the oven turned off it will not allow work. The display just says "door". We have tried the breaker, checked the door, etc.. The top buners work as well as the clock. Can not get the over to work on bake or broil. Display keeps going back to "door"
  • lionhrtma Dec 06, 2007
    I threw breaker left off for while turned back on, still says door when oven turned on. I interupted a clean cycle by accidently hitting the cancel button when wiping down the top of the stove. Never saw a clean cycle that could be interupted before. Oven hasn't worked since. I tried to finish clean cycle, but it was reset to 3 1/2 hours and didn't want it to run that long. Only had about an hour left on clean and it was clean.
  • 126 Answers
It sounds like your door switch
Posted on Nov 22, 2007
My microwave stopped working you can input time but when you push start nothing happens it has power and everything just will not start its like the start button does not work
Possibly a bad door switch behind the holes where the latch hooks go into. Usually with the bad switch the timer counts down but nothing runs. It all depends on which switch is bad. Usually 3 switches inside.
Apr 13, 2015 | Sharp R530EWT Countertop Microwave Oven...
My microwave is 25 years old, will it be working to maximum efficiency
If all the settings work and the door closes ok . why throw it out ?. It may not be quite as efficient power wise as a brand new one. the few cents extra to run it against the price of a new one, I would stay with old faithful.
Dec 31, 2014 | Sharp R530EWT Countertop Microwave Oven...
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
Nov 27, 2013 | Sharp R530EWT Countertop Microwave Oven...
I have a flashing code on my kenmore electric oven, model 911.47709200. the code is F7 dc, what does it mean?
Stuck Keypad. Roper ovens with 2 Digit Displays:
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
Oct 25, 2011 | Ovens
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
GE SpacemakerXL, model #JVM1330BW 002, does everything but run
it could be a defective thermal fuse,h.v. cap,h.v. diode or the magnetron tube are defective
Oct 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
F3 error in roper model B9757XO
Hi. This F-3 code is representing a malfunction within the oven temperature sensor. It is open at the moment and unable to transfer data at this time.
You can test by Measuring the oven temperature sensor resistance, should be1100 ohms. If not, replace sensor.
May 16, 2009 | Ovens
When we close the door the motor keeps running.
This just started happening on my Kenmore microwave because the door latch broke off.
Mar 10, 2009 | Samsung SMH7178STD Microwave Oven
Microwave Will not work
This is usually a bad door swithc or loose or broken door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can also find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 10, 2007 | GE JVM1350BW/WW/AW/SY Microwave Oven
Roper FEP320 Electric Kitchen Range Logo
159 people viewed this question
Top Roper Kitchen Ranges Experts
Justin Duby
Justin Duby
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Are you a Roper Kitchen Range Expert? Answer questions, earn points and help others
