Question about LG Televison & Video
My LG OLED TV switches on with the remote but switches itself off in seconds. Please help
    New Friend:
  • 27 Answers
If you continue to change the channel or use the remote does the tv stay on
Posted on Aug 28, 2017
Testimonial: "No"
  • Kyle Woodcock Aug 28, 2017
    This maybe a silly question but have you checked the power cable unplug it replug it at the wall and at the tv
SOURCE:
  • 5 Answers
SOURCE: i bought a second wii remote it is fully charged
wen you go to play a muliplayer game and the second remote won't turn on automatically wen a button is pressed then with the player one remote go onto the wii menu then go onto wii remote settings ( at the bottom of the screen) then click on reconnect press 1 and 2 at the same time on the player one remote after a while it will turn on the do the same thing with the player 2 remote and it should turn on afer a few seconds
hope that helps =]
Posted on Apr 23, 2009
  • 556 Answers
SOURCE: my tv
please change the switches in the front panel this will help.
Posted on Oct 02, 2007
  • 3 Answers
SOURCE: tv turns off by itself in 3 seconds and vcr makes noise
Take out the jammed VCR tape in it. Worked for me.
Posted on Apr 30, 2008
SOURCE: My 42" LG LCD turns itself off
There is probably a firmware update on the LG website that should take care of this.Go to the downloads area and enter the model number for available updates.
Posted on Jul 18, 2008
SOURCE: tv switches itself on and off no picture
Just had this happen to me. It's caused by a failure of the power supply board. Replacing the power supply should fix this issue.
This appears to be a very comon problem.
http://www.reviewcentre.com/reviews110919.html
Cr1spy.
Posted on Apr 06, 2009
LG 43LH5000 has blinking green light (power button).
Failing power supply. It revives, then fails again.
Jul 09, 2018 | LG Televison & Video
My LG Oled TV will not switch off with the remote although I can use it to switch it on
You have main board issues, all off and on commands to the power supply come from the main board.
Mar 11, 2018 | LG Televison & Video
Our lg oled EC 93 purchased 2/2016 stopped working TV froze, now nothing . Cant even turn on or off
Have you tried unplugging the TV for 5 minutes and see if it reset? Have you updated the software?
Feb 27, 2018 | LG Televison & Video
Code for programming to a LG 4K tv?
  1. LG UHD 4K Television - LG.com‎
    Adwww.lg.com/UltraHD4KTVRatings:Reliability 9.5/10 - Picture quality 9.5/10 - Features 9.5/10
Search Results
    Find Your Comcast Remote Control Programming Code
    customer.xfinity.com/...tv/finding-your-remote-control-programming-co...
    Learn Comcast remote codes and more information on how to program your remote control. ... To Watch On Demand Programming with XFINITY TV:.
    DIRECTV - Remote Control Code Lookup
Jan 01, 2016 | LG Televison & Video
My LG 26LH20 turns itseld off after about 2-3 seconds. TV is a little over 1 yr old. I t happened about 2 months ago and I thought it was the cable. had cable serviced, not the problem. now it's...
Tv turn itself off after 2-3 seconds the tv still audio voices?Yes,than the tv long board that call the LCD inverter board it is dead.Require change the tv long LCD inverter board,this board help the LCD screen panel to have a backlight to produced a picture or 2-3 seconds tv power died completely no power to tv all?Yes,than this problems the tv power supply board it is dying.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board or the tv power supply board for the replacement.
May 09, 2011 | LG 26LH20 LCD TV
Need to know how or get instruction to program new auto page xt-100 oled remote starter.
REMOTE TRANSMITTER PROGRAMMING Enter: 1. Turn the Ignition 'switch 'OFF/ON' 3 TIMES and stay in ON position. Within 15 seconds. 2. Push the Valet switch 2 times and hold in on the 2 nd push, when a long chirp is heard then release the valet switch. You are now in the Transmitter programming mode. Program: 1. Press the Lock button on transmitter 1 until the siren responds on Car with a confirming chirp; the first transmitter is now programmed to Car. Exit: Turn Ignition to 'OFF' position, or leave it for 15 seconds. 3 long chirps will confirm exit. Note: If more than 4 transmitters programmed, the system will only keep the last four. The Valet switch is a little Red Push Button that should be mounted under the lower left side of you dash or in the lower left kick panel near the E-brake pedal.
http://www.autopageusa.com/resources/2%20Push%20transmitter%20PROGRAMMING13.pdf
This sis atndard programming for the 900,915,1000,and 100 units.
Feb 12, 2011 | RS1000 OLED 2Way OLED Remote Start w 6...
Rca remote control CRK76TA1 has problem w/ sending signal to tv. if i wiggle the eye, it will work for a while. now, no amount of wiggling will work. i have tried removing batteries and pushing every...
Remote is broken.Replace it.
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Jul 06, 2017 | RCA Televison & Video
Program replacement remote
Enter:
1. Turn the Ignition 'switch ‘OFF/ON’ 3 TIMES and stay in
2. Push the Valet switch 2 times and hold in on the 2nd
Program:
May 21, 2010 | RS1000 OLED 2Way OLED Remote Start w 6...
Televison & Video Logo
83 people viewed this question
RONALD CARTER JR
