Question about Bass Pro Boating
Change impeller on DT65 suzuki outboard 1992-93
How to change impeller
5 Suggested Answers
  • 53 Answers
SOURCE: 2001 suzuki outboard water prop
water prop? if your talking about the Propeller that rotates to propel the boat. only replace it if fins are missing. Aluminum and stainless steel propellers can be rebuilt. If your talking about the water pump impeller. the answer is yes. its rubber and should be replaced seasonly
Posted on Nov 01, 2009
seabelow
  • 95 Answers
SOURCE: how do I change the water pump impeller on a
get the kit from boat shop all it takes is four bolts and remove the lower housing.. when you put the impeller in... flex the blade the same way take a photo before you take it apart...inside get a new gasket for between the upper and lower housing too...
Posted on Apr 09, 2010
  • 43030 Answers
SOURCE: How do I change the Impeller on a 1980 Evenrude
remove the lower unit after disconnecting the shift rod . and you will be right there . caution needed if any or the bolts are showing white oxidation around them .really HARD TO REDRILL AND TAP OUT IF BROKEN
Posted on Apr 25, 2010
  • 91 Answers
SOURCE: suzuki outboard motor 65 hp --oil sensor keeps
assuming you are not out of oil in your oil reservoir you probably have a bad sending unit in the reservoir. never bypass it or eliminate it as you could permanently damage your motor or ruin it if you ran it out of oil.
Posted on Jun 20, 2010
The two check eng and temp lights do not come on when I first turn switch to start on. Suzuki 60 2014
check the oil pressure first with a test gauge, as far as the other light goes have you over revved the engine?
May 22, 2016 | Suzuki Motor, Power Trim, DF60-70 98-00,...
HAVE TO REPLACE A CDI UNIT NEED A BREAKDOWN DT65 SUZUKI 6501
Suzuki DT65 1978 Wiring Diagram Page: 1 - iboats Boating Forums ...
forums.iboats.com/...suzuki.../296297-suzuki-dt65-1978-wiring-diagram Jan 5, 2009 - 6 posts - ‎4 authors ... diagram for a Suzuki DT65 6501 D-10978 (assume this is 1978). ... I looked around for a shop service manual on the internet, located a ...
Jun 23, 2015 | Suzuki Motorcycles
I just bought a suzuki outboard dt65 it sat for 6 years what do i need to do for water ready
remove carbs and clean jets etc ! clean or replace fuel tank and check primer bulb and line not perished ! check compressions and sparks ! remove gearbox and replace the impellor even if it looks ok and replace the gear oil ! run in tub of water for an hour to check cooling and the thermo opening also check no fuel leaks etc !
Jul 24, 2011 | Suzuki Boating
Suzuki outboard motor 65 hp --oil sensor keeps
Jun 19, 2010 | Boating
Oct 31, 2009 | Light Outboard Motor Boat Bass Fishing...
I have a Suzuki DT65, all is fine until motor warms up then i loose mid range, it's either idle or flat out, can someone help with this problem.
have a Older DT65 and the MOTOR is clean but wont tur over and sounds like a bearing in grinding or somthin
Aug 12, 2009 | Boating
Boating Logo
463 people viewed this question
Top Bass Pro Boating Experts
ray gallant
choprboz5
vinayghl
Are you a Bass Pro Boating Expert? Answer questions, earn points and help others
