Hi, Ann,
This means that either the camera is damaged in some way, or that there is something jamming the lens gearing within the camera body. Either way it requires a service
It makes the noise has if it's opening but it's not coming out
Still the same answer - needs a service
Cheers need to find somewhere that does it where I live
Can't help with that, I'm afraid. Try Google.
SOURCE: camera lense/power
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
SOURCE: 42 inch Hatachie Ultravision model 43UWX10B and
The magic focus will stop if there is a bad sensor and or a problem in the convergence circuit.
This set uses two STK-392-110 convergence chips--both along with any of the resistors that protect them need to be replaced and the set adjusted--I have repaired hundreds of these sets----
Confirm
model number----and if you go into the customer menu and either red or
blue will not move in any or some direction--the chips have to be
replaced---LET ME KNOW WHAT YOU FIND AND I CAN GIVE YOU FAIRLY DETAILED
INSTRUCTIONS ON WHERE TO GET THE PARTS AND WHAT IS INVOLVED IN THIS
REPAIR.
I am here to help people--
REGARDS, SD TECH
SOURCE: When I turn the camera
This could be a lens issue or power issue. Here are two websites that delineate what you can try to fix the problem:
Even though it says "lens error", it applies to all lens problems.
This blog deals with power problems:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
They say that 50% of cameras with these problems can be fixed, and hope you're one of that 50%! Good luck.
SOURCE: I need to download a
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Testimonial: "Many thanks.My wife had lost her manual for the camera.We have printed a copy of it.10/10 for the expert help."
